Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
50 registered members (Bailes1992, Anduril, another Todd, Astro14, asiancivicmaniac, AC1DD, 3 invisible), 1,326 guests, and 47 spiders.
Topics300,374
Posts5,174,472
Members70,491
Dexron 6 to Honda Z-1 #5283238 12/02/19 06:03 PM
K
Kbuskill Offline OP
K
I know this may be a strange question but here goes...
I have a 2008 Honda Civic with an automatic transmission in it. Honda calls for Z-1 transmission fluid.
Z-1 has been superceded by DW-1 fluid.
I was looking at Rock Auto's website and they show Dexron 6 as being compatible with my Civic.
I also saw where RA sells a friction modifier (ATP brand AT-203) which supposedly makes "any conventional" Dexron fluid, such as Dex 3, compatible with the Z-1 fluid.
The main reason I am asking all of this is because I also have a 2008 Suburban and I have about a case of Dex 6 left over from the transmission service I did on it.
So if the full synthetic Dex 6 will work as a replacement for the Z-1/DW-1 then I would much rather use it instead since it is synthetic.
If I chose to use it do you think the friction modifier would be necessary.
Any help would be appreciated.
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283267 12/02/19 06:34 PM
G
Gebo Offline
G
My opinion is to only use the transmission fluid the maker recommends. I'm not a Honda guy but please check with the dealership to make sure the DW-1 is correct.
Save the Dex 6 for future drain and fills for the Suburban about 30K from the transmission service.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283277 12/02/19 06:41 PM
B
Brian123 Offline
B
Is ATF z1 the same as ATF dw1?
Answer: aft-dw1 is the replacement for atf-z1. If your honda specifies atf-z1 you can use atf- dw1. Both fluids are compatible with each other.
I would go with the dw1 and forget about using the Dexron 6
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283284 12/02/19 06:49 PM
slacktide_bitog Offline
Use something that claims DW1 or Z1, such as Maxlife or Castrol Full Synthetic ATF smile
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283293 12/02/19 06:57 PM
A
atikovi Offline
A
I once accidentally changed the fluid in a Honda transmission with Dexron 6 and it ran just fine for the next 1,000 miles I had it. Ideally you use what the manufacturer specifies but on a 12 year old Civic you don't have much to lose and chances are you will be fine. The differences in fluid specs between manufacturers isn't all that huge, hence the multi-make fluids.
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283315 12/02/19 07:17 PM
K
Kbuskill Offline OP
K
I was hoping I could find the specifications for the Dex 6 and the Z-1/DW-1 fluids so that I could compare them but I don't have a clue as to where to even begin looking.
That is why I posted here, because I was hoping someone could point me in the right direction with actual fluid specs and not just opinion.
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283344 12/02/19 07:43 PM
Chester11 Offline
Interesting find on the friction modifier.
There is something in Z-1/DW-1 that changes the shift feel. I tried Maxlife in an 09 Honda using Z-1 and was really not happy with the result.
Maybe give it a whirl without the friction modifier and see what happens. If it stinks, order the modifier and add it?
The only downside is that if you hate it - you have to cycle through a ton of fluid to replace it all.
Having been there, the money saved was not worth the squeeze in the end.
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283351 12/02/19 07:48 PM
O
Oro_O Offline
O
I am going through this now as I have a slightly older Civic than yours, built for DW-1. Z-1 is the low-viscosity fluid Honda issued paralled to GM' DexIII/DexVI change and Toyota's T-IV/WS changeover.
A lot of research here and on Honda forums show most people happily substitute MaxLife for DW-1 (or Z-1) with long years of success. However, MaxLife is also a low-viscosity fluid like the newer generation (DexVI, etc). Personally, based on a lot of forum research but no personal experience yet, I am gong to use MaxLife instead of Z-1, and some Lubegard Red for seal conditioning and heat management (it does both).
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283355 12/02/19 07:50 PM
Mr Nice Offline
I would use Honda ATF only.... but lots of people say MaxLife works great.
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283392 12/02/19 08:34 PM
J
JeffKeryk Offline
J
I like this:
Idemitsu Honda Equivalent
Maxlife is $17 for 4 quarts, this is more than that.
But good stuff.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283407 12/02/19 08:45 PM
K
Kbuskill Offline OP
K
Sorry for the noob question but is there a " like " button on this forum?
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283424 12/02/19 08:57 PM
P
pitzel Offline
P
I buy branded Honda DW-1 for significantly less from the dealer than I can find any licensed Dex VI around here. I wonder if the opposite is true, if full synth DW-1 fluid can be substituted for Dex VI in vehicles that call for it.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Dexron 6 to Honda Z-1 [Re: JeffKeryk] #5283466 12/02/19 09:52 PM
O
Oro_O Offline
O
Originally Posted by JeffKeryk
I like this:
But good stuff.
I have always had a favorable view of Idemitsu products ( havesome in a TLS flavor in a lexus right now). BUT: Molakule did a VOA on genuine Honda fluid vs. the Idemitsu honda and the add packs were NOTHING alike. It's not a "clone" fluid like people were thinking.
Re: Dexron 6 to Honda Z-1 [Re: Oro_O] #5283476 12/02/19 10:10 PM
J
JeffKeryk Offline
J
I like this:
But good stuff.
I find it to be better than DW-1, which is why I use it.
Pulls better. Perfect shifts.
2018 Lexus RX450h
2006 Acura TSX
Re: Dexron 6 to Honda Z-1 [Re: Kbuskill] #5283546 12/02/19 11:21 PM
ctechbob Online Content
Online Content
I won't copy paste from the thread, but you can read the discussion here:
https://www.bobistheoilguy.com/foru...71227/re-three-atfs-analyzed#Post5271227
Here is my opinion, it's worth exactly as much as you're paying for it.
Yes the Idemitsu/Aisin/Maxlife fluids do not have the same analysis as Z1/DW1. If you want a clone of DW1, it doesn't exist, buy DW1.
It is my belief that just like motor oil, gear oil, coolant, etc, there is more than one way to get the job done. We have been told by Idemitsu that their H+ fluid has all the proper characteristics to work properly in place of DW1. How they do that and don't have matching chemistry, they haven't said. I don't particularly believe that with all the smart fluid engineers out there that whoever came up with the DW1 formulation had the golden key back in the mid 2000's as to the only way to make a fluid with those performance specs. It's been at least 10 years since DW1 came to market, I'm sure there's more than one way to skin that cat.
I also have spoken with the shop that did the rebuild for my wife's transmission in her now dead 2000 as to what fluid they recommend, a shop that rebuilds and ships Honda transmissions all over the US and has a great reputation. They use a 'multi-use' fluid in all of their rebuilds (Similar to Maxlife I expect, I have since forgotten the label on the drum at the shop), including the BAYA/MAYA 'fragile' V6 transmissions from the early 2000's. His opinion is that clean fluid is much more important than using DW1 exactly.
Me personally? I have switched over to the Idemitsu fluid because it can be had in a 5qt jug which I find more convenient than quarts. It has done everything I expect it to in my J-Series cars (And was working fine in the wife's rebuild until it got plowed by a cargo van and totalled).
As for Dex6, can't speak to it. Never considered using it in a Honda trans, although I'd be inclined to leave it to the GM stuff and pick up something that at least carries a 'suitable for' label. (Maxlife/Castrol/H+/Aisin/DW1).
That ATP stuff.....ehh, try it if you want, I'm a little leery about it and think I'll just stick with a regular fluid.
Not that we're discussing it here, but I certainly wouldn't ever go the other way and use DW1 in anything other than a Honda/Acura(and that one Saturn) transmission.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
