2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
117 registered members (alphadog, andyd, AC1DD, Audios, 12 invisible), 2,035 guests, and 53 spiders.
Topics298,383
Posts5,134,229
Members70,053
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Sight seepage from drain plug #5282944 12/02/19 01:25 PM
M
Mossyoakglock Offline OP
M
I have a 2008 Silverado w/ 5.3. Using Fram Ultra and M1 5W-30.
I have some slight seepage from my drain plug. I've torqued it to spec and even replaced the entire plug and rubber o-ring but it's still leaking. Maybe 1 or two drops of oil in the garage a night. I was thinking about replacing the plug with one from the autoparts store and using a different gasket. The one that keeps coming up for my truck is the Needa plastic/nylon blue washer.
Is that a reliable gasket and any issues with using a washer/gasket like that?
https://shop.advanceautoparts.com/p...6-P?searchTerm=oil+pan+drain+plug+gasket
It's the bluish/gray one on the top right in the picture.
Could I use teflon tape too? Or some sort or thread sealer?
2008 Chevrolet Silverado
5.3L / 4L60E
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282948 12/02/19 01:28 PM
A
aquariuscsm Offline
A
I’ve had that happen just from the residual oil still dripping out while putting the drain plug back in. It’ll seep out till it’s gone. Maybe just barely visible.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282964 12/02/19 01:41 PM
M
M
I thought that at first but I wipe it down. I'll check it the next day and a few days after (wiping it off each time) and there will be another drip and a new spot on the floor so I think it's definitely seeping. I replaced it last time with an OE plug/gasket.
5.3L / 4L60E
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282965 12/02/19 01:45 PM
demarpaint Offline
Did you try giving it a tiny tweak tighter? I had the same problem twice with an aftermarket plug with a magnet, both times I wiped it down and gave it about 1/16th of a turn tighter, and it resolved the problem. Next OCI I might just go back to the problem free OE plug.
Edit: "I" found the crush washers with that square tab and the one with the black ring to work the best. I have a Dorman transmission pan with a drain plug that leaked like a sieve. The washer with the black ring fixed it perfectly. The crush washer they provided sucked.
God Bless Our Troops
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282968 12/02/19 01:49 PM
Doublehaul Offline
tighten down more and spray nut and pan with brake cleaner when you're done. Spray filter area as well.
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282971 12/02/19 01:52 PM
Passport1 Offline
I have a similar problem with one of my vehicles. I've used both Teflon tape and thread sealant with mixed results.
I just park it on the grass now.
1992 940 Volvo turbo 320K
2006 Saab 9-3 86k
2007 Suzuki Burgman
2012 Suzuki Kizashi
Re: Sight seepage from drain plug [Re: demarpaint] #5282973 12/02/19 01:52 PM
M
M
I did. I think it's 18 ft/lb and I went a hair tighter but still an issue.
I think OReilly might sell a replacement seal for the OE plug but if they don't, are those blue nylon washer/gaskets a good idea? It has ridges like it's a type of crush washer.
5.3L / 4L60E
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5282989 12/02/19 02:11 PM
demarpaint Offline
"I" found the blue washer or the washer with the black rubber ring to work quite well. As long as they are the proper size to fit the drain plugs properly you should be GTG. I'd use which ever one your supplier has on hand that fits.
Re: Sight seepage from drain plug [Re: demarpaint] #5282996 12/02/19 02:21 PM
M
M
This the type you are using?
5.3L / 4L60E
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5283008 12/02/19 02:29 PM
demarpaint Offline
Yes. The blue/gray colored one with the square tab in the link you provided will work too. I have those in a light blue color. Sorry for the confusion. You can change that crush washer w/o draining the oil. Shop Vac Trick To Replace Drain Plug
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5283033 12/02/19 02:46 PM
E
edwardh1 Offline
E
toyota crush washers work well for me
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5283043 12/02/19 02:58 PM
A
atikovi Offline
A
Maybe try 3536966
[Linked Image from images-na.ssl-images-amazon.com]
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5283070 12/02/19 03:18 PM
M
M
That's the OE number that crosses to the Felpro gasket that I can get at Autozone. I'm going to pick one up after work and hopefully that helps.
5.3L / 4L60E
Re: Sight seepage from drain plug [Re: Mossyoakglock] #5283113 12/02/19 03:54 PM
MrQuackers Online Content
Online Content
Could try garden hose washers. I bought a dozen for less than a Dollar.
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Sight seepage from drain plug [Re: MrQuackers] #5283115 12/02/19 03:56 PM
A
atikovi Offline
A
Garden hoses aren't exposed 300 degree oil.
Page 1 of 3 1 2 3
