Windshield Damage
by MolaKule - 02/28/20 10:16 PM
Too close to home..
by Mad_Hatter - 02/28/20 10:03 PM
Pennzoil Platinum Euro L 5W-30 VOA
by mosschops - 02/28/20 09:53 PM
2008 Can Am Rotax 650 on my ATV
by sloinker - 02/28/20 09:49 PM
Another what is this
by parshisa - 02/28/20 09:20 PM
PTU oil choice?
by mpgo4th - 02/28/20 09:16 PM
School me on Radon...
by dareo - 02/28/20 08:56 PM
How do I bend this fence?
by Chris142 - 02/28/20 07:52 PM
Mercon LV in the transfer case?
by buck91 - 02/28/20 07:41 PM
Wix vanilla filters?
by NavyVet88 - 02/28/20 07:33 PM
What gas do pre-1974 LEADED gas cars run?
by wowthisexists - 02/28/20 05:50 PM
Does anyone do this?.,,
by BigCahuna - 02/28/20 05:49 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
StratMan, ABchevy, RAOD, MichaelTx, duesenberg
70826 Registered Users
54 registered members (alcyon, 14Accent, BLND1, bbhero, 4 invisible), 1,358 guests, and 15 spiders.
Topics302,063
Posts5,208,357
Members70,826
Need a LED work light, # of lumens? Recommendations? #5282780 12/02/19 10:33 AM
J
JLawrence08648 Offline OP
J
I'd like to purchase a LED work light. I had a older Halogen thin bulb light and besides putting out too much light and being very bright, it's hot, too hot for the summer.
I'm divided between a USB rechargeable light with a lithium battery, which I always have electricity, because it is smaller and lighter than 120v and easily charged on the job if needed; or a 120v light then I never have to worry about a battery failing and the unit becoming a throw away.
Next, how many lumens should I be looking at?
I'm looking using it in areas where I'm doing sheetrock, taping, painting, plumbing, replacing a hot water heater in a darker basement, working on a lawn mower or a snowblower in someone's garage, on the occasion that I need extra light. I don't need to light up the whole room, I can turn it, move it, but it should light up most of the wall.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5282813 12/02/19 11:07 AM
W
WyrTwister Offline
W
Buy the brightest one you can get / afford .
Wyr
God bless
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5282836 12/02/19 11:24 AM
W
wkcars Offline
W
If you have some battery powered tools probably check if the brand also make led lights that uses the same batteries.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5282837 12/02/19 11:25 AM
J
jeepman3071 Offline
J
I bought one from Harbor Freight that seems to be decently bright for the price. I've only used it maybe 10 times so far but it seems to work well.
Edit:
this is the one I have:
https://www.harborfreight.com/lighting/work-lights/1000-lumen-led-work-light-64738.html
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (58k) - Liqui Moly 5w40, MANN HU816X
Re: Need a LED work light, # of lumens? Recommendations? [Re: jeepman3071] #5282851 12/02/19 11:37 AM
J
J
It's truly a miracle at Harbor Freight. The LED work lights have nothing but 4 & 5 star reviews.
Re: Need a LED work light, # of lumens? Recommendations? [Re: wkcars] #5282853 12/02/19 11:42 AM
J
J
Great idea. Thanks.
I just checked and Ryobi sells a hybrid work light, that takes my 18v battery and has a removable plug in 120v cord for $70. More than I want to spend but may be worth it however for the same $70 or less I can buy 2 lights, a USB lithium rechargeable and a 120v corded.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5282862 12/02/19 11:50 AM
Dave9 Offline
I would shoot for at least 800 lumens but more is desirable if the budget will stretch, but if you go for a generic you may find that the lumen rating is greatly exaggerated.
A primary consideration is exactly how you'll use it. Those little tabletop lights are handy but often you may find that you want it mounted on a tripod (or hack out some way to get it at the height and position needed for the work) whether that tripod comes with it, or it has a mount for one, or you drill a hole for a DIY mount.
Try to avoid those with low CRI or much over 4500K color temperature for painting or any electrical work where you need to discern wire colors.
As far as what a good value is today, I've no idea as new makes and models are popping up all over the place and going on/off sale.
Be weary of those that have a disproportionately high lumen to rear heatsink area. They'll run hot and be shorter lived. LEDs don't produce nearly as much heat as incan per lumen but some designs out there definitely won't last for several years of use.
I don't have hands on experience with the Harbor Freight light to know how hot it gets but I do notice that all the reviews for it are recent (past two months). It could burn out in a single year of use and nobody had it long enough to reflect that in the review... not to single out that light, any built to a low price point could have this issue. Again consider the heatsink to lumen ratio and if it seems to run too hot, return it for a refund.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5282962 12/02/19 01:39 PM
B
benjy Offline
B
lumens vary with the type of lighting, a cheap hot 500 watt quartz halogen puts out 7000 lumens or more!! lots of options for sure. on the job out drywall finishers aka spacklers carried a cheap 250 watt incandescent inspecting the finish up close!! different lights for different uses + its said LED lights in general are NOT good for eye health!!
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5322249 01/14/20 07:51 AM
J
J
I bought a LED work light at Costco, $30. Has 1 main light with 2 small folding side lights that can be aimed sideways, the whole unit can be aimed up and down, #1600203, 120v, 5,000 lumen, 50w, 4,000K, folded 5"x9"x11", 3 yr guarantee. I love it because it's so small and lightweight, produces no heat, and bright.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5322410 01/14/20 12:13 PM
P
porterdog Offline
P
Not the same form factor as the others shown, but
the Braun handheld at HF is held in pretty high esteem by the hipo flashlight crowd. I've read it goes on sale regularly for ~$20.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5322578 01/14/20 03:26 PM
Quattro Pete Offline
If you want something that runs on AA cells, this Husky is currently $7.88 at Home Depot (in store only):
https://www.homedepot.com/p/Husky-500-Lumens-LED-Dual-Panel-Utility-Light-99877/309379030
The pivoting panels are quite useful, actually. Has built-in magnet as well.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5331869 01/25/20 01:12 PM
M
M635_Guy Offline
M
They're pricey, but Milwaukee has a variety of worklights that are awesome, and several of them will also take an extension cord for the times when you have access to power.
Re: Need a LED work light, # of lumens? Recommendations? [Re: JLawrence08648] #5331943 01/25/20 02:27 PM
E
eljefino Offline
E
Once you have a few hundred lumen you're probably set. I'd look for something with more diffuse light... less harsh, fewer shadows.
I like the battery powered ones. I'm cheap but hate tripping over cords. I could use rechargeables but don't... laziness prevails! Do try to get AA and not AAA models if possible.
Re: Need a LED work light, # of lumens? Recommendations? [Re: eljefino] #5331980 01/25/20 03:28 PM
K
kc8adu Offline
K
removable 18650 all the way.
#18650masterrace.
btw 3aaa powered lights can sometimes take an 18650 with a simple spacer.
aaa cells are a garbage power source for most lights except low power stuff.
3aaa in a carrier=cheap and nasty
Re: Need a LED work light, # of lumens? Recommendations? [Re: kc8adu] #5340785 02/04/20 11:12 AM
P
porterdog Offline
P
#18650masterrace.
This. I mostly now use a 18650 headlamp (Skilhunt H02) vs. the 3AAA Petzls I used for years.
Never going back.
