Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Subaru Forester with rusty brakes
by Donald - 12/14/19 12:55 PM
2017 Honda CRV, 1.5 Turbo, Mobil AFE 0W-30
by 06_lx - 12/14/19 11:48 AM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
60 registered members (4WD, Aichiguy, bdcardinal, 53' Stude, Blkstanger, 6 invisible), 1,206 guests, and 25 spiders.
Topics298,816
Posts5,141,823
Members70,129
Most Online3,589
Nov 2nd, 2019
2018 CRV, CVT fluid drain interval #5283774 12/03/19 09:04 AM
Schmoe Offline OP
I have researched this and looked everywhere. Does anybody know what mileage, from Honda, that you're suppose to replace the CVT fluid? Dealer said next visit, around 36K or so, the car will require a CVT fluid replacement. I disagree. The only thing I can find from Honda is when the MM shows up and tells you to. This dealership is known for hawking maintenance items that don't need to be replaced yet, plus, they want 180 dollars. Yeah, like that's going to happen. Anyway, just wonder if any one has come across the mileage requirements. I had thought around 60k, but I'm not sure where that came from.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283783 12/03/19 09:19 AM
J
JeffKeryk Offline
J
30K makes sense to me. It is an easy job. I don't wanna be a "CVT Statistic".
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283807 12/03/19 09:43 AM
M
meep Offline
M
My wife's is approaching 50k in her '15. My plan is to do it by 60k.
2018 F150
2015 crv (wifey!)
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283809 12/03/19 09:45 AM
H
henni Offline
H
We replace all our Hondas w/CVT partially (circa 4qt) at every other engine oil change. It's quick & inexpensive insurance. Similary our Hondas with DW-1, we do a partial replacement at every other engine oil change.
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283844 12/03/19 10:31 AM
T
Tjbouwhu Offline
T
I have a 2018 CRV, comes up on the MM at 30K. If you change your own oil this task is no more difficult than an oil change. Get (4) qts, end up using around 3.8 or so. [Linked Image]
I plan on doing it every 30K, remember you are exchanging like half of the fluid...not doing a total drain.
Tom
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283870 12/03/19 10:55 AM
The Critic Offline
Easy service. 4 qt of HCF-2 if it is the 2wd model, I recommend every 20K.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283885 12/03/19 11:05 AM
grampi Offline
CVT fluid is expensive...more so than ATF, which you'd think would be the same...
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5283902 12/03/19 11:24 AM
slacktide_bitog Online Content
Online Content
Honda doesn't publish any kind of maintenance schedule, only the minder. Honda relies on the MM for everything except brake fluid, which is every 3 years regardless of mileage.
The Honda Dealers worth using for service will tell you the same, to use the minder, and they explain what the codes mean. The dealers saying to do certain services every x years/miles are the ones to avoid.
Did you get a code 3 on your dash? 3 is the code for the transmission fluid. Also, you don't have to use the dealer's HCF-2. The parts stores often have Castrol CVT on sale for $5/qt. Amazon has the case of 6 for $35. Changing it is very easy on these cars, exactly the same as doing it on a regular automatic Honda smile
Re: 2018 CRV, CVT fluid drain interval [Re: slacktide_bitog] #5283928 12/03/19 11:53 AM
The Critic Offline
Honda's now indicate for brake fluid changes under subcode 7.
And yes, he needs to use HCF-2 at least while under warranty. Using a CVT fluid that is red (when CVT fluid is yellow/amber) is really smart...
smirk2
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5284019 12/03/19 01:55 PM
R
Railrust Offline
R
Honestly, I'd do a drain and fill every year...easy...cheap...good insurance. Cost you around $25 bucks. Done.
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5284043 12/03/19 02:23 PM
Schmoe Offline OP
Explains that. I'll do that myself....ain't spending that much money for the dealer to do it. I'm new to the whole CVT thing....a simple drain doesn't dump all the fluid out of the CVT like the AT's, correct? I wonder if the dealership does the drain, refill, run, drain, refill method or are they just draining and refilling.
06 Accord EX-L V6
2018 CRV EX-L
Re: 2018 CRV, CVT fluid drain interval [Re: The Critic] #5284081 12/03/19 02:54 PM
Online Content
smirk2
Cool! I didn't know about the brake fluid code thumbsup
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5284102 12/03/19 03:23 PM
dbias Offline
First off idk of any AT that dumps all the fluid out, specifically because of the torque converter.
I did the cvt on my civic around 30k and it was very easy. The civic has 45k on it now and the transmission code has never appeared.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-30
2016 HONDA CIVIC COUPE Casrol Edge 5w-30
2017 AUDI A4 Ravenol 5W-40 RUP
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5284117 12/03/19 03:41 PM
The Critic Offline
For $180 you are getting one drain and refill. A drain and refill on that CVT removes about 1/2 of the fluid, which is actually a bit more than what comes out of a normal a/t.
Re: 2018 CRV, CVT fluid drain interval [Re: Schmoe] #5284716 12/04/19 08:05 AM
Schmoe Offline OP
In that case, I'll just do it myself and buy the Honda CVT fluid. Appreciate the reply's.
06 Accord EX-L V6
2018 CRV EX-L
