NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
38 registered members (Bailes1992, 2015_PSD, 77GrandPrix, Bjornviken, Astro_Guy, 4 invisible), 1,191 guests, and 16 spiders.
Topics300,377
Posts5,174,521
Members70,491
Page 3 of 3 1 2 3
Re: How Bad is This? [Re: Twisted46] #5283059 12/02/19 03:11 PM
T
Twisted46 Offline OP
T
They are Clevite
Re: How Bad is This? [Re: Twisted46] #5283834 12/03/19 10:22 AM
R
racin4ds Offline
R
You caught it in time, those bearings are wiped! and from the looks of that oil it had a lot of coolant in it....
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: How Bad is This? [Re: Twisted46] #5284279 12/03/19 06:14 PM
sdowney717 Offline
The oil analysis shows no water in the oil.
I am wondering if your oil is too thick, when its cold. Too thick and the motor not hot, the oil cant flow into the bearings, you mention racing? Is the motor warmed up good and hot before your on it.
And do you have to use a 20-50w oil in the winter? Why not use a 5w-40 oil.
Re: How Bad is This? [Re: Twisted46] #5288353 12/08/19 08:39 AM
A
A_Harman Offline
A
Originally Posted by Twisted46
So obviously there is a big problem in the motor with these levels, what do you guys think.
VR1 20-50 in a small block chevy used at the track in 20-40 minute sessions over a weekend. Oil looked like gold paint when I drained it so I sent it in for testing.
This sample came out of the oil filter, I cut it open with tin snips.
Scariest looking oil analysis I've ever seen. I was expecting to see widespread bearing damage, but was the wiped rod bearing the only one you found?
The numbers in the UOA probably are exaggerated because it was taken from the filter.
With the aluminum and tin in the sample, it may indicate cam bearing distress. How do those look?
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: How Bad is This? [Re: A_Harman] #5288847 12/08/19 07:18 PM
T
T
Yeah, when I saw those numbers expected to find catastrophic damage to the engine.
I plan to pull it over Christmas shut down and get a better evaluation done.
The plan is a full rebuild regardless.
Page 3 of 3 1 2 3
