Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
71 registered members (ArrestMeRedZ, Aero540T, apollo18, 14Accent, 69Torino, AC1DD, 5 invisible), 1,561 guests, and 47 spiders.
Topics298,351
Posts5,133,556
Members70,043
Most Online3,589
Nov 2nd, 2019
First UOA. What mileage? #5282666 12/02/19 08:21 AM
STIcandy Offline OP
I have a 2006 pontiac vibe, 219k kms on the clock with the 1.8L toyota motor. The fill right now is Motul xclean efe 5w-30 with a toyota short filter. It's approaching 10,000kms and 4 months on this oci and I want to do a UOA next oil change with an interest in stretching the OCI out. The farthest I'd want to take the oil to time wise is 6 months (change it in the spring and in the fall.)
Any suggestions on where to start? I can change it at 10,000kms (6200 miles) or string it to 12k (7400 miles). Obviously the next OCI will be determined by the UOA just trying to find the sweet spot where the UOA and associated oil change wouldn't be considered a waste.
Re: First UOA. What mileage? [Re: STIcandy] #5282709 12/02/19 09:08 AM
B
BMWTurboDzl Offline
B
Assuming you're using the appropriate oil start at the interval recommended by the automaker.
435i
Re: First UOA. What mileage? [Re: STIcandy] #5282734 12/02/19 09:49 AM
W
WobblyElvis Offline
W
I live close to you and suffer a similar climate. You didn't state the type of driving you do or how many kilometers a year but I will assume it's similar to my own. I put 200,000 km on a car while changing the oil/filter twice a year [ spring and fall ] or approximately every 13,500 km. and I learned a few things by looking under the valve cover and sending in a few oil samples.
The engine got a little dirty as small amounts of sludge started to form in the corners, The engine stayed much cleaner on cheap conventional oil using 8,000 km OCIs as the previous owner had done. Used oil analysis showed increased wear, fuel dilution and insoluble levels during the winter months as opposed to summer months.
Over all the engine outlasted the rest of the car and was still in good condition at 374,000 km when it was scrapped. I learned that if I was going to change oil only twice a year I would make the OCI longer in the summer months and shorter in the winter. Maybe change April 1st and Nov 1st. a 7 - 5 months split.
Everyone's driving habits and conditions are different, and engines are expensive, so you want to be cautious. A UOA does not tell the whole story but it helps. I wouldn't really recommend you change oil only twice a year unless you keep a close eye on the engine.
Re: First UOA. What mileage? [Re: STIcandy] #5282773 12/02/19 10:29 AM
dave1251 Offline
Keep the oil topped off and if the expensive oil can't go 8K miles in a passenger vehicle. It's not worth buying.
don't use.
Re: First UOA. What mileage? [Re: WobblyElvis] #5282776 12/02/19 10:31 AM
STIcandy Offline OP
You're right, I realized after I posted I didn't mention the driving. It's typically 80% highway 20% city. I realize I wasn't being totally clear.
My aim is to change the oil either twice a year or at XX,XXX kms. Typically with this car I won't make it to 6 months. I change the oil when I do the winter tire swap and hope to not hit the mileage until it warms up and I have use of the hoist (when my summer toy comes out).
To be completely honest, I'm thinking my target OCI for this particular car is going to be 10-12k or 6 months whichever comes first with the oil changes being Oct/Nov and April/May (if I make the time limit.) Other than that I'll have to take the car off the hoist to change the oil on the pontiac.
My wifes 2013 Santa fe is the one I really worry about. She drives less than 10Kms one way to work so it never really warms right up. I have her Park it in the heated garage in an effort to speed up warm up time in the morning at least and we drive it for evening running around and weekend excursions. That one does way less mileage and usually hits the time limit.
Thanks for the input. Definately food for thought.
Re: First UOA. What mileage? [Re: STIcandy] #5282792 12/02/19 10:44 AM
Doublehaul Online Crying
Online Crying
Im pretty comfortable around 7500 miles with any SN+ lube to the point i wouldn't bother with a UOA until around 10k miles.
This is assuming your not direct injected. If that's the case id run the cheapest SN+ i could find and change it a 5k. My father has one of the early and very problematic GM 3.6l v6s. He's changed the oil at every 5k with either coastal or service pro and his engine runs like a top with over 150k on it.
Direct injection, turbo, or combo means 5k OCI in my book and at that interval oil quality really doesn't matter any more assuming its API Sn or Sn+
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: First UOA. What mileage? [Re: Doublehaul] #5282927 12/02/19 01:12 PM
STIcandy Offline OP
From what I've been reading the SN+ rated oils are reserved mostly for the Turbo GDI engines not NA GDI engines. Am I incorrect here? My vibe is PFI so that is a non issue, but the Santa fe is a GDI and it only calls for an API SN oil in the manual. Shout I be looking for a SN+ oil?
Re: First UOA. What mileage? [Re: STIcandy] #5283160 12/02/19 04:44 PM
K
ka9mnx Offline
K
Using SN+/dex1 Gen2 oil in my PFI vehicles and working quite well.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: First UOA. What mileage? [Re: WobblyElvis] #5285041 12/04/19 02:36 PM
ChrisD46 Offline
*Good comments here - in my GD! Sonata engine I have been running 4K mile / 4 month OCI's (or approx. three oil & filter changes per year) with synthetic D1 / Gen 2 rated oils . My worse case OCI is winter , so upon completion of this upcoming OCI I will get a UOA done to see how my engine looks on a 4K / 4 month OCI ? Then I will know if I can extend the OCI or not ? If I was only going to go with two oil changes per year - I would use M1 EP or Castrol EP for the longer oil drain benefit .
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
