17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
113 registered members (amblerman, Alfred_B, 1978elcamino, aircooled, aquariuscsm, 8 invisible), 2,558 guests, and 19 spiders.
Topics300,433
Posts5,175,658
Members70,503
Huge oil leak repair: 2001 Blazer 4x4 #5285451 12/04/19 10:44 PM
1
14Accent Offline OP
1
Unfortunately, I didn't get any pictures but here's the low-down:
I have a customer with a 2001 Chevy Blazer, about 122k on it. It's got to be one of the cleanest Midwest S10's I've ever seen, but it's still a Blazer. I just replaced the ABS module last month to the tune of $1,200, and this month she brought it back after having us degrease it to check for leaks.
I couldn't pinpoint all the leaks, but it for sure needed lower intake gaskets, an oil pan gasket, and oil cooler lines. WHAT A PAIN!! The oil pan alone pays 6 hours, another 2.2 for the cooler lines, and 3.6 for the intake. While I was doing the job, I found several other issues that she didn't blink an eye at: The remote oil filter housing was corroding away and cracking, replaced that with a Dorman unit. The OE block heater was leaking, so that was replaced with a freeze plug with the OK from the customer. I never would have seen the coolant leak without removing the differential for the oil pan job, it's buried above it.
For those that don't know, to do an oil pan on a 4x4 Blazer requires complete disassembly of the front suspension (as in knuckles OFF), disconnecting the steering linkage from both the pitman and idler arms, and removal of the front differential. BUT! You can't remove the front diff WITHOUT disassembling it! The right hand axle tube and shift fork have to be removed to gain clearance to remove the main housing.
I'm 30 years old, and if I go the rest of my career without doing another one of these, I'll be happy. It was ALL overhead work and my shoulders were on fire by the time I was done!
EDIT: Just for fun, because I know someone will ask: The total bill came to ~$2,200. That, plus her ABS repair, puts her at $3,700. For a BLAZER!! I thought I'd seen it all.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285464 12/04/19 11:02 PM
carviewsonic Offline
The company I work for had one, a late nineties Blazer. I drove it a few times to out of town meetings, instead of my muddy field truck. Our mechanic hated it with a passion, said it was absolutely terrible to work on. He had an ear to ear grin for a couple of days when the decision was made to send it to auction.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285474 12/04/19 11:18 PM
F
Falcon_LS Offline
F
The S-10 Blazers are nice trucks, but a real pain in the neck to work on. That's one of the reasons why I'm not a fan of 4x4; I personally have no need for it and refuse to buy a vehicle equipped with it because repairs can get messy. I have a 4x4 in my fleet already, and I yanked the engine right out when the oil pan started weeping.
I take it this was the 4.3L? She must have some sort of attachment to the truck to fork out that sort of money for repairs.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285479 12/04/19 11:26 PM
clinebarger Offline
The Aluminum Pan 4.3L's are notorious for that stupid captured rubber seal to leak.....GM should have stuck with the steel pan that was used on the earlier versions.
Of course the cooler lines & remote filter was always an issue with 4x4 4.3L S/T platform.
2001 Chevy Camaro L92/4L80E
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: Falcon_LS] #5285483 12/04/19 11:31 PM
clinebarger Offline
2wd S/T platforms are even harder to do a oil pan gasket on......The engine has to be removed!
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: clinebarger] #5285508 12/05/19 12:25 AM
F
Falcon_LS Offline
F
Wow, just wow. What the heck were the engineers thinking?!
99 Explorer: H17W02
00 Pajero: XG9688
05 Envoy: XG9837
Motorcraft 5W-50:
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285546 12/05/19 04:09 AM
R
Railrust Offline
R
It simply amazes me that people would spend that much to repair something that old...and that's just until the next thing breaks. You can't stay ahead of vehicles that old and designed that poorly. They will nickel and dime you.
I saw a woman put a brand new transmission in a Hyundai Sonata with 290,000 miles on it once, I thought...what? You've got to be crazy! But the tech told me...hey, it doesn't have any other issues and the lady doesn't want a car payment. Ok, I get that, but 290k miles?? You're going to sink $3,000 into a car with 290k on it? I don't know if that's a great idea; I have a friend that sank 4k into his Jeep Commander - needed an entire engine - that truck lasted another year before it literally caught on fire one day. I told him...guarantee pinched a fuel line when they installed that engine. But there was nothing he could do, it was a year later and it wasn't like he was going to have a forensic unti investigate the burnt carnage and find a pinched fuel line.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: Railrust] #5285566 12/05/19 05:27 AM
demarpaint Offline
Correct. Sometimes the smartest thing you can do is sell or junk it, and move on.
God Bless Our Troops
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285670 12/05/19 07:56 AM
c502cid Offline
Shoot I fixed the ABS module for free on my 2000 Blazer. A piece of electrical tape over the glowing ABS light on the dash.... she's fixed! I really love my Blazer. All my kids drove it in their teens, it's my airport car now. Yeah, she leaks some oil and makes some noises, but I can't kill it and it's a tank in the snow with studded snow tires and a little extra weight in the back.
16 F150 2.7 EB 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285691 12/05/19 08:18 AM
Snagglefoot Online Content
Online Content
We get into these conversations all the time at Bittog.” I have 400,000 miles “ vs “ she should dump it”
According to 14Accent, it’s one of the cleanest Midwest S-10’s he’s ever seen.
A new Blazer starts at $30,000.
So it boils down to those who appreciate a high mileage vehicle and are willing take a risk on future repair costs vs those who would give up and buy or lease a new vehicle. Lot’s of folks on both sides. She’s committed 12 months of equivalent car payments, but sounds like she’s really attached to the vehicle. smile
If you want the job done right......do it yourself.
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285770 12/05/19 09:40 AM
dlundblad Offline
I’ll have to do this repair on my truck probably this spring. When it’s it’s apart, I’ll likely replace the seal in the leaking steering box.
Currently trying to figure out the leaking front diff as you saw in my most recent thread.
It’s still been a good vehicle. Does excellent in snow, decent fuel mileage and I don’t have to worry about it when we go out and about. The only other “issue” I’ve had is a bad fuel pump. Everything else was just my OCD upgrades and PM.
I will say one is better off owning a HM vehicle if they’re mechanically inclined.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285828 12/05/19 10:38 AM
E
exranger06 Offline
E
Sounds like my wife's Escalade. I replaced the engine oil cooler lines, had to drop the front diff to do it.
I replaced the trans. cooler lines, had to remove the whole front bumper and grille, and had to unbolt the front sway bar from the frame. One of the sway bar bolts snapped. I removed the front sway bar and left it like that for 9 months before I finally got around to fixing the broken bolt.
I did a transmission service on it and had to unbolt the exhaust Y-pipe from the manifolds, since the exhaust goes right underneath the transmission pan. That resulted in some broken and mangled exhaust fasteners. I had to remove the driver side manifold to fix it.
I don't understand people who say GMs are easy to work on.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: exranger06] #5285835 12/05/19 10:44 AM
R
Rand Online Content
Online Content
R
would any of that have happened in California? /no road salt?
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5285923 12/05/19 12:29 PM
G
GSCJR Offline
G
Way to go 14Accent! I commend you on your hard work. I don't miss working on those tough jobs one bit.
My lower back still aches after all these years.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 155KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 175KM
Re: Huge oil leak repair: 2001 Blazer 4x4 [Re: 14Accent] #5286054 12/05/19 02:22 PM
1
14Accent Offline OP
1
Wow! I didn't expect all these comments!
I certainly won't be doing another one of these again any time soon. I agree that S10's are tough as nails, and this one was clean, but it's still a ton of money to drop on a 20 year old truck!
My current project is a 2.4 ecotec in a 2wd Equinox. You don't even need to take the wheels off to do an engine! I've gotten so good at them that I can have the old engine out in about 2.5 hours, another hour to transfer components, and running by the end of a 9 hour shift. That's with lunch and smoke breaks. Talk about cake compared to last week, and it pays better!
