Topics298,471
Posts5,136,092
Members70,070
Most Online3,589 Nov 2nd, 2019
When to replace a battery?
#5283376
12/02/19 08:14 PM
Chris142
OP
OP
Posts: 19,888 |
I went and had a complete charging system test done on my Jeep. It's all working as it should. The tester showed that my battery was fully charged but only had 80% of its rated capacity.
At what percentage of capacity loss should a battery be replaced?
02 Wrangler Napa high milage 10w40 87 F250 Valvoline 15w40 07 fjcruiser Car lube plus 10w30 Z400 castrol T 10w40 Can am Maveric edge 5w40 57 case tractor Chevron sae30
Re: When to replace a battery?
[Re: Chris142]
#5283384
12/02/19 08:24 PM
KGMtech
Posts: 1,332 |
This is not a technical answer, but I shop for a replacement battery before I need one. I think anything over 5-6 years is asking for trouble, besides, if you stretch the old battery too far it will put extra strain on your charging system.
2017.5 Nissan Rogue SV FWD 2013 Nissan Maxima SV 2009 Ford Flex SEL FWD 1984 Yamaha XJ750RL
[Re: Chris142]
#5283386
12/02/19 08:24 PM
JeffKeryk
Posts: 2,650 |
I kinda go by time. After 5 years, I keep an eye out for drag... The factory battery in my old 93 Toyota 4WD 22RE lasted more than 10 years.
If you see signs of trouble, I would replace it to avoid getting stuck. Especially if it was wifey's car.
2018 Tesla Model 3, Medium Range Battery 2018 Lexus RX450h 2013 Lexus GS350 F Sport 2006 Acura TSX 2001 Tundra Access Cab, 1998 Accord LX, 1968 Corvette L36 Roadster, 1965 Olds 4-4-2
[Re: JeffKeryk]
#5283394
12/02/19 08:35 PM
bbhero
Posts: 7,195 |
Agree 100 percent ^^^^^^
Especially the lady's car part has well.
Nissan Altima 3.5 Coupe Napa full synthetic 5w30 Wix 57356 Oil filter "Treat your family like your friends and treat your friends like your family."
[Re: Chris142]
#5283399
12/02/19 08:37 PM
Chris142
OP
OP
Posts: 19,888 |
It's 3 years old and in my Jeep.
[Re: JeffKeryk]
#5283416
12/02/19 08:50 PM
Wolf359
Posts: 7,577 |
If you see signs of trouble, I would replace it to avoid getting stuck. Especially if it was wifey's car. Well I've got a 12 year old AGM battery. I check the voltage, it's been about the same as last year. Could have gotten a Champion battery on Black Friday at Pepboys, I guess I'll wait another year or so...
[Re: Chris142]
#5283425
12/02/19 08:57 PM
69GTX
Posts: 4,345 |
I went 3 yrs on a battery similar to yours....total of 6 yrs. At the 3 yr point it had fluid level well below the cell tops and lots of sulfation. Was lucky to bring it back with a lot of charging. 6 yrs total was fine with me. I replaced it once it acted up again. I'm sure the capacity was never near 100% after is run down so low. You need enough capacity to start the car in cold weather. California is pretty temperate. But then again, batteries tend not to last near as long in hot desert climates.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2 1999 Camaro SS M6 /19K /Mobil 1 0w40 /Fram UG /GM MTL-ATF 1969 Ply GTX/RRs
[Re: Chris142]
#5283437
12/02/19 09:09 PM
rubberchicken
Posts: 1,229 |
Optima Red Top battery in my 1997 Suburban 2500. Manufactured in 2004, still running strong.
[Re: Wolf359]
#5283444
12/02/19 09:15 PM
bbhero
Posts: 7,195 |
That vehicle has that battery in the trunk too....
Extremely helpful to battery lasting a long, long time. Vs having the battery in the motor compartment with all that heat exposure.
[Re: Chris142]
#5283446
12/02/19 09:17 PM
bbhero
Posts: 7,195 |
At what percentage of capacity loss should a battery be replaced? I believe that if it drops below 70% of rated capacity then it's time to replace the battery... Maybe as low as 60 percent...
[Re: Chris142]
#5283450
12/02/19 09:29 PM
volk06
Posts: 4,993 |
My 2011 F150 still has the factory battery and is going strong. Just tested it this weekend, read 12.4v and 800 cranking amps when it was tested.
Wish I could find a aftermarket battery as reliable as that.
[Re: Chris142]
#5283454
12/02/19 09:38 PM
bilibako2
Posts: 44 |
I replaced our car's battery every 4 years.Costco battery most of the time.
bentoti/1999
[Re: Chris142]
#5283459
12/02/19 09:41 PM
Fawteen
Posts: 544 |
I go 4-5 years on a battery and replace it. I've never had one fail, never needed a set of jumper cables, and it has never left either me or my wife stranded.
[Re: Chris142]
#5283463
12/02/19 09:47 PM
2010Civic
Posts: 564 |
I replace the battery when I notice it getting sluggish.
2010 Honda Civic LX Valvoline SynPower 5w-20 - Napa Gold oil filter 59,992 miles
[Re: Chris142]
#5283472
12/02/19 10:06 PM
Donald
Posts: 23,245 |
At what percentage of capacity loss should a battery be replaced? At 80% you are fine. You are not in Maine where the temps get really low and battery capacity is reduced. At 60% I would start to think. At 50% I would definitely get a new one.
2015 Subaru Forester 2.5 engine/CVT 2015 Ford F250 w/Powerstroke 2016 Subaru Crosstrek CVT (wife's)
