Hi all,
My '07 RAV has 166k miles but I had the trans oil drained and filled a while back ... had it done again due to suspicions of potential transmission trouble. I'm getting a vibration at 65 in OD that is bad enough that the rearview mirror is unusable - problem stops at higher speed/RPMs or when I switch out of OD into 3rd.
Anyway, here's my report, I'm trying to determine if the trans is eating itself. No idea what the "non-factory oil" is about, only OEM fluids have been used.
Appreciate any help.
