AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
90 registered members (750IX, 67ZL1, 25ring, 53' Stude, 928, 4 invisible), 2,569 guests, and 22 spiders.
Topics300,360
Posts5,174,165
Members70,491
Page 2 of 4 1 2 3 4
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285638 12/05/19 07:25 AM
J
JeffKeryk Offline
J
The K24 starter R&R is involved for those not familiar with the process.
I understand the Element is easier because you can access it from below.
I just had the starter replaced on our beloved 2006 TSX at 190K; I think it was about $600.
They used a Nippondenso reman which is what I would have used if I did the work.
Our friend The Critic might chime in as he is familiar with the process.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285677 12/05/19 08:04 AM
M
Miller88 Offline
M
Every vehicle I've had has needed a starter - except the Subaru. Every single time I bought a Napa starter thinking it was better because it's "premium" and I have always had issues with them grinding the flywheel on the first attempt to crank. I'm running cheap Advance ones and have had a bit better luck with those.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Honda OEM starter vs aftermarket??? [Re: Miller88] #5285680 12/05/19 08:09 AM
Chris142 Offline
Napa's rebuilt starters and alternators are absolute garbage! No shop here will use one as it's a guaranteed comeback. The AutoZone and O'Riley's ones are better than Napa's junk.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285748 12/05/19 09:16 AM
1
1foxracing Offline
1
You might want to search your local area for a shop that rebuilds alternators and starters, use to be a real common thing but maybe they are all disappearing like all the old Mom and Pop chroming shops.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285751 12/05/19 09:21 AM
N
NormanBuntz Offline
N
If you trust the brand name Bosch, www.carid.com has a Bosch reman for $149. At all costs, you should avoid anything remanufactured by Cardone.
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 10K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Honda OEM starter vs aftermarket??? [Re: ctechbob] #5285813 12/05/19 10:19 AM
T
Tundragod Offline
T
ctechbob, like you I did it that way on my 08 Accord last month. Bought https://www.amazon.com/gp/product/B00T9ORWIG/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Rebuilt my old starter with an ebay brush for spare. I don't mind putting my old rebuilt starter back in. The new starter from Amazon is 1 year hassle free warranty.
Op, go this route to save $$. I assume you're looking to save money.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: Honda OEM starter vs aftermarket??? [Re: 1foxracing] #5285885 12/05/19 11:51 AM
B
brages Online Content
Online Content
B
^ yeah, this is what I was thinking
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285896 12/05/19 11:57 AM
N
nwjones18 Offline
N
I'll be the guy that has used the cheapest new starters off of amazon or ebay as long as the reviews were decent. I've had no problems and all are going strong and some were replaced years ago.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 and Mopar filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
2007 Mazda 3 2.3 130k 5w-30 syn-blend and Denso filter
Re: Honda OEM starter vs aftermarket??? [Re: nwjones18] #5285898 12/05/19 12:00 PM
J
JeffKeryk Offline
J
The issue with the K24 engine is the difficulty (cost) to swap a starter out.
You don't wanna do this twice.
I was reluctant to use a top of the line reman, but so far so good.
2018 Lexus RX450h
2006 Acura TSX
Re: Honda OEM starter vs aftermarket??? [Re: Chris142] #5285908 12/05/19 12:14 PM
N
nthach Offline
N
They are all "remanufactured" by BBB Industries or Remy in Mexico. Almost all the bits and pieces inside a chain store or even AC Delco non-GM OEM level reman come from WAI/Transpo from China.
In that case, the lifetime warranty on a Duralast or O'Reilly Optima Select is barely worth the trouble. Denso does their own remans, but only on their units. Supposedly, they rebuild them in Murrietta or Temecula, CA. Bosch also does their own remans but they both farm out non-Bosch/Denso units out to a 3rd party.
Re: Honda OEM starter vs aftermarket??? [Re: nthach] #5285939 12/05/19 12:41 PM
Chris142 Offline
The Napa rebuild we get here were rebuilt in China.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285940 12/05/19 12:41 PM
Chris142 Offline
Book time is 2.2.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5285952 12/05/19 12:50 PM
The Critic Offline
It's about a 45 min job from the top. The intake manifold comes out without too much drama. You might be able to get away with reusing the metal gasket....my local dealer doesn't stock the gasket if it tells you anything.
I had one 2.4 where the starter bolt damaged some threads in the block during removal. Had to tap new threads.
So far I have only used Denso reman's and my experience is that 1 out of 4 have failed after 18 months.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Honda OEM starter vs aftermarket??? [Re: Chris142] #5285991 12/05/19 01:16 PM
N
nthach Offline
N
Something tells me that either Napa is sourcing new from TYC or some other Chinese company and collecting cores to sell to brokers or that BBB/Remy/WAI have a reman plant in China which doesn't make sense due to the e-waste restrictions they recently imposed along with steel/iron/aluminum tariffs.
Re: Honda OEM starter vs aftermarket??? [Re: Garyd] #5286018 12/05/19 01:52 PM
bdcardinal Offline
Going to drop my one bit on Honda parts knowledge here. Friends of mine that work for Honda said that they are really picky about giving core credits. The parts returned must be OE Honda, or Honda reman parts. If they are from a parts house the dealer will not be given the credit from Honda.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Page 2 of 4 1 2 3 4
