Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
147 registered members (AC1DD, 53' Stude, 2010Civic, 3MillerBoys, 25ring, 928, 15 invisible), 2,535 guests, and 18 spiders.
Topics300,649
Posts5,180,191
Members70,541
Page 2 of 3 1 2 3
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286363 12/05/19 07:33 PM
A
atikovi Offline
A
I have a welder AND the special socket like any good mechanic should. Only I chose to work smarter, not harder.
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286373 12/05/19 07:40 PM
A
atikovi Offline
A
Absolutely. I don't even drink coffee.
Re: Drain plug with nut welder to it. PIC [Re: atikovi] #5286380 12/05/19 07:46 PM
T
tig1 Offline OP
T
As I said when I posted this thread. "If anyone is interested". Since you're not, move along, nothing here for you to see.
2007 Ford Fusion 252,000 miles
M1 5-20HM
2017 Ford Fusion 85K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Drain plug with nut welder to it. PIC [Re: atikovi] #5286381 12/05/19 07:46 PM
PimTac Offline
But not before you start a thread asking what kind of washer to put on the bolt or if you should wax the oil pan.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286398 12/05/19 07:59 PM
spasm3 Online Happy
Online Happy
Some round off sockets need to be hammered on to work properly. Not something you want to do on an oil pan. Tig1 used the method he is a expert at and it worked well. Different ways to attack a problem, you use the one you are most familiar or experienced with.
Nice job Tig1. With your experience it probably took no time at all.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286401 12/05/19 08:01 PM
J
jeepman3071 Offline
J
Nice work! It's crazy what some people will do to drain plugs and let the car leave.
To those who said "I take it to X place and if it strips it's on them" good luck. I've fixed a number of drain plugs where there was clearly a leak and they sent it down the road anyway.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286429 12/05/19 08:40 PM
J
JeffKeryk Online Content
Online Content
J
Plus your way is just plain cool...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Drain plug with nut welder to it. PIC [Re: Driz] #5286430 12/05/19 08:42 PM
Chris142 Online Content
Online Content
Originally Posted by Driz
Right there you have proof positive that you don’t get mechanical superstars working at oil change joints. Some people just cannot be trusted around air tools🙈. Yet another reason why it’s always better just to do it yourself. No matter how bad you screw it up you can’t do any worse.....
Ain't nobody using an air tool on that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286434 12/05/19 08:45 PM
N
NormanBuntz Offline
N
Nice work by you. As a retired welder, you saved yourself some decent coin. Think what a shop would have charged.
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 11K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Drain plug with nut welder to it. PIC [Re: NormanBuntz] #5286451 12/05/19 09:08 PM
T
tig1 Offline OP
T
$50-$100 would be my guess. shrug Actually I still have a welding shop and work part time. Also I do the welding for a small machine shop. They have no need for a full time welder.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: Drain plug with nut welder to it. PIC [Re: PimTac] #5286515 12/05/19 10:19 PM
R
Rand Offline
R
no no no you have it all wrong.. he uses all the time he saves with the sockets to pick rocks out of his flipper car tires.....
Re: Drain plug with nut welder to it. PIC [Re: PimTac] #5286540 12/05/19 11:24 PM
SLO_Town Offline
LOL!
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286555 12/06/19 12:12 AM
M
M56959 Offline
Global Moderator
Global Moderator
M
Just a friendly reminder that being uncivil towards each other will have consequences.
Re: Drain plug with nut welder to it. PIC [Re: tig1] #5286640 12/06/19 06:53 AM
E
edwardh1 Offline
E
does any one brand have "substandard" drain plugs, that fail more often?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Drain plug with nut welder to it. PIC [Re: edwardh1] #5286651 12/06/19 07:09 AM
T
tig1 Offline OP
T
Using the wrong socket or way over tightening drain plugs with a intergraded "O" ring is the most common cause for the head of drain plugs to round off. That's just one of several reasons why I still do my own engine and trans oil changes.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Page 2 of 3 1 2 3
