Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
127 registered members (25ring, 928, 2010Civic, aircooled, 53' Stude, 12 invisible), 2,805 guests, and 19 spiders.
Topics300,649
Posts5,180,181
Members70,541
Page 2 of 2 1 2
Re: Restoring headlights off the car [Re: atikovi] #5278816 11/27/19 11:54 AM
A
atikovi Online Content OP
OP Online Content
A
Yes, polishing compound is a fine last step, but you still need to sand them well first. At least the heavily worn lights.
Re: Restoring headlights off the car [Re: atikovi] #5278820 11/27/19 11:59 AM
Dave9 Offline
Originally Posted by atikovi
Sanded with the 500 and 800 discs followed by 1000 and 3000 foam pads. Looks hazy but that gives the clearcoat a better bite. Usually you would use polishing compound next as a final step but that would make it too smooth for the clearcoat to adhere well.
This is just Wrong Information.
They are supposed to be polished as clear as possible and a clear coat, while a bad idea to begin with, is only supposed to preserve that highest level of polish you can achieve.
There is no problem getting a proper clear coat to adhere, rather it just doesn't block all UV so you end up back to where you started eventually.
Clear coat is a bad idea because it's not a permanent solution. Yes it will make it take longer till you need to re-do them, but then you have to strip the clear coat off which takes many more minutes of "precious" time than just a touch-up polish occasionally.
If you don't clear coat then you can just polish them briefly every time you wash the vehicle, or every third time or whatever (depends on amount of UV exposure, where it's parked, etc, yearly can work fine if it's not parked outdoors).
Once you get them to a very high state of polish, you don't even need plastic polish to keep them that way, can use plain old toothpaste, but of course you are convinced in weird ways that this is some great ordeal that involves removing them instead of the 2 minutes it takes everyone else, so do it any way that works for you!
Re: Restoring headlights off the car [Re: atikovi] #5278826 11/27/19 12:03 PM
grampi Offline
Originally Posted by PimTac
Originally Posted by grampi
Maybe it's easier to leave them in place on the vehicle and tape them off?
This would be the simplest and easiest way to do it. Why complicate matters?
Well, I'll repeat what I said in the first post, it only takes 15 seconds each to remove these headlights vs. 15+ minutes of fiddly taping and masking them on the car and fitting towels over the engine,
But it's taken you 2 hours to figure out how to keep them from moving while being off the vehicle...
Re: Restoring headlights off the car [Re: Dave9] #5278837 11/27/19 12:11 PM
A
OP Online Content
A
Says right on the instructions, Each box contains two Clear Coat Wipes and one 3Mâ„¢ Trizactâ„¢ 3000-grit abrasive disc. Use this disc by hand, with water to lightly clean the lens surface. Wipe on the coating immediately after. The disc will create very tiny, light scratches in the lens which the coating fills in to increase adhesion and lengthen its effectiveness. But if you prefer homebrew Jethro solutions like toothpaste over the chemical engineers at at multi-billion dollar company, knock yourself out.
Re: Restoring headlights off the car [Re: atikovi] #5278940 11/27/19 02:26 PM
A
OP Online Content
A
[Linked Image from fototime.com]
Re: Restoring headlights off the car [Re: atikovi] #5278949 11/27/19 02:32 PM
T
TheLawnRanger Offline
T
2005-2012 Impala?
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Restoring headlights off the car [Re: TheLawnRanger] #5278993 11/27/19 03:28 PM
J
JustN89 Offline
J
Originally Posted by TheLawnRanger
2005-2012 Impala?
2006-2014 is the 9th generation, which is what the headlights look like they belong to.
Re: Restoring headlights off the car [Re: JustN89] #5279002 11/27/19 03:45 PM
A
OP Online Content
A
Yep, and even after doing probably a dozen pairs of lights, it never ceases to amaze me how well they look afterwards.
Re: Restoring headlights off the car [Re: atikovi] #5282893 12/02/19 12:33 PM
V
Vikas Offline
V
Are those *after* pictures? Not terribly impressed.
Re: Restoring headlights off the car [Re: Vikas] #5283044 12/02/19 02:59 PM
Malo83 Offline
Look pretty good to me. thumbsup
Re: Restoring headlights off the car [Re: Vikas] #5283046 12/02/19 03:02 PM
rooflessVW Offline
Thanks for saying it first, I didn't want to be mean.
"Zed's dead baby, Zed's dead."
Re: Restoring headlights off the car [Re: Vikas] #5284999 12/04/19 01:56 PM
A
ad244 Offline
A
+1
Re: Restoring headlights off the car [Re: rooflessVW] #5285002 12/04/19 01:58 PM
SatinSilver Offline
Same here. Although they do look a lot better than the before pics which most buyers will appreciate.
Re: Restoring headlights off the car [Re: atikovi] #5285022 12/04/19 02:18 PM
A
OP Online Content
A
Not sure what you're complaining about, they look like new in person. Picture taken with cloudy skies.
Page 2 of 2 1 2
