High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Am I Evil?
by A_Harman - 12/07/19 01:58 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
No passenger tires on LT
by otis24 - 12/07/19 10:23 AM
Subaru Robin 653cc Oil coming out air breather
by Steve_NC - 12/07/19 08:17 AM
Aircraft related, what would you do with $52K?
by Exhaustgases - 12/07/19 05:43 AM
Chevy Suburban on Hollywood walk of fame
by GMguy84 - 12/07/19 05:25 AM
Mills Fleet Farm Havoline & Rotella Sale with Rebate
by Nitronoise - 12/06/19 11:44 PM
85w90 vs 75w90
by Rohan - 12/06/19 11:24 PM
Milwaukee Ratchet & Impact wrench $200
by Deere John - 12/06/19 11:17 PM
Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FRAM ULTRA XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
Michelin Defender on Civic
by jharrison - 12/06/19 08:14 PM
MxTale, icemanrrc, Cobby, nzeroesc, Steve_NC
70059 Registered Users
96 registered members (andyd, 4WD, 69 Riv GS, 94astro, alarmguy, alchargo, 8 invisible), 2,733 guests, and 66 spiders.
Topics298,406
Posts5,134,826
Members70,059
Most Online3,589
Nov 2nd, 2019
Is valve lash adjustment included with piston r&r? #5283401 12/02/19 08:40 PM
L
ljbrandt Offline OP
L
My 2011 MDX has been approved by Acura for a warranty repair to remedy excessive oil consumption. The repair includes replacing all six pistons and rings.
Question is, would this procedure necessitate a valve adjustment when reassembling the head? Wanting to know before the dealer tries to double dip by selling me the "additional" service.
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283408 12/02/19 08:45 PM
ctechbob Online Content
Online Content
Hard to say. You'd have to ask them, but I doubt it.
Pretty good job getting them to cover something that far out of warranty.
2008 Acura TL Type S-155k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283452 12/02/19 09:36 PM
U
UncleDave Online Content
Online Content
U
Why would the heads come apart?
Off - yes, apart no.
Pistons and rings are the bottom end and heads are the top end.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283469 12/02/19 09:55 PM
O
oldhp Offline
O
Heads have to come off to remove the pistons. Different head gasket thickness will make readjusting the valves a for sure at no extra charge. The only way this would not be right is if the engine is a overhead valve type. Then the heads would just be remove and replace with new head gaskets. Depending on the miles and what your going to do with it (keep or sell it) maybe a valve job too, but that's up to you.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283494 12/02/19 10:27 PM
V
vw7674 Offline
V
those look like screw-type adjusters, & Honda usually calls for clearance check at every 17,500 miles on non-hydraulic camshafts.
If it were mine, I suppose head re-install time would also be clearance check time before the covers go back on......but it isn't 'required'.
Just a while-you-are-there type of service. YMMV.
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283559 12/02/19 11:51 PM
B
berniedd Offline
B
A new head gasket (and therefore valve lash check/adjust) is mandatory after the piston and ring work because the standard way is to access the pistons from above after the head is removed. One does not reuse the old head gasket.
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283577 12/03/19 01:28 AM
K
KneeGrinder Offline
K
Well, some don't know how dealer mechanics operate. If you don't have the cam or any rockers in the way of removing the head bolts, the mechanic will set the cams to T.D.C. and remove the heads. Won't ever touch the valves unless he got paid flag time to adjust valves, or there is a ticker. Valves should be adjusted, and new timing belt too if its anywhere past 60/70k on timing belt.
08 Tribeca 90k PUP 5w30
06 Accord 137k PP 0w20
03 Acura CL-S 90k M1 AP 5W20
02 Acura TL-S 241k ST 5W30
02 Accord EX 155k PP 0W20
02 K3500 99k M 1 ESP 5w40
00 F350 139k M 1300 15w40
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283636 12/03/19 05:52 AM
T
Tman220 Offline
T
Not a mechanic, but some of you must think they are some sort of charity, or like doing work they wont be paid for? If the head just needs to come off, then tossed back on, there is no way those valves will be adjusted unless its in the work order and they are paid their deserved shop time to do it. If rockers need to be removed to get to a couple head bolts, then those are probably the only ones that will be adjusted.
additionally, being an overhead cam engine, head gaskets or otherwise R&R'ing the head will in no way affect the lash adjustments
Mechanics aren't like a DIY'er that thinks like... huh, while im in there I might as well as take care of this, this, and this... If mechanics did that they would find themselves working 50 hours a week and only getting paid for 35, and quickly out of a job, not sure how many of you would be ok with that?
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 160k
2004 Civic LX M5 178k
2007 Camry 2.4 232k
2016 Victory Vegas
Re: Is valve lash adjustment included with piston r&r? [Re: Tman220] #5283679 12/03/19 07:33 AM
R
ragtoplvr Offline
R
This.
On the other hand, if the book says 3 hours to adjust valves and replace timing belt, but with everything already exposed by the piston and valve job, it will take 1 hour additional, it is not fair to charge for the entire 3 hours, but most all of the mechanics do.
I see the mechanics point, they often have to repair a broken stuck bolt and flat rate does not pay for that either. But this was not MY broken stuck bolt. The system is not ideal.
Rod
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5283741 12/03/19 08:37 AM
U
Online Content
U
The op can expect to have ONLY the warranted parts replaced and nothing will be touched that isnt a part of that- and he is getting an awesome deal at that.
Once that engine is open that is the time for him to update anything else - new timing belt water pump valve adjustment plugs etcetera.
With any kind of good relationship the dealer will give him a smoking deal on all that and he can drive away with as fresh an engine as can be had.
If he and the dealer "had at it" up until this point maybe the deal won't be so great.
UD
Uncle Dave
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5284138 12/03/19 03:53 PM
The Critic Offline
https://static.nhtsa.gov/odi/tsbs/2019/MC-10153886-0001.pdf
Valve Adjustment is mentioned under the procedure list, but whether it'll be followed is anyone's guess.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5284420 12/03/19 08:21 PM
L
ljbrandt Offline OP
L
Thanks to all for the info. From the responses, it seems as though the answer is: the valve adjustment should be done, but probably won't be (unless paid for).
The link "the Critic" posted doesn't mention anything explicitly about adjusting the valves.
With over 200k on the engine, I guess I can't complain.
Re: Is valve lash adjustment included with piston r&r? [Re: ljbrandt] #5284498 12/03/19 10:10 PM
A
andyd Online Content
Online Content
A
OHC? solid lifters? With a a head R+R, the valve lash should be checked. grin2
Thick oil is better grin2
