Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
144 registered members (77GrandPrix, 4WD, 2010Civic, 53' Stude, 3MillerBoys, 25ring, 15 invisible), 2,550 guests, and 19 spiders.
Topics300,650
Posts5,180,201
Members70,541
Page 1 of 3 1 2 3
0-20 instead 5-30? #5283404 12/02/19 08:44 PM
W
widetrax Offline OP
W
Just bought a used truck, Nissan Frontier, and the dealer ''serviced'' it with 0-20 m.o. I thought about that,, looked in the book, and it calls for 5-30 m,o, Now with it being cold here, I really don't 'spect that will hurt anything, but I will change it to 5-30 in early spring, any thoughts on this, from anyone here?
2019 Volkswagen convertible
2018 RX 350
2010 Nissan Frontier
Re: 0-20 instead 5-30? [Re: widetrax] #5283419 12/02/19 08:51 PM
PimTac Offline
Why not go back to the dealer and let them correct it?
How cold does it get in East Mississippi?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: 0-20 instead 5-30? [Re: PimTac] #5283430 12/02/19 09:00 PM
W
widetrax Offline OP
W
Not really cod here until Jan.- Feb., 50-60 at daytime. I bought the truck in Jackson-- 75 miles away,,,, I still think the 0-20 will be fine til spring, though,,,,,,
2018 RX 350
Re: 0-20 instead 5-30? [Re: widetrax] #5283434 12/02/19 09:03 PM
JohnnyJohnson Online Content
Online Content
My 2004 Corolla specs 5w-30 and I've been running 5w-20 for the last 900 miles its doing just fine hasn't dropped off the full mark.
2004 Corolla 138491
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 0-20 instead 5-30? [Re: widetrax] #5283439 12/02/19 09:10 PM
R
rubberchicken Offline
R
I would not worry about it until springtime.
Re: 0-20 instead 5-30? [Re: widetrax] #5283464 12/02/19 09:48 PM
O
oldhp Offline
O
I would have dealer put in what's supposed to be in the engine. Any warranty on this truck? Me personally always thicker than thinner.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: 0-20 instead 5-30? [Re: widetrax] #5283467 12/02/19 09:54 PM
spasm3 Online Happy
Online Happy
I would either take it back, or drain and replace myself. To be sure, i'd do it myself.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 0-20 instead 5-30? [Re: widetrax] #5283511 12/02/19 10:47 PM
U
umungus1122 Offline
U
It will be fine.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: 0-20 instead 5-30? [Re: widetrax] #5283529 12/02/19 11:06 PM
B
burla Offline
B
I use this graph because it shows 5w30 and 0w20 viscosity in the cold.
[img]https://mirageforum.com/forum/attachment.php?attachmentid=13190&d=1543607872[/img]
Re: 0-20 instead 5-30? [Re: widetrax] #5283532 12/02/19 11:08 PM
B
burla Offline
B
At 0-C 0w20 will be visc around 375, a 5w30 will have a visc around 525. And you see the graph as far as the 5w30 will always be thicker.
Re: 0-20 instead 5-30? [Re: widetrax] #5283553 12/02/19 11:37 PM
T
The_Nuke Offline
T
\Given your geographical location, running 0w-20 in lieu of 5w-30 gains nothing, and given your particular application (nothing out of the ordinary about how the engine is operated), running 5w-30 over 0w-20 gains you notihng.
In other words, for all intents and purposes, you can consider the two oils to be effectively the same. Move onto the next problem in your life and work on resolving it; as this one is not a real problem at all.
For all those that responded with, "Take it back and make them do it right!" or some version of that, I have a serious question for you: Really? Is that what you would do? Why? It won't make one single bit of difference in how the vehicle's engine operates or how long it lives. So what's the point? To teach them a lesson? To right some perceived wrong?
I envy anyone that has the free time to waste making others redo tasks which were done without any effective problems to begin with and yet must insist on being done again just to satisfy some warped belief that the world has to be completely fair and and orderly merely because they want it to be.
Everyone has issues in their lives. Dealing with the important ones first is what matters. Despite what others might say, worrying about running 0w-20 versus 5w-30 when you drive around in the southern continental U.S. is not something to worry about.
Regards,
Nuke
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.65 (215mm)
Re: 0-20 instead 5-30? [Re: widetrax] #5283555 12/02/19 11:42 PM
MolaKule Offline
Global Moderator
Global Moderator
What year and engine displacement?
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: 0-20 instead 5-30? [Re: widetrax] #5283556 12/02/19 11:44 PM
A
Anduril Offline
A
I have the same engine in my XTerra and run 5w40 HDEO in it. I tried 5w30 recently and switched back to HDEO as it seems to make the engine run quieter at idle. I wouldn't run 5w20 in it ever, especially with the off roading and towing I do with it.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: 0-20 instead 5-30? [Re: widetrax] #5283582 12/03/19 02:02 AM
dave1251 Offline
Knowing the year and engine would help out.
don't use.
Re: 0-20 instead 5-30? [Re: widetrax] #5283606 12/03/19 04:38 AM
O
OilUzer Offline
O
Surprised they put in 0W20. Typically 0W20 is pricier than dealer's bulk 5W30.
Maybe it is just a typo.
Page 1 of 3 1 2 3
