Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Detroit 4-53T swap update.
by A310 - 01/19/20 12:54 PM
Wiper arm tension...
by Loogie - 01/19/20 12:26 PM
Changing Battery
by Char Baby - 01/19/20 12:16 PM
UOA shelf life
by STIcandy - 01/19/20 12:02 PM
2015 Ram Engine Oil
by nemtulea - 01/19/20 12:02 PM
Fram TG7317 1000 miles
by KenshinHimura - 01/19/20 11:57 AM
2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
powhitehorn, Centripetal, MRLakersLA, elksniserviss_lv, Sukhi
70476 Registered Users
103 registered members (AC1DD, 55hambone, Astro14, 928, ammolab, Aero540T, 9 invisible), 3,040 guests, and 20 spiders.
Topics300,323
Posts5,173,278
Members70,476
Most Online3,825
Jan 19th, 2020
3 HP on a 15 Amp 120 v circuit #5286498 12/05/19 09:53 PM
Snagglefoot Offline OP
This Makita Air compressor is labeled 3 HP but has a 120 V 3 prong cord. I’m used to the limit being 2.4 HP on a 15 Amp breaker. (120 V x 15 A)/746 Watts per HP. Does anyone know the answer on how Makita expects this to be run on a 120 V outlet.I suppose one option is to upgrade to a 20 A breaker if the wiring is up to it. A search of the internet brought up a fellow asking the same question about the same compressor.
If you want the job done right......do it yourself.
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286503 12/05/19 09:59 PM
Donald Online Content
Online Content
I would get a AC peak hold amp meter. Maybe they did some marketing rounding of the HP.
2015 Ford F-250 w/Powerstroke
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286510 12/05/19 10:11 PM
R
Rand Offline
R
peak hp its how shop vacs are 6.5hp.
that air compressor draws around 13.8amps. so its really more like 2 continuous hp.
ps those are great air compressors.. none better in that size.
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286511 12/05/19 10:12 PM
Just found the spec sheet on the net. It’s 2.1 running horsepower and 3 peak HP. Problem solved. Looks like a bit of false advertising. Thanks.
spank
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286519 12/05/19 10:26 PM
P10crew Online Content
Online Content
Snag it’s the new math. Smoke and mirrors
746 Watts per hp and don’t forget to add the service factor. Modern motors are usually 1.15 sfa the good old ones were 1.25 sfa.
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286643 12/06/19 06:57 AM
E
edwardh1 Offline
E
like toilet paper and paper towels, 6 of their rolls equal 400 of other brand.
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286665 12/06/19 07:52 AM
Dave Sherman Offline
There was a bit in the news years ago about air compressors having misleading or meaningless HP ratings, namely against Craftsman and CH. Their cryptic rating was based on the instantaneous power it could deliver for a split second from the inertia of the rotating assembly if it suddenly stopped. Totally meaningless for an air compressor, but I'm sure the marketers thought it was a great idea. I have a "3 HP" Craftsman that was rated at 13 amps at 120 volts. Yeah, sure. Thought it was funny when years after I bought it, it was recalled for a possible fire hazard, and when it came back from repair it had a new sticker on the motor shroud that says 1.5 HP. Guess they decided they had to come clean and state that it's not really a 3 horsepower motor.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: 3 HP on a 15 Amp 120 v circuit [Re: Snagglefoot] #5286720 12/06/19 09:17 AM
B
bullwinkle Online Confused
Online Confused
B
Their horses aren’t Clydesdales, more like Shetland ponies! You should be OK, but a stout extension cord & running on a circuit with nothing else will be necessary for 15A 120V.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 3 HP on a 15 Amp 120 v circuit [Re: P10crew] #5286785 12/06/19 10:39 AM
CR94 Online Content
Online Content
746 Watts per hp and don’t forget to add the service factor. ...
... And that's per horsepower electrical input power. Mechanical output power will be substantially less, because the motor is not 100% efficient.
2011 Toyota Prius now at 107K
