Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
It was 1911
by CourierDriver - 01/17/20 06:10 PM
Desulfating a Battery
by 5AcresAndAFool - 01/17/20 05:41 PM
weird deal alert: potassium permanganate
by GON - 01/17/20 04:42 PM
CPA1989, myisland, BuellRacer, devharryc, UncleNorby
70460 Registered Users
50 registered members (69Torino, adams355, aquariuscsm, 928, 4 invisible), 1,438 guests, and 24 spiders.
Topics300,266
Posts5,171,967
Members70,460
Most Online3,728
Jan 11th, 2020
where does gas go if not poured directly in fuel hole? #5286115 12/05/19 03:17 PM
A
apollo18 Offline OP
A
hey guys! my last bottle of fuel injector cleaner didnt have a good spout on it and my gas hole has the sheet metal infront of it so the only way to make sure gas is actually going directly in the tank is to push the sheet metal thing with the gas tank metal nozzle. so i had to pour my fuel injector cleaner on the small holes in the gas tank filler neck.
i just wanna make sure that still leads str8 to the tank and not to waste under the vehicle?
i can provide pic if im not making sense but my gas tank has the main fill hole and then nearby it has a bunch of 1 cm holes in it, so im wondering where those lead to
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286143 12/05/19 03:41 PM
M
mk378 Offline
M
It will just drip down into the pipe and end up in the tank. The holes are there is in case some gas ends up outside the door when removing the nozzle. Also they let air and vapor escape as the tank fills.
The door is to remind you not to fill up with diesel or leaded gas. Only an unleaded pump should have a nozzle small enough to fit.
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286146 12/05/19 03:44 PM
K
kschachn Offline
K
So you're saying there is some sort of blockage in your gas hole?
Nah, that's all right. I think we can work on this without pictures.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286154 12/05/19 03:47 PM
E
eljefino Offline
E
It all goes to the tank. Think about it, you have an evaporative emissions system that keeps fuel and fumes in, and the o-ring in your gas cap is the top seal for that. Everything below-- both the small and big holes all go to the same place.
I think the small ones are to give a liquid signal to the gas nozzle that the tank's full, and it should shut off now, but don't quote me on that.
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286172 12/05/19 04:06 PM
Quattro Pete Offline
This may vary from one vehicle to another. In some capless ones, the fluid can end up on the ground instead of in your tank.
Example:
https://www.youtube.com/watch?v=mlqqD44HWFE
Even though my 530i doesn't have capless gas tank, if I don't ensure that the little metal flap is open, I'll end up with fluid on the ground.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286185 12/05/19 04:21 PM
T
tcp71 Offline
T
There is a low point drip hole on our sienna. It drops fuel spilled when removing the nozzle onto the inner fender and the ground.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: where does gas go if not poured directly in fuel hole? [Re: kschachn] #5286265 12/05/19 05:53 PM
9
92saturnsl2 Offline
9
I think he's describing the little hinged metal flap that's present in a lot of gas tank fillers... The one that gets depressed when you put the nozzle in. That same one that gets in the way when you want to dump a can of fuel injector cleaner in, or use a gas can and the spout's not long enough smile
I've had this happen many times, I watch the gas/fluid just trickle around it; it eventually gets to the tank I assume as there's never any fumes or liquid spilling on the ground.
96 Grand Prix SE (project car)
04 Odyssey EX 200k Philips Shield Choice 10w-30
96 Maxima GLE 275k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286299 12/05/19 06:25 PM
dogememe Online Content
Online Content
One time I put a fuel additive in my Ford and it all spilled on the tire because yay capless frown so depending on the car if your container isn't capless compatible you have to use the weird funnel thing that comes with the car. Of course I wasn't paying attention and didn't notice the puddle on the tire and the ground until I dumped the whole bottle of additive in @[email protected]
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: where does gas go if not poured directly in fuel hole? [Re: apollo18] #5286486 12/05/19 09:43 PM
N
NoNameJoe Offline
N
The small hole outside of the fuel cap leads to the fender and the ground, not the fuel tank. If the holes are past the fuel cap, then yes that stays in the fuel system.
2015 Civic LX Coupe
