Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
131 registered members (928, aircooled, 53' Stude, 2010Civic, ABerns, 12 invisible), 2,894 guests, and 18 spiders.
Topics300,649
Posts5,180,181
Members70,541
Page 1 of 3 1 2 3
sprinter oil change - not low SAP #5282350 12/01/19 07:57 PM
A
angryorc Offline OP
A
Hi guys, i have a sprinter 310, 2.2 cdi, year 2009, i decided to change an oil, previous owner used 10w40 and decided to continue using that one, i filled WAVE POWER SL 10W-40, then i read that this oil is not suitable for vehicles with DPF and now i dont know what to do, should i change it or leave it, if change what do you recommend?
Re: sprinter oil change - not low SAP [Re: angryorc] #5282364 12/01/19 08:17 PM
2
2004tdigls Offline
2
personally I would drain it immediately, that is a high ash oil only diesel rated for CF
https://www.northsealubricants.com/en/products/wave-power-sl-10w40
you need a low ash oil to protect the dpf from plugging
Re: sprinter oil change - not low SAP [Re: angryorc] #5282530 12/02/19 01:22 AM
I
Impatient Offline
I
Mercedes has specs for different oils: examples are 228.3, 229.3, 229.5, 229.51 etc. The link 2004tdigls sent you for the WavePower shows it meets 229.1. Most euro oil bottle labels will show what Mercedes spec the oil meets.
Try this: https://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
This may not be the right table, but something like this is what you need to consult. Hopefully you can find your engine in all this. You may need to find a version of this table dated 7-8 years ago. There is no guarantee an engine similar to yours produced today takes the same oil as a 2009 version.
15 Ford Transit 250 3.5EB Turbo
07 Subaru OBXT 2.5 Turbo Castrol Euro 0w30
Re: sprinter oil change - not low SAP [Re: angryorc] #5282711 12/02/19 09:12 AM
E
edyvw Offline
E
Anything MB229.51 or 229.52.
By the way, which Georgia? Georgia country or Georgia state? Give us more accurate location and maybe we can help with specific oils.
11' BMW 328i xDrive 6MT (BMW TPT 5W30+OE filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: sprinter oil change - not low SAP [Re: angryorc] #5282763 12/02/19 10:21 AM
M
MParr Offline
M
I imagine any 5W-30 oil that meets MB 229.5 and VW 504.00/507.00 would be just right.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: sprinter oil change - not low SAP [Re: angryorc] #5282778 12/02/19 10:32 AM
K
kschachn Online Content
Online Content
K
Everyone makes this type of oil choice so difficult when in reality it is very simple. Use any oil that carries the approval required by your owner's manual, make sure it has actual approval and is not just "recommended for" that approval. Ignore grade since all oils that meet the required approval will have a similar HTHS, and there in Georgia the slight differences in winter ratings will have no meaning.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: sprinter oil change - not low SAP [Re: MParr] #5282783 12/02/19 10:34 AM
E
edyvw Offline
E
229.51.
Re: sprinter oil change - not low SAP [Re: edyvw] #5282854 12/02/19 11:43 AM
M
MParr Offline
M
229.51.
Missed it by .01
Anyway many VW 504.00/507.00 oils meet that spec.
https://bevo.mercedes-benz.com/bevolisten/229.51_en.html#close
Re: sprinter oil change - not low SAP [Re: edyvw] #5282867 12/02/19 12:00 PM
A
angryorc Offline OP
A
country))
Re: sprinter oil change - not low SAP [Re: angryorc] #5282873 12/02/19 12:09 PM
A
angryorc Offline OP
A
i will need to fill 10w40 again because engine was used to that oil from the beginning when it was new, the first fill was shell rimula https://www.shell.com/motorist/oils...-duty-engine-oil/shell-rimula-r6-lm.html
now it has 170k miles, can you recommend any good oil of this grade?
Re: sprinter oil change - not low SAP [Re: angryorc] #5282886 12/02/19 12:21 PM
K
Online Content
K
Why would you have to use the same grade? The requirement is the approval, not the grade. I would use the proper approval and forget about what is in there now. Engines do not get “used to” anything.
Pick the least expensive oil you can buy that has the actual approval required for your engine. That’s the best one. If that Rimula is easily available for you and inexpensive then use that. If it’s not then find something else.
Please listen to the advice being given to you here rather than making up new concerns or imaginary ones.
1994 BMW 530i, 251K
Re: sprinter oil change - not low SAP [Re: angryorc] #5283051 12/02/19 03:05 PM
K
Kamele0N Offline
K
You can buy Rimula in the states? I tought that you can get Rotella only...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: sprinter oil change - not low SAP [Re: Kamele0N] #5283056 12/02/19 03:09 PM
K
Online Content
K
Angry Orc said he's from the country of Georgia, even though his location link takes you to the US state.
1994 BMW 530i, 251K
Re: sprinter oil change - not low SAP [Re: kschachn] #5283089 12/02/19 03:35 PM
53' Stude Online Content
Online Content
popcorn
Yup, more to this story
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: sprinter oil change - not low SAP [Re: kschachn] #5283168 12/02/19 04:53 PM
K
Kamele0N Offline
K
Did not know that you can click on a location and google maps show your aprox location smile Since when do we have that feature?
Page 1 of 3 1 2 3
