Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
94 registered members (40Deluxe, alarmguy, alchargo, 14Accent, Ag76, 6 invisible), 1,803 guests, and 17 spiders.
Topics298,824
Posts5,142,067
Members70,129
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
parking brake use #5283335 12/02/19 07:34 PM
M
mobilaltima Offline OP
M
Ive decided to start using my parking brake more often when parking my truck. Ive read that its beneficial to the parking pawl in the tranny. When using it in the past, Ive always put it in park and then applied the brake.
To my understanding the correct way to apply the parking brake is to leave the vehicle in drive with your foot on the regular brake, apply the parking brake and then put the vehicle in park.
To let off the parking brake, I understand its the opposite, I would put the tranny in drive or reverse first and then pull the parking brake lever? Is this correct?
Might sound like some dumb questions but I never gave it much thought and if its beneficial for the parking pawl Ill do it every time I park.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: parking brake use [Re: mobilaltima] #5283356 12/02/19 07:50 PM
skyactiv Online Content
Online Content
You plan on moving to San Francisco where this would matter?
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: parking brake use [Re: mobilaltima] #5283358 12/02/19 07:51 PM
bdcardinal Offline
When I drive an automatic transmission equipped car I put the transmission in neutral with my foot on the brake pedal. Then I apply the parking brake, and take my foot off the brake pedal to make sure the parking brake catches. Then I put my foot back on the pedal and put the vehicle in park.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: parking brake use [Re: mobilaltima] #5283360 12/02/19 07:53 PM
Online Content
Right foot on brake, left foot on parking brake or pull the handle or toggle the electronic switch and put the vehicle in park or 1st gear if it's a stick.
Re: parking brake use [Re: mobilaltima] #5283361 12/02/19 07:56 PM
B
bullwinkle Offline
B
I'll usually use the parking/e-brake on hills, slopes, or when loading/unloading a trailer or rolling something up ramps into the back of the van/truck. The only way to keep the load off the parking pawl is to set the brake before you put it in park (& make sure it holds like bdcardinal said above). If I'm on a flat surface, I don't think it makes much of a difference.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: parking brake use [Re: mobilaltima] #5283365 12/02/19 08:02 PM
Dinoburner Offline
An old mechanic told me to always set the parking brake then put the trans in park especially when parking on a hill to take some stress off the parking pawl. Also it makes easier to release the pawl without the weight of the vehicle on it.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: parking brake use [Re: mobilaltima] #5283368 12/02/19 08:03 PM
Shannow Offline
I always use it, all the time, both auto and manual.
Saw a Rambler Matador where the pawl failed once.
If it's the truth....it can handle the pressure !!!
Re: parking brake use [Re: mobilaltima] #5283371 12/02/19 08:09 PM
R
red7404 Offline
R
many years ago i worked at a trencher manufacture, in the prototype shop. we learned that there is a difference between an emergency brake and a parking brake. an good emergency brake will stop a rolling machine. a parking brake will not not stop a rolling machine. but will hold it after stopping. history note. the old Hudsons after the reg brake peddle went to far it started applying the emergency brake.
Re: parking brake use [Re: mobilaltima] #5283372 12/02/19 08:11 PM
P
PandaBear Offline
P
I always hold my right foot on the brake, park in P (automatic), apply parking brake, let go my right foot, and make sure the car is not moving, then turn off the engine.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: parking brake use [Re: bdcardinal] #5283388 12/02/19 08:28 PM
Cdn17Sport6MT Offline
100%. I believe you need to ensure the vehicle (if it wants to) moves a bit before you engage park. Then to move off again you take it out of Park and place it into N before disengaging the parking brake. Save those Park pawls and don't "hang" your vehicles in Park due to the parking pawl engagement!
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: parking brake use [Re: mobilaltima] #5283455 12/02/19 09:39 PM
F
Fawteen Offline
F
Don't overthink it. It's a parking brake. Park, set the brake, and don't fuss over it.
Re: parking brake use [Re: bdcardinal] #5283461 12/02/19 09:43 PM
CharlieBauer Offline
Ditto.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: parking brake use [Re: bdcardinal] #5283502 12/02/19 10:34 PM
A
AC1DD Offline
A
This.
I've noticed on most of my automatic cars that putting the parking brake on after shifting into neutral and then into Park seems to be the right choice to keep stress off the
pawl.
Re: parking brake use [Re: AC1DD] #5283569 12/03/19 12:22 AM
CR94 Offline
Originally Posted by AC1DD
... putting the parking brake on after shifting into neutral and then into Park seems to be the right choice to keep stress off the pawl.
That routine makes sense when parking on a significant hill. Elsewhere, you'd wear out the brake mechanism long before the parking pawl.
2011 Toyota Prius now at 107K
Re: parking brake use [Re: bdcardinal] #5283590 12/03/19 03:08 AM
demarpaint Offline
thumbsup That is how you are supposed to use the parking brake.
God Bless Our Troops
Page 1 of 3 1 2 3
