NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
130 registered members (AC1DD, 97prizm, A310, 750IX, 53' Stude, AandPDan, 13 invisible), 2,578 guests, and 26 spiders.
Topics300,364
Posts5,174,194
Members70,491
Diff leaking after second repair attempt #5285095 12/04/19 03:31 PM
dlundblad Online Happy OP
OP Online Happy
I’m at a loss.
I replaced the CV axle and seal on my Blazer’s front diff a few weeks ago with house brand parts. The seal leaked right away so I’m assuming I damaged it somehow. I replaced it with an OE seal and it’s still leaking..
It looks to be leaking between the shaft and the seal. Could it be the shaft is the wrong size? I have no idea what to check at this point.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Diff leaking after second repair attempt [Re: dlundblad] #5285108 12/04/19 03:43 PM
The Critic Offline
Check the surface condition of the new shaft. If it was improperly finished, this can cause a leak.
Do you still have the old shaft? If you do, reinstall the old shaft with a new seal and see if it still leaks.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Diff leaking after second repair attempt [Re: dlundblad] #5285119 12/04/19 03:52 PM
Chris142 Offline
measure the place where the seal runs on both axles.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Diff leaking after second repair attempt [Re: The Critic] #5285140 12/04/19 04:08 PM
OP Online Happy
The old axle is long gone. Ill have to recheck the surface finish.. Does it take much roughness to cause an issue?
Either way, I am guessing the seal is bad at this point.
Re: Diff leaking after second repair attempt [Re: Chris142] #5285142 12/04/19 04:09 PM
OP Online Happy
Will do.
Re: Diff leaking after second repair attempt [Re: dlundblad] #5285143 12/04/19 04:09 PM
R
Redright9 Offline
R
Is there a vent? check that, I have had seen plugged vents allow diffs to create too much pressure and create leaks.
Re: Diff leaking after second repair attempt [Re: dlundblad] #5285445 12/04/19 10:37 PM
1
14Accent Offline
1
How much play is in there in the diff? Worn bearings will allow the CV shaft to wobble and cause a leak. Try wiggling the CV shaft up and down, how much movement is there?
I just had the front diff out of a '01 Blazer to do an oil pan gasket. I had 0 leaks afterwards, reusing all the original parts.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Diff leaking after second repair attempt [Re: 14Accent] #5285565 12/05/19 05:22 AM
OP Online Happy
That’s certainly worth mentioning, but it didn’t leak beforehand so I’m assuming the bearings are still good.
Re: Diff leaking after second repair attempt [Re: dlundblad] #5286699 12/06/19 08:43 AM
OP Online Happy
Well this is embarrassing.
I check it last night and the CV shaft wasn’t fully seated. Literally 1/2” of play in all directions.
I do recall wondering if it was fully seated, but I gave it a tug both times and wouldn’t back out without some considerable force. I think the snap ring is too open so I’m going to try without it just to make sure it’s not another issue. It’s just odd because I’ve done the job before without issues.
