What Are The Gun Laws Like In Canada?
by BlueOvalFitter - 01/17/20 10:27 AM
OEM F150 battery finally giving up after 9 years
by volk06 - 01/17/20 10:05 AM
My 2013 Honda Fit Undercarriage after
by TDOHGL01 - 01/17/20 09:08 AM
Oil that won't clog the catalytic converter?
by Underdawg - 01/17/20 08:46 AM
Rear Struts Recommendations
by willbur - 01/17/20 07:46 AM
Critical Windows 10 Update
by doitmyself - 01/17/20 07:38 AM
Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
116 registered members (750IX, 330indy, Alfred_B, 2011335d, 16 invisible), 2,250 guests, and 24 spiders.
Topics300,225
Posts5,171,258
Members70,452
Most Online3,728
Jan 11th, 2020
Ariens 36" snowblower #5283143 12/02/19 04:26 PM
Donald Offline OP
Well my snowblower let me down. Engine runs fine but the shift will not move out of 4th. Not to 5th or N or R. The machine would go forward and blow snow but at times was making a banging metal sound. Worked fine last spring. Belts are pretty new.
I tried to use it but it took too much energy to hold it back and down. It needs to be in 1st or 2nd to do this snow.
I do have a newer Craftsman 24" but that's for another day.
Ideas?
2015 Ford F-250 w/Powerstroke
Re: Ariens 36" snowblower [Re: Donald] #5283171 12/02/19 04:55 PM
K
Kamele0N Offline
K
Check its friction disc & its settings...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Ariens 36" snowblower [Re: Donald] #5283176 12/02/19 04:59 PM
supton Online Content
Online Content
I'd put it in the garage and pull it apart. Maybe it's something simple. I'm assuming it's a friction disc, which would indicate to me that it's a stuck linkage. If it was something with real gears, the banging would have me worried...
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Ariens 36" snowblower [Re: Donald] #5283179 12/02/19 05:01 PM
M
MasterSolenoid Offline
M
Check the Owners Manual for points to lubricate.
Maybe something is just hung up and needs oil or adjustment.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Ariens 36" snowblower [Re: Donald] #5283233 12/02/19 06:00 PM
Danno Offline
Raise it up vertically from the rear, and place it on the auger. Helps if you have less than half a tank of gas. The curved plate on the bottom covers the mechanism for shifting. Take the cover off, and you should be able to trouble shoot. Its a remarkably simple yet effective mechanism.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Ariens 36" snowblower [Re: Donald] #5283235 12/02/19 06:02 PM
B
benjy Offline
B
this a great forum but snowblower specific ones are better, especially those related to your model + brand.
Re: Ariens 36" snowblower [Re: Donald] #5283292 12/02/19 06:57 PM
B
BISCUT Offline
B
Mine is 5 years old. As stated by many, friction disc. These new Ariens aren't your daddys!
I've been very lucky in life with most machines but my Ariens has been rough. Leaking seal on the gear box; leaking carb; and somehow the auger axle is pulling (on right side only) away from the frame. Last one was a JD 328D that was 15 years and solid til it tanked. Grandfathers Ariens was like 17 years and kicking with like zero maintenance for 8 years or so.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(40k)
2017 Sub OB M1 5-30 EP FRAM Ultra(70k)
Re: Ariens 36" snowblower [Re: Donald] #5283337 12/02/19 07:35 PM
Donald Offline OP
This one is probably 15 years old. Engine is solid but not OHV.
Re: Ariens 36" snowblower [Re: Donald] #5283349 12/02/19 07:47 PM
A
andyd Offline
A
My guess is it is bound up linkage. grin2
Thick oil is better grin2
Re: Ariens 36" snowblower [Re: Donald] #5283468 12/02/19 09:55 PM
I
iahawk Offline
I
Look up Donyboy73 vids on youtube, he has a lot of stuff on snowblowers. Could be the rubber drive disc binding up on it’s shaft. As others said, put the blower in the service position and take off the belly pan. The issue should be easily identifiable.
Re: Ariens 36" snowblower [Re: Donald] #5283890 12/03/19 11:12 AM
J
JTK Offline
J
Like said above. First drain the fuel out of the tank so it doesn't drip everywhere and some may require draining the engine oil so that doesn't go everywhere, THEN tip the machine into the service position. Business end flat to the ground. Pull the belly pan and investigate.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Ariens 36" snowblower [Re: Donald] #5283999 12/03/19 01:24 PM
J
jeepman3071 Online Content
Online Content
J
What model?
Usually on these the axle that the friction disk slides back and forth on gets gummed up. Clean it real well and spray some silicone spray on the shaft.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Ariens 36" snowblower [Re: jeepman3071] #5284275 12/03/19 06:11 PM
Donald Offline OP
Originally Posted by jeepman3071
What model?
I think it's a ST1136. Older than I thought. Back to early 1980s.
Apparently the "ST" machines were built like a tank.
Re: Ariens 36" snowblower [Re: Donald] #5284660 12/04/19 06:59 AM
J
Online Content
J
What model?
Yeah definitely put it up on it's front and pull the bottom cover. You should be able to see what's going on with it. I actually had an Ariens 724 in last week that wouldn't go into reverse, and when I pulled the cover it was packed full of mouse nests.
Re: Ariens 36" snowblower [Re: Donald] #5284859 12/04/19 11:29 AM
Donald Offline OP
The belt for the snow auger started to shred and some got stuck and jammed the drive mechanism. Now to determine why that belt started to shred. It was only 1 year old.
