Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
86 registered members (28oz, andyd, 25ring, Alfred_B, Aero540T, 9 invisible), 2,259 guests, and 61 spiders.
Topics298,368
Posts5,133,894
Members70,047
Most Online3,589
Nov 2nd, 2019
High Mileage Yukon - Oil Filter question. #5284722 12/04/19 08:19 AM
G
GMLSGUY Offline OP
G
Hey folks, I’m glad to be a part of the board! I have a 2005 GMC Yukon XL SLE with the 5.3 engine. It has 275,000 miles on it and drives like a champ. I drive it 7 days a week. It’s time for an oil change and I’ve thought about switching oil filters. I always use the standard ACDelco filter and 6qts of Mobil 1 5w30 full syn. I’ve read lots of good things about the NAPA Gold 1042 (believe it’s a rebranded WIX?). I know WIX makes awesome filters. I’ve also read up on Fram Ultra Guard being another great filter. THEN I started reading up on the longer filters. Are there any benefits to running a longer oil filter? Some people swear by it, others don’t. I believe the part number for the longer filter is 1522. Thanks for all the help! I’ll be changing the oil this evening.
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284729 12/04/19 08:31 AM
K
krismoriah72 Offline
K
You are not going to see a bit of difference in a larger filter other than adding more oil.
The Fram Ultra is 'great' because it has a smaller micron filtering ability and is more efficient. Plus its been proven to be used 2X (up to around 20K miles).
So with that being said if you are the kind of guy that changes oil and filter at less than 7500 miles just keep doing what you are doing, or you can go with a Supertech or a Fram Extra Guard.
The Wix/NAPA gold are well built filters.. but for the money do not filter as well and not as efficient as an Ultra Guard.
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284730 12/04/19 08:37 AM
dogememe Offline
ACDelco filters are fine.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~289K Miles: Unknown Oil, Filter.
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284734 12/04/19 08:41 AM
dave1251 Offline
AC Delco. Wix is what we use in our fleet vehicles and after hundreds of thousands miles used each year none have failed.
In all actuality any brand name filter will be better than needed.
don't use.
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284735 12/04/19 08:43 AM
J
JeffKeryk Online Content
Online Content
J
Congrats on the 275K. You are doing something right...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284738 12/04/19 08:49 AM
Chris142 Online Content
Online Content
I put the pf61 on our Tahoe. Only real reason I do is because it's easier to get on and off the engine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284744 12/04/19 09:00 AM
JohnnyJohnson Offline
Why would you go away from the filter that got you 275,000 miles on your 5.3? Don't fix something that isn't broken.
2004 Corolla 137331
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76862
Out: T6 5W-40 XG9100 73705
In: Rotella Dino PH9100 11-3-19
Re: High Mileage Yukon - Oil Filter question. [Re: JohnnyJohnson] #5284753 12/04/19 09:06 AM
G
GMLSGUY Offline OP
G
A good friend of mine was having some startup noise and lower oil pressure readings with the ACDelco filter and switched to a WIX and now has neither. I do not believe it’s coincidence either. I used to run Fram extra gard filters on my Jeep Cherokee with the 4.0 Inline 6 and had lots of startup valvetrain noise and lower than I’m happy with oil pressure readings. I switched to Wix and never looked back. Oil Pressure was tested before and after with a mechanical oil pressure gauge and it showed 10psi difference with a Wix than the Fram. I’m not trying to steer away, but if there’s better for the same price or maybe just a hair more then why not make the switch!?
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284765 12/04/19 09:22 AM
Z
zrxkawboy Offline
Z
Wix are excellent filters. Check with your local NAPA to see if they have a filter sale. Many have one either once or twice a year, and the prices on NAPA Gold filters are below the store’s usual cost. It’s a great opportunity to stock up.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284769 12/04/19 09:30 AM
T
Triple_Se7en Offline
T
I woud stick with the AC Delco PF46e. It's improved flow characteristics match your engine. Wix would be my 2nd choice.
Some GMs need be wary of Fram Ultras. For some have the wrong settings.
19' Hyundai Santa Fe 2.4 GDI - Valv Syn 5w30 / Napa Proselect filter / 6oz Liqui-Moly
20' Kia Soul X-Line 2.0 Multi-port / Factory-fill oil / filter
04' Colorado 3.5 / Castrol Edge 0W40 / K&N filter
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284777 12/04/19 09:38 AM
M
Mad_Hatter Offline
M
Don't "fix" what ain't broken...
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284822 12/04/19 10:31 AM
K
ka9mnx Offline
K
You have managed to go 275k miles and now you want to change because a friend had a problem? And you want to venture away from the oil filter that was spec'd for your vehicle?
BTW: Welcome!
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284896 12/04/19 12:05 PM
N
N Heat Offline
N
Ive got on 02 suburban with 277k and for a majority of its miles its seen Supertech oil and filters. If your not using a bunch of make up oil, I would stick with what got you there.
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284921 12/04/19 12:35 PM
AZjeff Offline
Does anyone think a NAPA Gold is going to blow up his Yukon? Good grief, try one if you want.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: High Mileage Yukon - Oil Filter question. [Re: GMLSGUY] #5284962 12/04/19 01:15 PM
K
kstanf150 Offline
K
Use any good filter you want and stick with the Mobil 1
It’s served you well !
