2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
103 registered members (4WD, AC1DD, AandPDan, alphadog, 14 invisible), 2,166 guests, and 50 spiders.
Topics298,384
Posts5,134,246
Members70,053
Most Online3,589
Nov 2nd, 2019
Making Coffee with Alkaline Water #5282669 12/02/19 08:27 AM
B
buster Offline OP
B
For those that have GERD/LPR or any reflux issues, have you considered making coffee with Alkaline water to reduce the acidity? I just did a quick google search and it seems to be quite common, not only to reduce the acid levels, but also improve taste.
I ordered some Black Rifle Coffee. I like it, but it's pricey and don't think it lives up to the hype.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Making Coffee with Alkaline Water [Re: buster] #5282672 12/02/19 08:32 AM
supton Offline
I've had some heartburn issues in the past, and whenever I'm on the road and need coffee, I just add sugar and cream. Not sure if that battles acid or not.
This link indicates that dark roasts have less acid, didn't know that.
https://www.livestrong.com/article/511107-how-to-neutralize-the-acid-in-coffee/
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: Making Coffee with Alkaline Water [Re: buster] #5282674 12/02/19 08:35 AM
PimTac Offline
A tiny amount of baking soda does the same thing. However, if you reduce the acid the coffee taste will change.
I’m drinking the Beyond Black roast. I use a press pot. 4 minutes brew and it’s done. Overbrewing can raise acid levels.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Making Coffee with Alkaline Water [Re: buster] #5282682 12/02/19 08:40 AM
B
buster Offline OP
B
thumbsup
Re: Making Coffee with Alkaline Water [Re: buster] #5282683 12/02/19 08:41 AM
J
jalf Offline
J
I've had serious GERD problems for years. I dilute my morning coffee with microwave-heated soy milk. Roughly four parts coffee, one part vanilla-flavored soy milk. Sometimes I add a squeeze or two of caramel syrup, then blend for three seconds in the Magic Bullet. Works for me to lessen the acid.
2015 LaCrosse 26,000
2009 Outback 86,000
2002 Corolla 101,000
5W30 X 3. The Buick gets the pricey oil.
Re: Making Coffee with Alkaline Water [Re: buster] #5282694 12/02/19 08:53 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Coffee is acidic, as are most foods. Milk and cream are some of the few foods that are alkaline. I'd use cream, not alkaline water.
Re: Making Coffee with Alkaline Water [Re: buster] #5282703 12/02/19 09:02 AM
M
mcrn Offline
M
Have you tried a cold brew? I am using that and do not have a problem. i believe it is less acidic.
2012 Nissan Rogue
Re: Making Coffee with Alkaline Water [Re: buster] #5282712 12/02/19 09:15 AM
Q
Quattro Pete Offline
Q
One nice thing with a manual espresso machine is it allows you to control extraction amount, thus controlling acidity level. Pulling a long shot makes it more acidic. Pulling a short shot gives you the nice flavors, but leaves acidity out.
I use ZeroWater filtered water to make coffee. Haven't tried alkaline water though.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Making Coffee with Alkaline Water [Re: Kestas] #5282715 12/02/19 09:21 AM
B
buster Offline OP
B
I love espresso. The Acid Watcher Diet is great for those that suffer from reflux related issues. Not only does it give you a nice breakdown of all the pH levels of different food, but it also talks a lot about foods that are acid producing. And pepsin as well.
I use almond milk or soy creamer 90% of the time. I gave alkaline water a shot today.
Re: Making Coffee with Alkaline Water [Re: buster] #5282724 12/02/19 09:38 AM
U
UG_Passat Offline
U
You can get coffee with lower acid levels.
I buy my beans from Coffee Bean Direct.
https://www.coffeebeandirect.com/
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Making Coffee with Alkaline Water [Re: buster] #5282735 12/02/19 09:49 AM
G
Gebo Offline
G
Buster, that is a great idea. I'll give it a try.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Making Coffee with Alkaline Water [Re: buster] #5282770 12/02/19 10:27 AM
K
kschachn Offline
K
Compared to the pH of stomach acid coffee is only mildly acidic. But if you want to adjust the pH why not do so after brewing? If you can measure the pH then you would know how much alkali to add to reach neutral or slightly alkaline.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Making Coffee with Alkaline Water [Re: buster] #5282784 12/02/19 10:34 AM
R
Rolla07 Offline
R
Some coffees advertise low acidity, so trying that may also help.
I drink this one and it does make a difference;
https://www.costco.ca/william-spartivento-sumatra-medium-dark-roast-fair-trade-and-organic-whole-bean-coffee%2C-2-pack.product.100122567.html
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Making Coffee with Alkaline Water [Re: kschachn] #5282799 12/02/19 10:52 AM
B
buster Offline OP
B
You can do it that way too, but I don't like to dilute coffee.
Some foods are acid forming, despite their pH being mildly acidic or even neutral. But that's going off-topic.
Re: Making Coffee with Alkaline Water [Re: buster] #5282810 12/02/19 11:00 AM
H
hallstevenson Offline
H
Originally Posted by buster
...making coffee with Alkaline water to reduce the acidity?
What's the pH level of your tap water ?
