Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
94 registered members (alchargo, 2004tdigls, 53' Stude, 69Torino, adams355, 77GrandPrix, 6 invisible), 1,860 guests, and 16 spiders.
Topics298,825
Posts5,142,099
Members70,129
Most Online3,589
Nov 2nd, 2019
Valvoline Synpower 5w40 - Track use #5284400 12/03/19 07:51 PM
DV0993 Offline OP
Picked up quite a few bottles of Valvoline Synpower 5w40 (non-mst version).
They go on sale here sometimes; and end up being an absolute steal of a price coupled with a rebate.
Looking at migrating my daily drive, wife's car (on LPG/Propane) and my S2000 to this oil and wanted to hear thoughts?
Through the forum search I hear there a plenty of good UOAs on Synpower, but have never actually seen one myself.
I also note that apparently there is no moly in the formula. I was thinking of adding some (Half bottle of Mos2 or MoDTC) to the fill in my s2000. Any benefits?
Any thoughts on how the Synpower will hold up in my S2000 on the track?
Thanks!
Re: Valvoline Synpower 5w40 - Track use [Re: DV0993] #5284436 12/03/19 08:37 PM
Doublehaul Offline
Is this the 229.5mb version?
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Valvoline Synpower 5w40 - Track use [Re: Doublehaul] #5284452 12/03/19 09:00 PM
DV0993 Offline OP
229.3mb according to the website. I'll need to check the bottles at home. From memory I couldn't see any approvals on the bottles
Re: Valvoline Synpower 5w40 - Track use [Re: DV0993] #5287376 12/07/19 01:57 AM
A
adams355 Online Content
Online Content
A
Should be fine on the track unless you doing a heap of laps. Its very good oil, underrated in Australia along with Shell helix ultra. Interestingly, those 2 oils are the only ones I will use. I have tried most of them through a 550hp XR6 Turbo on the dyno and as a daily. I wouldn't add the moly it needs to be a precise (unknown) amount to work well with the specific oil. Try the Shell Helix Ultra 5W-40 next time it has a little moly in it.
2007 Ford XR6 Turbo (modified) - Shell Helix Ultra 5W-40 SN A3/B4 - Purolator ONE filter + ZF 6 speed - Gulf Western SYN-TS
2008 Holden Craptiva (wife's) - Castrol 5W-30 A3/B4 - Shell R next
Re: Valvoline Synpower 5w40 - Track use [Re: DV0993] #5287400 12/07/19 03:52 AM
SR5 Offline
That’s the full-SAPS 5W40 SynPower. It’s rated API SN/CF, ACEA A3/B4, MB 229.3, VW 502.00, VW 505.00, RENAULT RN710, RN700
That’s a good oil and I see no problem tracking a S2000 with it. Here is a link to the PDF <Jump>
I would skip the MoS2 add.
If you need more you can also get a SynPower 10W50 (API SN/CF, ACEA A3/B4) which is their high performance version of the oil. <10W50 link>
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Valvoline Synpower 5w40 - Track use [Re: DV0993] #5287907 12/07/19 05:21 PM
dave1251 Offline
It will be a fine lube I would skip the additives. Do you know what the sump temperature is while on the track?
don't use.
Re: Valvoline Synpower 5w40 - Track use [Re: dave1251] #5288199 12/08/19 01:02 AM
DV0993 Offline OP
Thanks everyone.
No idea what the sump/oil temp hits. I volunteer at a track down here in Melbourne Australia. Unfortunately when I head out in the S2000 for each session, I head out in a bit of the rush and the oil temp has cooled drastically. I do my best to warm her up but inevitably end up pushing it on the second lap - Hence the 5w choice.
I do exercise some mechanical sympathy, shifting early where possible etc in light of the above and squeezing in a cool down lap mid session to lower temps.
Currently using penrite racing 10w40 and have a bottle of nulon racing 5w40 ( both Group IV/V) to use prior to using my huge stash of synpower.
Re: Valvoline Synpower 5w40 - Track use [Re: DV0993] #5288202 12/08/19 01:10 AM
T
tundraotto Offline
T
You are WAY overthinking this.....DRIVE the car.
