Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Am I Evil?
by A_Harman - 12/07/19 01:58 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
No passenger tires on LT
by otis24 - 12/07/19 10:23 AM
Subaru Robin 653cc Oil coming out air breather
by Steve_NC - 12/07/19 08:17 AM
Aircraft related, what would you do with $52K?
by Exhaustgases - 12/07/19 05:43 AM
Chevy Suburban on Hollywood walk of fame
by GMguy84 - 12/07/19 05:25 AM
Mills Fleet Farm Havoline & Rotella Sale with Rebate
by Nitronoise - 12/06/19 11:44 PM
85w90 vs 75w90
by Rohan - 12/06/19 11:24 PM
Milwaukee Ratchet & Impact wrench $200
by Deere John - 12/06/19 11:17 PM
Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FRAM ULTRA XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
MxTale, icemanrrc, Cobby, nzeroesc, Steve_NC
70059 Registered Users
102 registered members (53' Stude, 97prizm, 2015_PSD, 4WD, AndyB, 69 Riv GS, 10 invisible), 2,751 guests, and 65 spiders.
Topics298,407
Posts5,134,846
Members70,059
Most Online3,589
Nov 2nd, 2019
Supertech extended drain? #5282740 12/02/19 09:56 AM
Doublehaul Online Crying OP
OP Online Crying
In a Toyota 2.7 (2tr-fe) that sees mostly 75% plus highway driving is there any reason to believe super tech synthetic can't go the 10k oci as recommended by the mfgr?
Current UOAs are with M1 0w40 and I've had a TBN over 4.5 each time after a 10k oci
Same question for a Toyota 4.0.
Reason Im asking is I'm considering switching to D1G2 oils and simply buying off price as its proving to be a very strong spec...and I like the concern for timing chains. The zinc in M1 0w40 concerns me a touch.
Both would be getting 5w30 as per the mfgr.
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Supertech extended drain? [Re: Doublehaul] #5282743 12/02/19 10:00 AM
supton Online Content
Online Content
Are you planning to do a UOA? If so, I'd run it for 10k and measure. I doubt there would be an issue, but why not sleep easy?
I believe others have tested ST and not seen any reason to believe it is somehow sub-par.
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: Supertech extended drain? [Re: Doublehaul] #5282759 12/02/19 10:16 AM
OP Online Crying
I know its not sub par...it carries some strong certs. I will get a UOA...but that negates a good deal of cost savings.
The D1G2 spec is NOT about extended drains IIRC. GM only goes out to like 6 or 7500 OCIs do to the faulty design of many of their timing chains. My concern is that not all D1G2 oils can go to 10k.
Mobil 1 0w40
Re: Supertech extended drain? [Re: Doublehaul] #5282765 12/02/19 10:22 AM
dave1251 Offline
ST meets the specs recommended by Toyota for 10K OCI's. I'm sure it will be a good oil for 10K OCI. I would not worry.
don't use.
Re: Supertech extended drain? [Re: Doublehaul] #5282766 12/02/19 10:22 AM
P
paoester Offline
P
If it passes dexos1, then it's actually better than what Toyota specifies. They only ask for SN GF-5. It's good to go.
Is this for the vehicles in your signature? All engines in the '19 Taco & 4Runner use 0w-20, not the 5w-30 or 0w-40 you discuss.
https://www.toyota.com/t3Portal/document/om-s/OM35B48U/pdf/OM35B48U.pdf
https://www.toyota.com/t3Portal/document/om-s/OM04021U/pdf/OM04021U.pdf
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Supertech extended drain? [Re: Doublehaul] #5282782 12/02/19 10:34 AM
OP Online Crying
According to both owners manuals and this is a quote "An oil with a higher viscosity may be better suited if the vehicle is operated at hight speeds, or under extreme load conditions.
Both of my vehicles qualify. The Tacomas cruising RPM on the interstate is 3500!
UOAs with both vehicles are excellent with 0w40 having a TBN around 5 after 10k. The oil stays within grade and doesn't show any oxidation.
Mobil 1 0w40
Re: Supertech extended drain? [Re: Doublehaul] #5282793 12/02/19 10:44 AM
M
Miller88 Online Content
Online Content
M
I think dnewton7 has posted extended drains of the conventional Supertech and it has done quite well
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Supertech extended drain? [Re: Doublehaul] #5282806 12/02/19 10:57 AM
Chris142 Online Content
Online Content
Our shop truck has the 2.4L version of your 2.7L. It gets whatever oil is on sale. Uually a warren oil,sometimes Napa oil. It gets changed when I remember it. Usually at least 6k oci or more. It has 440K+ on it now.
So I think that if ours can go that mileage on cheap oil the syn can only be better.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Supertech extended drain? [Re: Doublehaul] #5282811 12/02/19 11:02 AM
K
ka9mnx Offline
K
I've been very pleased with ST oil after switching from M1. I considered ST syn as a "safe" 5k oil. My 4Runner is now at 5k and 6 months. I usually change it every year (5k miles) but this year we've been driving it a lot more. Just checked the dipstick and it looks like it was changed last month. I'll check the oil with my Lubrichek gaget this week and probably keep it in until the year is up.
I know, very scientific.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Supertech extended drain? [Re: Doublehaul] #5282827 12/02/19 11:19 AM
Donald Offline
You do a UOA on a new oil brand or additional mileage added to a OCI. Once you know how everything looks then do a UOA only every few OCIs.
2015 Ford F250 w/Powerstroke
Re: Supertech extended drain? [Re: Doublehaul] #5282829 12/02/19 11:20 AM
Donald Offline
UOA kits from NAPA at $16 make it almost reasonable price.
Re: Supertech extended drain? [Re: Doublehaul] #5282831 12/02/19 11:21 AM
OP Online Crying
The problem with the above thinking is that the oil manufactures change the formula all the time...seemingly on a whim. You may be buying the same bottle...but you really dont know what's inside. Mobile has changed the 0w40 at least 4 times since ive been buying it.
With a house brand oil like Supertech you really dont even know who the blender is day to day. Citgo today, warren tomorrow...who knows.
Ive come to understand the spec is all that matters any more.
Mobil 1 0w40
Re: Supertech extended drain? [Re: Doublehaul] #5282833 12/02/19 11:22 AM
OP Online Crying
16 isn't bad...ill check with them. Do you pick them up at the store?
Mobil 1 0w40
Re: Supertech extended drain? [Re: Doublehaul] #5282839 12/02/19 11:25 AM
Donald Offline
I call and they get them in a day or two. Pickup at store.
Re: Supertech extended drain? [Re: Doublehaul] #5282842 12/02/19 11:29 AM
J
jeepman3071 Online Content
Online Content
J
For 75% highway driving I think it would be perfect.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (53k) - Castrol Edge Euro 0w40, MANN HU816X
