01 Burb 5.3 ~290K P0303 Bad Engine?
Napa, CA.
Recently purchased this vehicle which seemed to run and drive great. I let it sit for a couple months and now I'm driving it again and I seem to have a problem. Everything was fine but the other day I had to merge into traffic using a lot of power and it started flashing the check engine light and felt down on power.
Had a P0161 code... hmm, whatever, o2 sensor... Ignoring that one. It now does this (misfire and flashing CEL) every time I am on the highway and give it a lot of gas. Around town it's fine. Finally it did set a P0303 code. I changed the coil and it did not fix the problem. I changed the plug wire and it did not fix the problem. Finally I removed the spark plug and found this plug. it's covered in oil, wasn't even tight, and I don't even think it's the right spark plug... the part number shows it's for 2011+ GMs not 2001. odd. So I put in a cheap copper ACDelco R44LTSM and still, same issue.
The engine sounds fine except when cold with medium application of gas pedal there is a sort of squeaking ticking sound, and when it's warm under high load (but not at medium load) it does the same noise. Engine oil looks fine and I haven't had to add any oil.
My friend who works at a GM dealer looked at the picture of the plug and told me I need a new engine, probably my valve springs/lifters are toast which might have resulted in piston damage. I'm not ready to spend like $5K on replacing the engine so I would like to do some further diagnosis. I'm thinking compression test and pulling valve cover?
Any input appreciated. Thanks in advance!
[Linked Image from i.imgur.com]
I see oil on the exterior of the plug.....Valve cover gaskets.
If it's making ticking noises......Pull the valve cover & check for a broken valve spring & the Rocker Arms for dumping their Trunnion needles.
Also, Wipe the plug off & check for cracks in the porcelain!
I've seen too many engine's be deemed bad over over broken valve springs & compression testing is inconclusive at times!
If it's making ticking noises......Pull the valve cover & check for a broken valve spring & a the Rocker Arms for dumping their Trunnion needles.
Ok thanks I will pull VC when it stops raining. Safe to drive for now?
If it does have a broken spring......The keepers can come loose & the valve will fall down in the cylinder & ruin the engine for sure!
OK thanks I'll check it ASAP!
Tough to tell from your photo, but it doesn't appear that the spark plug is damaged, just oily. So I wouldn't condemn the whole engine.
I would start with a compression test.
Compression tests are inconclusive with broken valve springs.....I recently had a 2008 Ford F-250 5.4L that returned great (150psi) readings on cylinder #4 three out of five times.....One time was 90psi & the other was Zero psi.
Now the Relative Compression test via a Scan Tool caught it!......It had a broken exhaust valve spring on #4 cylinder.
You can hear a dead/low compression cylinder by cranking the engine with spark & fuel disabled, But again inconclusive with broken springs. In fact I sometimes have a hard time with this on gasoline engines where diesels are really noticeable with their high compression.
if the valve spring is broken cleanly with no bits and bobs floating around can it be changed w/out removing head?
Compression test.
Do you have an endoscope to look at pistons through the spark plug hole?
Pulling the valve cover and examine each valve stem to be tight and where it should be.
Yes sir...Requires a GOOD/Reliable source of compressed air of at least 125psi, A 14mm compression tester Whip, A good pencil magnet & a Spring compressor.
The always break clean & wind around themselves.
Sounds like what my 02 Ranger did when it plugged up it's y-pipe pre cats. Low power, flashing CEL, weird whistling noise, never set a catalyst code. Not saying that's it, but something to consider.
With LSx engines.....You will have a whole bank misfiring per the misfire monitor (P0300) & MAF (Low) signal performance DTC's if a Catalyst is clogged.
If you don't have a good compressor and the spark plug adapter for it, I have used some 1/4 inch cotton rope thru the spark plug hole and then bring the piston up with a wrench to compress the rope against the valves. Guess that may be a red neck way to do it.
If I was chasing a misfire code, I would put in the proper spark plug from the get go.
I have an 03 Suburban and one cat failed causing misfires, loading of fuel, ruined two 02 sensors, and threw a code for cam sensor. The loading of fuel and misfiring led to the other cat failing shortly after..
Both cats replaced..now all is well.
Take it to an exhaust shop and have a heat gun test on both cats. Just to rule that out
Great posts, thank you for them!
Any reason not to try installing new plugs and wires and see what happens?
Also since it sat, any chance the fuel has moisture in it or could be from bad fuel when filled up?
Trying to think of simple things first before jumping to conclusions.
That's how I have always done it... except used nylon rope (like what a recoil starter uses)
I'd pull the valve cover off and take a look.
Weak valve springs are rare, and you won't be able to tell unless you do your compression test at over 2,000 rpm's. Idle is useless for checking weak springs. However if you pull the covers, you'll be able to see a broken one.
You could also do a leak down test on the cylinder...piston at TDC of the compression stroke. If it leaks out your exhaust or intake or crankcase?? Don't bother going any further...engine is junk. Not worth replacing the heads on an engine with 290k on it, or replacing pistons.
