Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
98 registered members (53' Stude, 750IX, 67ZL1, 25ring, 928, 6 invisible), 2,569 guests, and 25 spiders.
Topics300,360
Posts5,174,165
Members70,491
Page 2 of 2 1 2
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: benjamming] #5282340 12/01/19 07:44 PM
dblshock Offline
You decide....
Honda 1.5 intake
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: benjamming] #5282359 12/01/19 08:07 PM
spasm3 Offline
The instructions for the CRC cleaner say to warm up the engine, and spray the entire can into the brake booster line while keeping the engine at 2k rpm. Let it sit an hour to soak the carbon and then drive at highway speed for at least 10 minutes.
Would the product stay on the valves better( less flash off) If you started out with the engine cold and sprayed it at the 2k rpm then let it soak? Would you not have less flash off and the solvent sit there longer?
The valves will still be warm from running for a minute or so at 2k, just not as hot as fully warmed up.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: benjamming] #5282687 12/02/19 08:45 AM
Cujet Offline
Ez off oven cleaner will clean hard carbon. Used with care, it’s about the most effective carbon-eater.
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: benjamming] #5282879 12/02/19 12:15 PM
B
BMWTurboDzl Offline
B
Walnut blast on high mileage because I'd worry that any cleaner would send a slug of carbon into the cats thereby fouling them. Cleaners are probably ok if used as part of a maintenance regimen (ex, every 25k miles).
435i
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: BMWTurboDzl] #5282882 12/02/19 12:19 PM
supton Online Content
Online Content
Why would one need a regimen of cleaners? I've not run many vehicles past 200k but those have not gotten cleaners, certainly not on a regular basis.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: supton] #5282892 12/02/19 12:33 PM
J
JTK Offline
J
Were any of them direct injected?
I'm with you in that I've never had a vehicle that required a "cleaning" either, but DI's are a whole nother deal.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2012 GMC Terrain 3.0L V6 Intake Valve Cleanup [Re: JTK] #5282906 12/02/19 12:50 PM
Online Content
True that, none were DI. Oh wait--my diesel was a DI, but lemme guess, that doesn't count. wink
Great, now people are going to swarm in and tell me I'm a Luddite for not having any DI's, right? That I'd be better off getting 3 more mpg but having to do 5k OCI's and run some cleaners every 25k, 'cuz that's better for the enviroment?
Eh. Now I'm missing that ole TDi, NOx emissions or not. Oh well. Every technology has its teething issues; DI has come a long ways and isn't quite the scary thing it used to be. And technically engines have been gumming up / carboning up for a long time prior to DI. TDi's especially!
Page 2 of 2 1 2
