Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
82 registered members (4WD, c1vic, BAJA_05, Bookmaker, BeerCan, Audios, 7 invisible),
2,182
guests, and 57
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,383
Posts5,134,204
Members70,052
Most Online3,589 Nov 2nd, 2019
Honda K24 Valve Adjustment
#5282723
12/02/19 09:35 AM
Chester11
OP
OP
Posts: 215 |
Hi folks:
With the temperature drop I am hearing some increased valve noise recently when cold.
I understand the adjustment is supposed to do be done around 110k - I'm at 95k.
I am not sure how often my independent shop does these. (They seem pretty good - I just don't see a ton of Hondas in the lot). Is this a dealer service?
(I watched the how to videos and do not trust myself to have the right feel for this job).
Thanks....
Re: Honda K24 Valve Adjustment
[Re: Chester11]
#5282726
12/02/19 09:40 AM
JeffKeryk
Posts: 2,626 |
If you are over 80K miles on your K24 I suggest having your valves adjusted. There is nothing special about Honda valves; any competent mechanic can do this.
I love to adjust valves. I use a go - no go gauge. I wathced my older brother perform a valve adjustment many years ago on my old 22RE Toyota 4WD Pickup. He simply turned the adjuster a tiny amount until perfection. Easy peasey.
Get 'er done!
2018 Tesla Model 3, Medium Range Battery 2018 Lexus RX450h 2013 Lexus GS350 F Sport 2006 Acura TSX 2001 Tundra Access Cab, 1998 Accord LX, 1968 Corvette L36 Roadster, 1965 Olds 4-4-2
[Re: Chester11]
#5282738
12/02/19 09:51 AM
millerbl00
Posts: 1,014 |
Too tight worse than too loose
[Re: Chester11]
#5282747
12/02/19 10:03 AM
Yah-Tah-Hey
Posts: 4,389 |
You should be able to adjust all twenty four valves on the Honda V6 by searching the internet for directions on starting the lash adjustment with crank pulley set at TDC where several valves can be adjusted and then repositioning the crank pulley to bring more valves to the fully closed position. Find TDC timing mark on pulley and mark with chalk.You can feel the lash of valves fully closed. I remember on my 06 Civic I4, it took two moves after the initial TDC to adjust all sixteen valves. You have to turn engine in direction of normal operation by rotating crank pulley. A Go/NoGo set of feeler gauges will help.Do not over tighten the rocker arm adjustment lock nuts.
[Re: Chester11]
#5282749
12/02/19 10:04 AM
skyactiv
Posts: 6,132 |
I was a technician at a Honda dealer before becoming a semi mechanic. The senior techs got first dibs on all non warranty work as it paid more. Valve adjustments was one of those tickets a good tech could make bank on.
Wife: 15' Audi A4 quattro 6 speed manual Sold: 13' VW GTI 3 door 6 speed manual Me: 18' Elantra Sport 6 speed manual
[Re: Chester11]
#5282752
12/02/19 10:11 AM
Chris142
Posts: 19,872 |
Normally valves get tighter with age. Not looser. As the valve recesses into the head it takes up the clearance at the rocker..The only way for them to get looser would be cam or rocker wear.
02 Wrangler Napa high milage 10w40 87 F250 Valvoline 15w40 07 fjcruiser Car lube plus 10w30 Z400 castrol T 10w40 Can am Maveric edge 5w40 57 case tractor Chevron sae30
[Re: Chester11]
#5282905
12/02/19 12:50 PM
The Critic
Posts: 21,347 |
There's a certain feel to valve adjustment - as a general rule of thumb, the next size up should not go in. If properly adjusted, the selected size of feeler gauge will have a drag when inserted.
IMO, the exhaust valves should be adjusted to the loose end of spec and the intakes should be adjusted to the tighter end of the spec.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30 2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
[Re: Chester11]
#5282908
12/02/19 12:52 PM
WhyMe
Posts: 1,018 |
did this on my CRV. took me a couple of hours as i had to read the instructions. its pretty straight forward. most of mine were tight . i think a dealer charges about $150 for this service. A good mech that does them all the time can knock it out pretty quick
[Re: WhyMe]
#5282991
12/02/19 02:15 PM
The Critic
Posts: 21,347 |
did this on my CRV. took me a couple of hours as i had to read the instructions. its pretty straight forward. most of mine were tight . i think a dealer charges about $150 for this service. A good mech that does them all the time can knock it out pretty quick Most important part is to do the job when the engine is cold. I think Honda says a ECT <100F is acceptable, but cold is best.
[Re: Chester11]
#5283009
12/02/19 02:31 PM
bozo66
Posts: 6 |
Honda dealer in Florida quoted me four hundred dollars to inspect and adjust valves at 110,000 miles about six months ago.
[Re: Chester11]
#5283140
12/02/19 04:21 PM
ctechbob
Posts: 628 |
If you decide to tackle it yourself (Its not that hard, really) go ahead and order up new spark plug tube seals, valve cover gasket, and valve cover bushings. Those are your 'might as well since I'm here' things to replace. Stick with Honda OEM for them. I've had really bad luck with aftermarket VC gaskets in my J Series cars for some reason, so the cost savings isn't worth doing the job twice. Its pretty evident in the quality as well. I had a Felpro and a Honda gasket side by side, the Honda was thicker and had ribs cast into it to expand out into the VC groove.
As far as the actual adjustment, most of it has been covered here. There is a special tool you can buy if you want that lets you hold the adjuster and tighten the jam nut, but on the K24 where everything is on top you could probably just as easily do it with a 10mm wrench and flat head screwdriver. The tool isn't expensive, I think I paid $10 for mine off Ebay if I recall.
2008 Acura TL Type S-155k* 2003 Honda Accord V6-207k Oil-Havoline ProDS 5W30 / *HM 5W20 Filter-Partsmaster 61334 Trans-Idemitsu H+
[Re: Chester11]
#5283153
12/02/19 04:36 PM
JeffKeryk
Posts: 2,626 |
Go No Go GuageCheck clearance with guage; if it is within speck leave it alone. Put wrench on lock nut and good screwdriver into adjuster slot. Crack nut while holding screwdriver. Turn screwdriver a tiny amount; snug lock nut and recheck clearance. Repeat until clearance is within spec and snug down adjuster nut. Recheck clearance. You will be a pro in no time. She will purr like a kitten. Easy peasey. Have The Critic come over if you screw it up. No biggie. Good luck and have fun with it.
[Re: Chester11]
#5283769
12/03/19 09:02 AM
Chester11
OP
OP
Posts: 215 |
Thanks for all the help folks - appreciate it.
I'm going to talk with my shop and see what they say. Anything near $400- I may tackle it myself.
[Re: Chester11]
#5283811
12/03/19 09:45 AM
meep
Posts: 4,119 |
chatty valves are happy valves!
2018 F150 2015 crv (wifey!)
[Re: bozo66]
#5284062
12/03/19 02:41 PM
Mitsu_Joe
Posts: 63 |
Honda dealer in Florida quoted me four hundred dollars to inspect and adjust valves at 110,000 miles about six months ago.  Holy sh... I have to check/adjust the valve clearance each ~15k mls on my engine. Nobody paid even close to 400 bucks for that back in the day. It does not require any special tools, just a wrench and a screwdriver and takes ~30 mins. It is an 8 valve engine, though I am also not a trained mechanic. Even for a 24 valve engine, the whole job should not take longer than two hours unless you have to get tons of stuff out of the way to disassemble the valve cover. Probably it’s like with carburetors, very few people know what to do at all and therefore they charge premium prices.
1988 Mitsubishi Galant, Meguin SL 5W-40
