AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
89 registered members (750IX, 67ZL1, 25ring, 53' Stude, 928, 4 invisible), 2,573 guests, and 24 spiders.
Topics300,360
Posts5,174,165
Members70,491
I think the era of the wet cell is going to be over soon #5283906 12/03/19 11:26 AM
BeerCan Offline OP
My new Porsche comes with a lithium battery. While I know other cars come with similar batteries my impression was that it was for sportier vehicles. Such as the GT4 or cars intended for some track use.
This is my first time seeing Lithium in what I consider a more standard car. I guess with all the modern car electronics needing more and more power this makes sense.
To be sure wet cell batteries will be around a long time but I think more and more cars will be switching.
I like that this is LiFePO4 chemistry. I feel it's a little safer. I hope it lasts because I am sure replacement costs are going to lead to a lot of heartburn smile
[Linked Image]
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283911 12/03/19 11:35 AM
P
PowerSurge Offline
P
Negative. Until those batteries become less expensive, FLA batteries are going to be around for a while. Plus, they don’t perform as well below 0 degrees.
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283912 12/03/19 11:35 AM
supton Online Content
Online Content
Maybe. Cars for a long time have been headed towards an era where the owners never pop the hood open, only the dealership does. And most new car owners are apt to flip the car long before any repairs (including a battery) could occur.
Hrm. A lithium battery requires quite a bit of charging finesse. I wonder if it would last much longer, and/or give a suitable warning (via the ECU) about needing to be changed in the near future. I mean, maybe it could give a heads-up as to when it wants replacing, and that is just built into a service visit.
Anyhow. The car needing more power? No, that isn't what this is for. Momentary surge, sure; but ultimately the alternator has to be able to keep up with the load. IMO this is all about weight savings.
As for wet cells, I wonder if they will be around for a while to come. I'm thinking tractors, where weight is good. Would batteries for home solar work well enough? where cost is critical. I wonder if there are other locations where weight and space is less important than cost.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283926 12/03/19 11:49 AM
BeerCan Offline OP
I see your point about the ALT being able to keep up, but what certain times when usage may spike (N/M reading comprehension issue)? Also could these lead to less powerful ALT? Serious question because I don't know what the charging profile of these batteries are.
As for the weight, I guess every pound matters but this is a pretty heavy vehicle to begin with but I guess 50lbs is 50lbs no matter how you save it.
Never thought of the temperature issue but this car is being sold in some pretty cold places. The battery is inside the cab, near the passenger feet so perhaps that helps a bit.
I know that flooded batteries will be around a long while, but I still think we are going to see these in more and more vehicles. Once they are in cars that retail below 60K will seal the deal in my mind.
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283954 12/03/19 12:21 PM
N
nthach Offline
N
Mercedes has been using Li-Ions in the AMG Black Label series of their cars. BMW has moved over to Li-Ion on some cars, I assume M-cars.
With Porsche's choice of LiFePO4 instead of Li-Ion, looks like VAG could be having Saft, BYD or Clarios make them. LG and Samsung SDI are still using cylindrical cells to make their SLI 12Vs.
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283978 12/03/19 12:49 PM
I
Impatient Offline
I
I’ve been toying around with a camper van. The more well-heeled camper crowd are already moving to LiFePO for the coach batteries. Some even go so far as to say it’s stupid to get AGM, rationalizing their $4000-$10000 battery/charge-circuitry investment. But, for example, a single 100ah Lithium battery goes for near $1000, whereas the very very best AGM’s go for under $400 (some are nearer $250...or less) and an old fashion FLA (flooded wet cell lead acid) is probably still under $200 ($100 for cheap Walmart marine-type). (The Lithium crowd will cry that’s not apples-to-apples).
I’m sure Porsche has no qualms about charging you $1000 (or perhaps way more) for a new battery, even for a “standard car” like a Cayenne 😂, but economics will delay the complete obsolescence of lead acid (at least AGM). Still, I am encouraged, that the price curves will begin to change soon, or change more quickly, but I doubt Lithium will be at parity before I have to replace my 2 house batteries. Too bad: because much lighter, potentially greater discharge potential (deeper cycle), and expected life are all great selling points for Lithium. But I got a kick out of a kid telling me his company’s LiFePO batteries had a 10 yr warranty, when I seriously doubt his camper conversion company will be in business 10 yrs from now, and I doubt there is much “real life” proof that 10 yrs is reasonable expectation in an off-road environment anyway. But maybe I just lack “vision.” I certainly wasn’t looking far enough into the future when I acquired my FLA/AGM/Gel-compatible charge controller circuits 4 yrs ago, so I’d probably have to re-invest in that stuff too. Argh.
15 Ford Transit 250 3.5EB Turbo
07 Subaru OBXT 2.5 Turbo Castrol Euro 0w30
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5283995 12/03/19 01:16 PM
sloinker Offline
You hear stories of wet cell lead acid batteries that sometimes reach 15 years of use. Rare, but not unheard of and the best cost/reward ratio IMO. Time will tell with AGM and now lithium technology. It's all about the weight with the lithium, that's why you have seen them available for racing applications for many years now.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5284015 12/03/19 01:54 PM
P
pitzel Offline
P
I know the Priuses had, at least the early ones, a conventional battery, *and* the hybrid battery. Did they finally eliminate that ridiculous-ness?
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5284050 12/03/19 02:29 PM
Snagglefoot Offline
Given all the efforts in reducing weight in vehicles, lead acid batteries get a fail. It’s about time we made some progress. Yes it will be a while for costs to come down. Remember when fuel injection was just for performance cars?
If you want the job done right......do it yourself.
Re: I think the era of the wet cell is going to be over soon [Re: BeerCan] #5284052 12/03/19 02:32 PM
Dave9 Offline
^ Quite untrue.
Flooded lead acid is the most cost effective way to make a battery with acceptable performance and lifespan.
I don't want to pay more to reinvent the wheel nor to have a more complex charge circuit, more prone to failure and more difficult to troubleshoot, as well as far more expensive to repair.
If 50lbs seems important to you, okay, but realize that it will change fuel economy by such a tiny amount that you need to be mesmerized by numbers to care. Consider a smaller vehicle (where weight savings % is higher so it makes more of a difference):
50lb / 2800lb vehicle = 1.8% weight reduction.
EPA testing finds that small vehicles average a 2.1% fuel economy increase from a 5% weight reduction, so that is only a 0.75% fuel economy increase for a small vehicle and it goes down as vehicle size increases. For a small vehicle achieving, say 30MPG, at 12K mi/yr that's (given current fuel prices) little under $8 saved per year, except that for a small vehicle, you wouldn't save as much as 50lbs but let's ignore that.
It is unlikely that a Li-Ion starter battery is going to last more than 10 years (some sources even claim a ridiculously low 2-3 year lifespan, but let's say 10yr), and let's say flooded lead acid lasts 5 since you can get them with a 5 year prorated warranty. 5 additional years at $8 per year is $40 from a battery cost perspective, but even if you count total lifespan that's only $80. If the Li-Ion battery costs more than $40/$80 more than a lead acid, you never break even. I think we can concede that it costs hundreds more for the battery and more complex charging circuit, let alone repair later.
In short, it is bad engineering to put a Li-Ion starter battery in anything that does not place weight as the most critical factor for racing performance. If you really care about modern engine emissions from 3 gallons per year of fuel, you'd make life plans to drive less than 12K mi/yr... or plant a tree, or both.
Not only do trees and other vegetation scrub CO2, they also convert solar energy into cellulose and eventually oil (if we don't find a more expedient way to extract that energy before then). It's really kind of funny that in the bigger picture, planting crops to make alcohol and 'sink CO2 is more green and sustainable than EVs. Plants necessarily 'sink all the CO2 that burning the fuel produced from them, gives off. The remaining need is obviously to get politics out of it and move forward with more efficient bio-solar cells to produce fuel.
Re: I think the era of the wet cell is going to be over soon [Re: pitzel] #5284072 12/03/19 02:48 PM
CR94 Offline
When a Prius is parked with the hybrid system shut off, the high-voltage battery is disconnected by relays on both poles, for very good safety reasons. In that circumstance, what do you suppose would operate the clock, door locks, dome light, etc., or power up the relays to reconnect the high-voltage battery if the "ridiculous-ness" of the small AGM were eliminated?
2011 Toyota Prius now at 107K
Re: I think the era of the wet cell is going to be over soon [Re: pitzel] #5284098 12/03/19 03:22 PM
A
azjake Offline
A
My Niro has a lithium battery. The neat thing about the NIRO is if that battery is run down and unable to start the vehicle there is a button you can push on the bottom left of the dash that uses the hybrid battery to jump the lithium battery.
2019 Kia Niro EX w/Premium pkg.
Re: I think the era of the wet cell is going to be over soon [Re: pitzel] #5284198 12/03/19 05:09 PM
N
nthach Offline
N
Nope - even Teslas have an auxiliary 12V battery to "boot" the electronics and aux loads. The high-voltage system is electromechanically isolated when the car is off.
Re: I think the era of the wet cell is going to be over soon [Re: pitzel] #5284269 12/03/19 06:08 PM
E
eljefino Offline
E
Still the same. In 2019 buyers have their choice of HV batteries-- Lithium (Prime) and NiMH (e-AWD). Seem to be slowly moving to Lithium, at Toyota's conservative pace.
Since the e-AWD is marketed to snowy climates, the better cold weather characteristics of the NiMH are an advantage.
My 2006 prius is running a SLA wheelchair battery on the low-voltage side vs the stupid overpriced factory 12V one.
Re: I think the era of the wet cell is going to be over soon [Re: Dave9] #5284295 12/03/19 06:25 PM
Snagglefoot Offline
Originally Posted by Dave9
^ Quite untrue.
EPA testing finds that small vehicles average a 2.1% fuel economy increase from a 5% weight reduction, so that is only a 0.75% fuel economy increase for a small vehicle and it goes down as vehicle size increases. For a small vehicle achieving, say 30MPG, at 12K mi/yr that's (given current fuel prices) little under $8 saved per year, except that for a small vehicle, you wouldn't save as much as 50lbs but let's ignore that. [quote]
$8 x 200,000,000 cars = $1.6 billion dollars. Manufacturers would scramble to lose 50 lbs of weight on a car.
