Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
24 registered members (ArrestMeRedZ, 19elantragt, blufeb95, ctechbob, Dallasmale1970, cadillactech), 874 guests, and 28 spiders.
Topics307,781
Posts5,317,714
Members71,917
Drafty house thermostat installations #5284761 12/04/19 10:17 AM
K
KrisZ Offline OP
K
I just replaced the thermostats in my house and noticed the downstairs one had a cold draft coming through the hole in the drywall where the wires were run.
My previous house had the exact same problem and that cold draft will cause the thermostat to cycle the furnace more often.
I sealed it up with some expanding foam and it does seem like my furnace is cycling less often now.
These thermostats were all installed on internal walls, so Iin theory there should be no drafts, but we all know the quality of "pro" work these days.
Something to keep an eye on.
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: Drafty house thermostat installations [Re: KrisZ] #5284773 12/04/19 10:32 AM
J
jbutch Offline
J
Usually on the exterior walls, there is a vapor barrier box that goes behind the electrical receptacle and needs to be taped to the vapor barrier to form one continuous barrier that would block the drafts. See below
[Linked Image from house-improvements.com]
The thing is, I've never seen a thermostat on an exterior wall and it's intriguing that you have a draft in an interior wall...
2015 Forester XT @ 104k km
Current fill: Pennzoil Euro LX 0w-30 with Fram Ultra XG7317
Re: Drafty house thermostat installations [Re: KrisZ] #5284801 12/04/19 11:08 AM
F
Fawteen Offline
F
Your drafts could be coming from a hole in either the top or sole plate where wiring or plumbing is being run. I'd check both of those and get things sealed up. Not only does it cause efficiency issues, but it's a great way for vermin to get inside the walls. If you have a slab house then it's most likely the top plate.
A can of Great Stuff and a couple hours of time would be a very good investment. While you may have sealed around the thermostat, you'll still have a cold spot on the wall.
Re: Drafty house thermostat installations [Re: KrisZ] #5284856 12/04/19 12:29 PM
H
Hall Offline
H
Originally Posted by KrisZ
....so Iin theory there should be no drafts, but we all know the quality of "pro" work these days.
As fawteen mentioned, there may be "holes" in there intentionally for different bits of infrastructure. I doubt there's anything like a giant, gaping hole from poor quality construction like you're thinking.
Re: Drafty house thermostat installations [Re: KrisZ] #5284863 12/04/19 12:34 PM
SatinSilver Offline
Single story home?
Re: Drafty house thermostat installations [Re: KrisZ] #5284880 12/04/19 12:52 PM
F
Fitter30 Offline
F
A blower door test will tell you how tight the house is. A lot of utility company's offer this test under a energy audit mine charged $50 and with the audit receives more that $50 of stuff. Light bulbs, caulking & weather stripping.
Re: Drafty house thermostat installations [Re: SatinSilver] #5284980 12/04/19 02:37 PM
PimTac Offline
Single story home?
Good point. I would check the attic space and how the insulation has been laid.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Drafty house thermostat installations [Re: KrisZ] #5285068 12/04/19 04:08 PM
K
KrisZ Offline OP
K
The house is two story and there are no drafts inside the house that I can feel at least.
The wall that the thermostat sits on is next to the stairs and under the stairs we have a pantry and all of it attaches to the garage wall.
I'm guessing the wall cavity is not insulated at all and some air from the garage enters it.
Again, I don't feel any drafts when walking barefoot etc. so it's not affecting the living space, but that hole for the wires had an effect on the thermostat.
Re: Drafty house thermostat installations [Re: KrisZ] #5285369 12/04/19 09:34 PM
E
edwardh1 Offline
E
just caulk around where the wires go into the wall?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
