Originally Posted by Timmastertech
You can get that diff out without taking it apart. I pull the steering linkage completely then unbolt the steering box and shove it up. That gives you enough room to get the diff out. Still not a fun diff to do but on the bright side, those cooler lines are real easy to do with the diff out! Hope you used GM lines or you will be doing the cooler lines again soon from experience. The Dorman lines tend to last about a year before they start leaking
Believe me, I tried. I tried and tried and tried. I just could NOT get the angle I needed for the housing to clear the mounts on the frame. It's no big deal to pull the passenger axle tube, it's only 5 bolts. I didn't consider moving the steering box, personally that's way more work than it's worth however having the pitman arm out of the way would have been WONDERFUL.
I did use the GM lines for the block -> adapter, however I couldn't get my hands on adapter -> radiator lines in the time I needed, so Dorman went in. At least if they fail, they're the eas(ier) ones to do again.
