Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
93 registered members (A_User55555, 28oz, BAJA_05, andyd, 25ring, 12 invisible), 2,276 guests, and 75 spiders.
Topics298,370
Posts5,133,915
Members70,047
Most Online3,589
Nov 2nd, 2019
TPMS slow to react #5283799 12/03/19 09:37 AM
K
Kira Offline OP
K
I installed my mounted snow tires on my 2007 Volvo V70 2.4 (base) 15 days ago.
They do not have TPMS sensors.
The TPMS warning just came on my car for the first time today.
SEPARATE QUESTION:
Does anybody know how to detect which of the two frequencies a particular car's TPMS is?
When I buy new snow tires I want to include TPMS sensors.
Re: TPMS slow to react [Re: Kira] #5283821 12/03/19 10:08 AM
Snagglefoot Offline
I bought a set on Amazon for my 2008 Suburban. There were no decisions to be made about frequency, just year, make and model for mine. The shop installed them and set them up.
Fast forward to this November. I removed the summers (which also had TPMS sensors from Amazon.). The summers were then sitting in the garage but the truck still sensed them).
I then drove to a gas station that I knew had a pressure hose that could fill to 50 psi. At this point the low tire pressure light was on and there were no pressure readings available. I invoked the GM re-set procedure which on my Burb which is:
Key in the ignition, turned to on position.
Press both the lock and unlock buttons on the FOB and hold them down.
The Burb honked twice.
Go to the driver’s side front tire. Remove cap and start bleeding the tire down. After bleeding for 30 seconds the horn honked.
Do the front passenger tire. Horn honked after about 30 seconds of bleeding.
Repeat for passenger side rear then drivers side rear.
After the driver’s side rear, the horn honked twice indicating I was done. I then aired up all four tires.
Keep in mind you want to do this outside the of the TPMS sensor’s range on other set of tires. Once done the vehicle does not recognize the other set of tires. Repeat again in the spring.
Check your owners manual and search the net for your procedure.
smile
If you want the job done right......do it yourself.
Re: TPMS slow to react [Re: Kira] #5284140 12/03/19 03:54 PM
T
toneydoc Offline
T
Thank goodness that we in the deep south do not have to worry about this issue crzy
1994 Jeep 166k NextGen 10w30
2014 Camry 43k Castrol Magnatec 0w20
2018 Jeep Cherokee 6k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: TPMS slow to react [Re: Kira] #5284456 12/03/19 09:09 PM
Snagglefoot Offline
Yep, I had coffee with some old boys today. They all bought winter tires and drove them year round. They said why have two sets of tires. The tires might outlive them. laugh
