Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
109 registered members (53' Stude, 1978elcamino, 65convertible, 2010Civic, AC1DD, 12 invisible), 2,483 guests, and 21 spiders.
Topics300,644
Posts5,180,104
Members70,541
Page 1 of 3 1 2 3
Mechanics and come backs #5285700 12/05/19 08:33 AM
M
motor_oil_madman Offline OP
M
I want to say that 80 percent of the non bitog population don't even know what they are looking at when they pop the hood. (Sad I know) so considering that 8 out of 10 times people work on my stuff I usually have to bring it back for them to fix/finish the job. Why is it that I have to look at it and double check that the work was done right. I wonder if I can just cancel the credit card payment when this happens.
Opinions?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Mechanics and come backs [Re: motor_oil_madman] #5285711 12/05/19 08:46 AM
J
jkhawaii Offline
J
Blame the pay system. Mechanics get paid for speed not quality
Re: Mechanics and come backs [Re: motor_oil_madman] #5285718 12/05/19 08:51 AM
Chris142 Offline
Your lumping us all together. I rarely have a comeback and if I do it's usually a failed part and not a mistake. I'm sure that critics work is as good if not better than mine since he likes to use OEM parts.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mechanics and come backs [Re: motor_oil_madman] #5285726 12/05/19 08:56 AM
W
wag123 Offline
W
Don't cancel the credit card payment, they can put a mechanic's lien on the vehicle.
This sort of thing always has been, and will continue to be, something that happens in an industry that pays it's mechanics on a flat rate commission basis. The industry also suffers from a lack of skill due to the fact that there is precious little formal schooling available for mechanics now days, and the vast majority of training is on-the-job. Customers really have no way of knowing how much, if any, experience the mechanic working on their vehicle has on their specific vehicle and/or problem.
Re: Mechanics and come backs [Re: motor_oil_madman] #5285727 12/05/19 08:56 AM
CARJ Offline
You're always going to read/hear more complaints than praise. I worked with very skilled techs and our dealership rarely had comebacks.
2004 Toyota 4Runner | 194k | Havoline Pro DS 5w-30, YZZD3
2012 VW Passat | 97k | M1 0w-40, XG9911
Re: Mechanics and come backs [Re: motor_oil_madman] #5285752 12/05/19 09:23 AM
Chris142 Offline
You can't or should not cancel a credit card unless you have had to return a few times. A minor comeback that's likely not a techs fault is no reason to cancel payment.
If you think its ok to do that you will be labeled as a whiner and no shops in your area will want to work on your stuff. Most shops are friends with other shops and we all talk.We also know who the flakes in the business are.
Re: Mechanics and come backs [Re: motor_oil_madman] #5285757 12/05/19 09:28 AM
demarpaint Offline
Probably because 80% of the so called mechanics today are hacks. The same can be said for other tradesmen as well unfortunately. There are several good mechanics who reside on this board, Trav, clinebarger, and The Critic come to mind, as do a few others. If they were close to me I'd probably use or recommend them to people. Aside from that finding one can be a challenge, I got lucky and found great tech at a local Jeep dealership. He has been great handling recall and warranty work. He's a great guy, a neat worker and very knowledgeable. I make it a point to take care of him when he does work for me.
God Bless Our Troops
Re: Mechanics and come backs [Re: motor_oil_madman] #5285758 12/05/19 09:28 AM
M
Mad_Hatter Offline
M
Most banks want you to make a good faith effort to resolve the matter before disputing a charge. And just because you can dispute a charge doesn't mean you won't ultimately be on the hook for it.😉
Re: Mechanics and come backs [Re: motor_oil_madman] #5285759 12/05/19 09:29 AM
B
BMWTurboDzl Offline
B
Opinions?
Major disconnect here. You say 8 of 10 non-BITOG don't know what they're looking at under the hood and then project that 80 percent figure onto people who work the trade?
435i
Re: Mechanics and come backs [Re: motor_oil_madman] #5285771 12/05/19 09:40 AM
M
M
I'm saying some mechanics get by with shoddy work because they know that most of the public doesn't even know most of the parts under the hood, so they wouldn't know if it was done wrong to begin with.
Re: Mechanics and come backs [Re: motor_oil_madman] #5285780 12/05/19 09:50 AM
Donald Offline
I think there are many situations where no one will know for a while. With brakes if you did not do a good job of prepping the caliper bracket and putting the proper grease under the clip it would be awhile before the rust from the caliper bracket pushed on the clip. At that point its many months or a year or so after the brake job. It was not done right but no one knew. The next mechanic will attribute it to living in the rust belt.
2015 Ford F-250 w/Powerstroke
Re: Mechanics and come backs [Re: motor_oil_madman] #5285781 12/05/19 09:50 AM
B
BMWTurboDzl Offline
B
Ahh..ok. Well, hmm.I would not charge back on comebacks w because it creates an adversarial tone between you and the shop. Of course I'm assuming you're not talking about unresolved comebacks.
435i
Re: Mechanics and come backs [Re: motor_oil_madman] #5285782 12/05/19 09:52 AM
J
jeepman3071 Offline
J
Good work doesn't come cheap. This applies to any trade. The few times I've taken my vehicles to another shop it wasn't cheap, but the one time I had an issue it was fixed ASAP with no questions asked.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Mechanics and come backs [Re: motor_oil_madman] #5285786 12/05/19 09:59 AM
dlundblad Offline
If you constantly have to return your vehicles, do the work yourself.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Mechanics and come backs [Re: motor_oil_madman] #5285789 12/05/19 09:59 AM
rooflessVW Offline
Find a new mechanic. I don't have this problem.
"Zed's dead baby, Zed's dead."
Page 1 of 3 1 2 3
