Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
91 registered members (aircooled, Antiquity, 2K2AcuraTL, 2004tdigls, AndyB, 90crvtec, 9 invisible), 1,925 guests, and 16 spiders.
Topics300,379
Posts5,174,636
Members70,492
Volvo T6 (SI6) oil #5285964 12/05/19 12:59 PM
P
posaune Offline OP
P
I've been using M1 0-40 in everything I own for many years (VWs and Volvos, including an '09 XC70 T6), but I just bought a '15.5 XC70 T6 with a CPO warranty. Since these things can and do have ring problems, I want to make absolutely sure that I use the "right" oil according to Volvo so they can't deny coverage in the event of an issue, but I can't really get a straight answer about what's right. I figure BITOG will have some opinions... grin
-My manual and the website says the cars need 0w-30 A5/B5
-The dealer that sold be the car used Castrol 5w-30 and the local dealer said 5w-30 was specified in the manual (see above)
-Volvo "recommends" Castol Edge Professional 0w-30. That's not readily available in the states as far as I can tell, though you can buy quarts at the dealer for $$$$
-Lubri-Moly Special Tec V 0w-30 is "Volvo approved" and is about $38/5L at Amazon and FCPEuro (not too far form me)
-Pennzoil Platinum, Ultra Plat, Mobil 1, and Castrol all make a 5w-30 A5/B5 and are cheaply available down the street at Wal-Mart
So? What would you do? The car has 38k miles and is under CPO warranty until 100k or 2025.
Re: Volvo T6 (SI6) oil [Re: posaune] #5286001 12/05/19 01:32 PM
J
Jimmy_Russells Offline
J
The LM is $38 shipped, I'd go with that. You'd probably never have a concern with the 5w's but personally I wouldn't use them until warranty was over.
Re: Volvo T6 (SI6) oil [Re: posaune] #5286011 12/05/19 01:45 PM
E
edyvw Offline
E
Are there any alternatives in manual?
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Volvo T6 (SI6) oil [Re: posaune] #5286057 12/05/19 02:25 PM
K
kschachn Offline
K
Your manual says this, correct?
Quote
Full synthetic engine oil meeting the minimum ACEA A5/B5 must be used. Lower quality oils may not offer the same fuel economy, engine performance, or engine protection.
And any grade statements I saw are recommendations, right? Not requirements.
Given that, any ACEA A3/B4 oil is also acceptable since that is a higher specification (above the minimum of ACEA A5/B5). Therefore the Mobil 1 0W-40 meets the requirements of your warranty booklet.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Volvo T6 (SI6) oil [Re: posaune] #5286069 12/05/19 02:33 PM
B
brages Online Content
Online Content
B
[Linked Image]
5W30 would be allowed by the manual. I believe an A3/B4 oil will give better protection, but worse fuel economy...
Re: Volvo T6 (SI6) oil [Re: posaune] #5286074 12/05/19 02:36 PM
P
posaune Offline OP
P
Ok, well, I looked at the maintenance manual online and it shows 5w-30 (as above). I SWEAR I looked at that before...
Still though, it says that "extreme operation" requires 0w-30, and that includes trailer towing. Since I have a trailer hitch and module, I think I'm still stuck with 0w-30. Looking up what is the required oil on the website still comes up with ONLY 0w-30.
So the 0w-40 is a higher spec than A5/B5? I'd love to continue using that, but I don't want to give them ANY reason to deny warranty coverage.... Tbh, so far, Volvo has been quite good about warranty work (versus VW, which seemed like a fight every time), so I may be overthinking this.
Re: Volvo T6 (SI6) oil [Re: posaune] #5286087 12/05/19 02:51 PM
K
kschachn Offline
K
Just be aware that "0W-30" is not a "requirement" for extreme engine operation, if anything the ACEA rating of A5/B5 is. There are other 0W-30 oils that are not A5/B5. For example Mobil 1 Advanced Fuel Economy 0W-30 would not qualify.
But again that is a recommendation not a requirement. So your current M1 0W-40 is a better choice giving you slightly higher operating viscosity.
1994 BMW 530i, 251K
Re: Volvo T6 (SI6) oil [Re: posaune] #5286149 12/05/19 03:45 PM
M
mattwithcats Offline
M
You can buy Liqui Moly from Rock Auto...
Liqui Moly 0W-30
Add a filter while your there...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Volvo T6 (SI6) oil [Re: posaune] #5286359 12/05/19 07:27 PM
P
paoester Offline
P
My favorite is the 0w-30 A5/B5 (also LL-01FE, SN as a bonus) Mini dealership oil. Same as BMW TwinPower 0w30 oil. Both are available all over the internet for delivery to your door, probably on Amazon, ecstuning.com, fcpeuro.com, many more, just google it. Those strictly meet the "0w-30 A5/B5" requirements. The bonus LL-01FE BMW-Mini engine tests are quite tough, ensuring a quality oil for your turbo animal. https://www.fcpeuro.com/products/bmw-engine-oil-07510017866 for one source, the Mini LL-01FE is the same.
My Walmart A5/B5 favorite is Mobil1 Annual Protection 5w30, and I think your Owner's Manual does indeed allow for "5w30" instead of 0w30, so can do....
Thats very high performance oil. It doesn't get much better than that. You get dexos1 turbocharger coking engine tests as a bonus.
Re: Volvo T6 (SI6) oil [Re: posaune] #5286475 12/05/19 09:30 PM
B
Bjornviken Offline
B
any acea A5 will do fine in that engine... you can also use mobil1 0w-40 in that engine.
Re: Volvo T6 (SI6) oil [Re: kschachn] #5286755 12/06/19 10:00 AM
P
paoester Offline
P
Not a higher spec. A different spec for sure. I don't think that's what Volvo means when they say "minimum". See my explanation below.
No.
Take a look at the clear wording in the manual "Full synthetic oil meeting the minimum ACEA A5/B5 must be used." Notice use of the word "must". That is clear. Its a requirement.
1. Full synthetic. and:
2. A5/B5 minimum. By "minimum" they mean the oil can have other extra certifications or approvals piled on, but at a minimum it must be A5/B5 at least.
Definition of "extreme driving" (0w30 clause): I think they are talking about very cold weather, like below -5F starts. They are not talking about towing or racing.
Now a couple people here are saying the thicker A3/B4 meets the A5/B5. It does not. Its not "above", or whatever words kschachn wants to make up for this. A3/B4 has different viscosity for one thing.
I would personally agree that a 0w40 would be fine, but the goal here is to satisfy the Warranty Claims Dept. at Volvo, not people on bitog.
Re: Volvo T6 (SI6) oil [Re: posaune] #5286845 12/06/19 11:56 AM
E
edyvw Offline
E
There is no such thing as higher spec. Also, 0W40 is grade, not specification.
Re: Volvo T6 (SI6) oil [Re: posaune] #5287016 12/06/19 03:40 PM
B
BMWTurboDzl Offline
B
Basically Volvo requires a HTHS range of 3.5 - 2.9. (i.e. A5/B5). Due to the HTHS requirement these oils will never be 40w. A5/B5 is essentially a slightly thinner version of A3/B4.
435i
Re: Volvo T6 (SI6) oil [Re: posaune] #5287205 12/06/19 07:53 PM
K
Kamele0N Offline
K
Acea A5/B5/C2/C1/C5 is your CAFE....
What you want in your car is ACEA A3/B4 (Full saps) or ACEA C3/C4 (DPF friendly)
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Volvo T6 (SI6) oil [Re: paoester] #5299990 12/20/19 01:49 PM
P
posaune Offline OP
P
Thanks for this. I know I've been throwing around words that do not necessarily apply- my fault, and I know better. I got what I deserved for not thinking before posting here. LOL
I think to be safe, I'll be sticking with A5/B5. It remains to be seen whether I go for the cheaper/easier to get 5w-30 or the LiquiMoly Spec V 0w-30. I sort of lean toward the latter, but that might change when I decide that I want to change the oil at 9p on a Sunday and haven't yet bought any....
No.
