100 registered members (Armkb, Ag76, 94astro, Anduril, 2010Civic, aquariuscsm, 6 invisible),
2,219
guests, and 54
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,365
Posts5,133,862
Members70,047
Most Online3,589 Nov 2nd, 2019
Best way to recover files from Hard Disk Drive?
#5284366
12/03/19 07:17 PM
Vern_in_IL
OP
OP
Posts: 2,316 |
I had a 2004 Gaming PC, the motherboard had defective capacitors(common at the time) They finally blew out, took out the BIOS and can't get video....
So I got a 70 Gigabyte IDE drive with Windows XP SP2, with some rare files on it.
What is the best way to get these files copied to my laptop? I got a IDE to USB converter, Can I just plug and play, copy over files, I do not think SP2/3 had encryption on the drive.
The laptop I'm using runs Windows 8, mainly audio and video files I need to copy over, very rare.
Re: Best way to recover files from Hard Disk Drive?
[Re: Vern_in_IL]
#5284372
12/03/19 07:20 PM
JC1
Posts: 4,103 |
External Hard drive case (IDE I'm assuming) and try to plug it into your PC via USB to see what you can access.
Hopefully the drive still spins when it gets power.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter 1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
[Re: Vern_in_IL]
#5284422
12/03/19 08:24 PM
Jethro_Bob
Posts: 61 |
Can I just plug and play, copy over files, Most likely yes, assuming the drive wasn't fried. Windows 8 may require you to "take ownership" of the files before copying. I can't find a link I personally feel trustworthy discussing it. But you do not need to download anything to do it. It may not even be an issue for you at all.
[Re: Vern_in_IL]
#5284469
12/03/19 09:28 PM
Donald
Posts: 23,242 |
The laptop I'm using runs Windows 8, mainly audio and video files I need to copy over, very rare. If you have the IDE to USB converter then you should be able to copy the files. I assume you are also powering the drive? Not sure USB will power it. You can run CrystalDisk Info on the drive. It will tell you the condition of the drive.
2015 Subaru Forester 2.5 engine/CVT 2015 Ford F250 w/Powerstroke 2016 Subaru Crosstrek CVT (wife's)
[Re: Vern_in_IL]
#5284473
12/03/19 09:29 PM
Donald
Posts: 23,242 |
Then develop some kind of backup strategy. Never have any file only one place.
[Re: Donald]
#5284475
12/03/19 09:31 PM
Rand
Posts: 14,204 |
This is correct, you will need to power the drive with either a dedicated power supply (they sometimes came with ide->usb adapters) or another computer.. I
2019 Jeep Cherokee Trailhawk 2.0T 2020 Hyundai Elantra "Value Edition"
[Re: Donald]
#5284666
12/04/19 07:05 AM
OVERKILL
Posts: 40,695 |
The laptop I'm using runs Windows 8, mainly audio and video files I need to copy over, very rare. If you have the IDE to USB converter then you should be able to copy the files. I assume you are also powering the drive? Not sure USB will power it. You can run CrystalDisk Info on the drive. It will tell you the condition of the drive. Yup, this. I have an old external IDE/USB DVD-RW enclosure that has what is basically a laptop power supply for it that works perfectly for this purpose. As Donald indicated, assuming the drive is OK, this should just "work".
2019 RAM 1500 Sport - Mobil 1 EP 0w-20, FRAM Ultra 2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
[Re: Vern_in_IL]
#5284710
12/04/19 07:54 AM
mk378
Posts: 2,279 |
> You can run CrystalDisk Info...
The SMART report is unlikely to work through a USB adapter. Drive would need to be connected directly to a (S)ATA port for that. That can also get you much faster data transfer but not necessary for a one-time thing.
