Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
119 registered members (28oz, andyd, A_User55555, Bebop367, BAJA_05, 16 invisible), 2,316 guests, and 71 spiders.
Topics298,370
Posts5,133,922
Members70,047
Most Online3,589
Nov 2nd, 2019
Diesel (Passenger Vehicles) in Hot Climates #5283250 12/02/19 06:20 PM
A
ad244 Offline OP
A
Hey all
Just wanted to see if any other members seem to notice a trend in modern diesel passenger vehicles (Cars and trucks) where they and their emission systems seem to hold up better in hotter climates such as the south west?
Because modern diesels heat to burn off catalysts and get up to temp quicker, would this in theory make them last longer?
Re: Diesel (Passenger Vehicles) in Hot Climates [Re: ad244] #5283269 12/02/19 06:35 PM
M
maxdustington Offline
M
I would think the exhaust getting super hot while getting sprayed with salt water in the winter and then humid environments in the summer would shorten it's lifespan considerably.
99 Toyota Tercel CE 5EFE/C151
Re: Diesel (Passenger Vehicles) in Hot Climates [Re: ad244] #5283631 12/03/19 05:38 AM
dnewton3 Offline
Global Moderator
Global Moderator
Everything holds up better in the arid southwest ... mechanically, but not cosmetically. The UV will beat the tar out of paint and vinyl and rubber, but the southwest is very easy on drive-train systems, gas or diesel.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Diesel (Passenger Vehicles) in Hot Climates [Re: ad244] #5283651 12/03/19 06:26 AM
B
BMWTurboDzl Offline
B
Not really. If anything the plastic components will lose their plasticity at a higher rate in hot/dry climates. Most of the components for the SCR (DEF aka Urea Solution) system are plastic/rubber.
If anything I would think that driving distances are generally longer in the SouthWest so that would bode well for allowing uninterrupted DPF regens.
435i
Re: Diesel (Passenger Vehicles) in Hot Climates [Re: ad244] #5284712 12/04/19 08:03 AM
B
BrianF Offline
B
The cold climate, long idle times and short trips seem to be rough on diesels here. The newer scr equipped ones fair out better...
I have done a mix of everything with my 3500 and the only issues were a DEF countdown that cleared itself while driving and my recent cylinder 1 injector (unrelated but still a mechanical problem).
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
