New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
25 registered members (ctechbob, bbhero, Dave_Mark, Black_Thunder, d00df00d, blufeb95, 2 invisible), 1,660 guests, and 21 spiders.
Topics300,519
Posts5,177,611
Members70,518
can a dial torque wrench be use for wheels? #5285149 12/04/19 04:17 PM
W
WhyMe Offline OP
W
i have been sorting a lot of tools i have accumulated over the years. one is a Blackhawk 1/2 dial torque wrench. seeing it does not click , can use it to torque lug nuts?
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285152 12/04/19 04:21 PM
Quattro Pete Offline
What is its operating range (torque values)?
My guess is the actual value might be hard to read while you're tightening the wheels. A clicky one is much easier to use on wheels.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285166 12/04/19 04:39 PM
skyactiv Offline
You can use it.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285187 12/04/19 05:19 PM
bdcardinal Offline
You can, but it makes it more difficult since you have to keep an eye on the wrench. I like those for building engines on a stand. Click type are generally the best for tires since you get the positive sound when you reach the desired value.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285188 12/04/19 05:19 PM
T
Traction Offline
T
Good luck trying to read the dial leaned over to see it while using it. Tried it 40 years ago when all I had was a beam style torque wrench, and it is too much trouble.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285219 12/04/19 06:02 PM
sloinker Offline
I bought torque sticks for my impact wrench. I checked them with a couple different torque wrenches for accuracy and they are within 5% of the click and beam style wrenches I own. Saves time and effort and well worth the cost.
They can be had fairly cheaply nowadays at HF.
https://www.larrycloth.com/drive-ft...bn-limiting-tool-color-coded-65-150-inch
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: can a dial torque wrench be use for wheels? [Re: Quattro Pete] #5285223 12/04/19 06:04 PM
W
WhyMe Offline OP
W
it's this model.
https://www.worthpoint.com/worthopedia/blackhawk-torque-wrench-indicator-52638175
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5285669 12/05/19 07:56 AM
T
Trav Offline
T
As others have said, yes you can but trying to read it is going to be a pain. Get a split beam type, there is no need to zero it out every time you use it.
Edit: Put that old timer on the shelf as a conversation piece, you cant trust something almost 100 yrs old to be anywhere close to accurate. The reliability of the parts at that age is another story.
Re: can a dial torque wrench be use for wheels? [Re: Trav] #5286224 12/05/19 05:03 PM
W
WhyMe Offline OP
W
ok. gonna order a split beam soon . so what are these dial ones usually used for? you must be jesting that it is 100 year old. i thought is from the 60's. i paid $10 for it a few years ago. i tested it with my digital adapter and it was only a couple of pounds off .
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5287458 12/07/19 06:59 AM
N
NYEngineer Offline
N
I use dial wrenches for setting preload on pinion bearings and diesel injectors and such.
Re: can a dial torque wrench be use for wheels? [Re: WhyMe] #5288658 12/08/19 03:02 PM
T
Trav Offline
T
The link has it from the 20's..
Quote
BlackHawk ½" Torque Wrench/Indicator - Vintage - Antique - 1920's
Dial type wrenches are for things like head, main, rod bolts/nuts. Some have a memory needle which can be very useful for setting bearing pre-load and transmission bands.
The vast majority of German tire shops I have gone to use split beams exclusively.
