High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Am I Evil?
by A_Harman - 12/07/19 01:58 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
No passenger tires on LT
by otis24 - 12/07/19 10:23 AM
Subaru Robin 653cc Oil coming out air breather
by Steve_NC - 12/07/19 08:17 AM
Aircraft related, what would you do with $52K?
by Exhaustgases - 12/07/19 05:43 AM
Chevy Suburban on Hollywood walk of fame
by GMguy84 - 12/07/19 05:25 AM
Mills Fleet Farm Havoline & Rotella Sale with Rebate
by Nitronoise - 12/06/19 11:44 PM
85w90 vs 75w90
by Rohan - 12/06/19 11:24 PM
Milwaukee Ratchet & Impact wrench $200
by Deere John - 12/06/19 11:17 PM
Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FRAM ULTRA XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
Michelin Defender on Civic
by jharrison - 12/06/19 08:14 PM
MxTale, icemanrrc, Cobby, nzeroesc, Steve_NC
70059 Registered Users
96 registered members (94astro, alarmguy, 4WD, Audios, Astro14, alchargo, 11 invisible), 2,717 guests, and 60 spiders.
Topics298,406
Posts5,134,818
Members70,059
Most Online3,589
Nov 2nd, 2019
Which Location for Attenuator on Broadband Cable? #5283014 12/02/19 02:33 PM
L
LoneRanger Offline OP
L
In reference to my thread last month about my broadband provider needing to fix our easement box, they came out and did whatever they did which improved but hasn't eliminated the correctable error count. Was getting 750,000 correctables in 24 hrs of uptime, now they're way down to about 25,000 a day. But the downstream power is unchanged @ +9 dBmv. Speeds are back within spec, tests on avg about 70 - 90 Mbps download, 10.9 Mbps upload (subscribed @ 100/10 Mbps), and internet route ping is between 31 - 44ns most of the time testing on the usual speed tests online and not hardwired to the cable modem (clients connected via 5Ghz wifi connection running from 175 - 433 Mbps client to router).
So my question is which is best location (or does it matter) to put a -6 dBmv attentuator ? It's a one way, downstream only ... does not attenuate the upstream power. I currently just have it screwed directly onto the cable modem's coax fitting, but would it be better to locate it in the outside wall box on house to attenuate the power before it enters the house's cable plant?
With the one way attenuator on the modem now, downstream power is holding at +3 dBmv.
'19 Ford F150 2.7 twin turbo GDI V6 .....(Motorcraft 5W30 SN+)
'19 GMC Terrain 1.5 turbo GDI I4...........(GM 0W20 dexos2)
'16 Moto Guzzi 1151cc air cooled v-twin (Eni 10W60)
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283030 12/02/19 02:43 PM
M
mk378 Offline
M
It does not matter.
Are there any splits inside the house for TVs, or is the cable modem the only thing on the line? In general the fewer connections and splitters you have between the street and the modem, the better it will work.
Correctable errors don't hurt your speed, because the data is immediately corrected by the modem and sent to your network -- it doesn't need to be retransmitted. Uncorrectable errors are a problem.
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283032 12/02/19 02:46 PM
Donald Offline
Why do you need an attenuator? Why isn't the cable company giving you service that meets the specs? I would have them out and be there working with them until its right.
But until you get fiber there will always be come issues with coax.
2015 Ford F250 w/Powerstroke
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283096 12/02/19 03:41 PM
Dave9 Offline
You should have linked to that topic or better still, provided a concise summary.
Without that, it appears that you are following bad information. There is no need to attenuate a +9dBmV downstream signal. It is within spec and gives you extra margin should the line degrade or you later need to use a splitter for more devices. Take the attenuator off and see what happens. If the error rate goes up, odds are your modem is faulty.
What is your SNR? Is this an apartment building and there's a cable amp on the line? If so the attenuation should be before the amp, except I don't think YOU should have one at all, rather the amp is flaky, which would not be your property, or the SNR getting to it needs attention. Again this is only in a multi-dwelling apartment/etc where there's an amp to get to 9dBmV.
Re: Which Location for Attenuator on Broadband Cable? [Re: Dave9] #5283266 12/02/19 06:32 PM
L
L
Single family home, no splitters on the line and incoming buried coax connects directly to the coax of the modem's wall drop via a male to male grounded union. Cable company diagnosed last month that the amp or something was faulty in their utility box in the neighborhood's shared easement back of property behind the house, said that box serves four houses (subdivision). SNR is in the 41's all 16 bonded downstream channels, and in the 43's on three bonded upstream channels.
Modem is a two year old Zoom 5370 Docsis 3.0, very stout unit, don't suspect it but will try what you suggested. Thanks for the help smile
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283294 12/02/19 06:58 PM
Dave9 Offline
The utility box probably just has splitters in it, that also attenuate the signal. I'm doubting the problem is on your end, probably they re-did the coax connectors to the splitters just enough to get it working to minimum standards but not quite perfect.
You may be stuck in a gray area of "it works, we delivered what we advertised" if all you're getting is the correctable error count. Realize that a correctable error count is just that, errors that were corrected. Uncorrectable errors are the bigger problem. Your SNR looks good.
I'm just saying that your setup may not be that far from typical if you're doing a fair amount of downloading, streaming video or P2P, etc. to result in 25K correctable errors.
Tell us again why you are chasing correctable errors if you're getting the throughput you're supposed to? Over wifi no less?
Re: Which Location for Attenuator on Broadband Cable? [Re: mk378] #5283329 12/02/19 07:31 PM
R
Rolla07 Offline
R
Originally Posted by mk378
It does not matter.
+1
CEC's are not a problem no matter how high they get. Its CRC errors that cause problems, more specifically your internet would disconnect.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283363 12/02/19 07:56 PM
R
Rand Online Content
Online Content
R
I've never had any luck with zoom.
I'd snag a sb6183 they are cheap now... easy to rule that out then.
but doesnt seem like you have concrete issues?
Re: Which Location for Attenuator on Broadband Cable? [Re: LoneRanger] #5283638 12/03/19 05:59 AM
L
L
Reason I looked at modem page last month was because of pauses in streaming and speed test results well below subscribed limits even in off peak times of day. That prompted initial call, then they came out and diagnosed.
At my other house (been in this current one less than a year) the plant was crystal perfect. Text book signal quality with zero error count 24/7. So I guess I'm spoiled due to that, lol.
Re: Which Location for Attenuator on Broadband Cable? [Re: Dave9] #5283645 12/03/19 06:07 AM
L
L
Probably is the case. Six months into a two year contract for 100 Mbps down, 10Mbps up and bring my own modem. But, it's only $24.99 a month so maybe I should stop griping.
