Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
powhitehorn, Centripetal, MRLakersLA, elksniserviss_lv, Sukhi
70476 Registered Users
102 registered members (atikovi, AC1DD, 928, ammolab, avi1777, Aero540T, 8 invisible), 3,062 guests, and 25 spiders.
Topics300,322
Posts5,173,273
Members70,476
Most Online3,825
Jan 19th, 2020
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid #5286501 12/05/19 09:55 PM
F
FloridaTime Offline OP
F
The CVT service is due in my wife’s Outlander and the dealership advise me that the 2016 Outlander does not have a serviceable filter. The CVT service consist of a drain & fill. I’m not to thrilled to pay them $280 for something I can do for easily myself with $60 worth of fluid.
The Valvoline CVT Fluid states it’s compatible with Mitsubishi J1/J4. My question is has anyone used this in their Mitsubishi CVT with any issues?
Thank you in advance!
98’ Range Rover P38: M1 HM Syn 10w-40
16’ Mitsubishi Outlander: Valvoline HM Syn 0w-20
19’ Jeep Renegade: Valvoline Syn 0w-20
92’ Range Rover Classic: Valvoline HM 10w-40
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: FloridaTime] #5286627 12/06/19 06:24 AM
J
Jimzz Offline
J
Ive used plenty if Valvoline CVT fluid without issue. Use it mostly in Nissan as its not a red color.
If the Mitsubishi CVT fluid is red then use Castrol CVT fluid. If is anything else then Valvoline will work for that. Only reason i do that is if there is an issue during warranty period they can;t use the color to make your life hard. After the warranty is over then you can run what ever is onsale.
yup
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: FloridaTime] #5286793 12/06/19 10:49 AM
J
JTK Offline
J
The Jatco CVT will have a serviceable filter. They're mounted behind the fluid cooler/heater assembly, or under a separate external housing on the case. I doubt a Mitsubishi dealer would know or even care to address them. There's also a typical mesh filter under the pan.
Main thing is refreshing the fluid. A filter change would be nice at higher mileage IMO.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: JTK] #5286860 12/06/19 12:18 PM
F
F
What mileage would you recommend? 100k?
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: FloridaTime] #5286888 12/06/19 12:50 PM
J
JTK Offline
J
For the filters, I'd think 75-100K miles. For fluid refreshing? 25K and then every year or so.
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: FloridaTime] #5288116 12/07/19 09:26 PM
6
69Torino Offline
6
There is also a fluid degradation value that is resettable in the ECU. What you are paying for at the dealership should include this step. The ECU knows how long the fluid has been in the trans, and adjusts the adaptives accordingly. New fluid will feel much smoother in the transmission with the degradation value reset. I have performed this procedure at the Kia/Mitsubishi dealer I worked for. Most techs don’t know about it and just spill and fill the trans. Especially the kids.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2000 Nissan Xterra
2008 Hyundai Santa Fe
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid [Re: 69Torino] #5288431 12/08/19 10:37 AM
J
JTK Offline
J
I know Jatco units do have a fluid life monitor of sorts in Nissans. It's mentioned in Nissan factory service manuals, but I assume it comes with all Jatcos. I was under the impression that any adaptive learning the CVT does is based on inputs only. Not on the value the counter gives. Nissan says to change fluid if the counter exceeds 210000 points or something like that.
