Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Subaru Forester with rusty brakes
by Donald - 12/14/19 12:55 PM
2017 Honda CRV, 1.5 Turbo, Mobil AFE 0W-30
by 06_lx - 12/14/19 11:48 AM
Toyota WS ATF or Aisin WS ATF
by dblshock - 12/14/19 10:28 AM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
93 registered members (4WD, 69Torino, 928, 77GrandPrix, 2015_PSD, 9 invisible), 1,508 guests, and 22 spiders.
Topics298,815
Posts5,141,801
Members70,129
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Crushed washer #5282653 12/02/19 08:05 AM
dosmom Offline OP
Hello, I have a 2008 Honda Odyssey which I know has an aluminum pan and a 2011 Toyota corolla. I am not sure if the toyota pan is steel or aluminum, does anyone know?
What type of washer is recommended to use for each for the oil drain plug? I have seen a washer that is metal along the outside with rubber in the middle, don't know if this is acceptable or if it is better to use a crushed washer on both of the vehicles. Thanks.
Re: Crushed washer [Re: dosmom] #5282667 12/02/19 08:22 AM
R
ragtoplvr Offline
R
I like the steel washer with the molded oring
Rod
Re: Crushed washer [Re: ragtoplvr] #5282679 12/02/19 08:40 AM
dosmom Offline OP
Do you mean one like this?
Re: Crushed washer [Re: dosmom] #5282697 12/02/19 08:56 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Check the pan with a magnet
Check the pan with a magnet.
Re: Crushed washer [Re: dosmom] #5282704 12/02/19 09:04 AM
M
mclasser Offline
M
For the Honda, it's a metal crush washer. Don't fool around with anything else or you'll have drips / a stripped pan. Buy from the dealer or a baggie full from Amazon.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Crushed washer [Re: dosmom] #5282710 12/02/19 09:10 AM
K
Kira Offline
K
I service 2 Honda engines, an '07 Odyssey and a 2010 Accord.
Both had 14mm aluminum crush washers.
I use 14mm aluminum crush washers.
The metal/neoprene one dosmom posted a picture of above is my personal favorite.
It would be my "pre-goop" choice to address a leaking oil drain.
The Saabs had copper washers. I used copper washers on them.
Re: Crushed washer [Re: dosmom] #5282722 12/02/19 09:31 AM
dosmom Offline OP
Thanks. Sounds like it should be a crushed washer on the honda. How about the Corolla? Crushed or the metal/neoprene or does it not matter if it is a steel pan?
Re: Crushed washer [Re: dosmom] #5282728 12/02/19 09:43 AM
Donald Offline
Fumoto valve.
The metal and rubber one should work for a few oil changes in either vehicle. A few, not twenty. I like them. But the Fumoto valve is even better.
2015 Ford F250 w/Powerstroke
Re: Crushed washer [Re: dosmom] #5282732 12/02/19 09:47 AM
G
Gebo Offline
G
Toyota's OEM are either blue or black. They have either a blue or black coating on them.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Crushed washer [Re: dosmom] #5282736 12/02/19 09:51 AM
A
atikovi Online Content
Online Content
A
If it's not leaking, why not use the one that's on there right now?
Re: Crushed washer [Re: dosmom] #5282739 12/02/19 09:52 AM
Doublehaul Offline
I hate crush washers and after having a fumoto fail on me ill never use another. Crush washers are used for ease of assembly imho. I use a standard fibreor plastic/rubber re-useable drain plug gasket from auto zone. Never leaks, never stains etc.
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
Re: Crushed washer [Re: dosmom] #5282745 12/02/19 10:02 AM
M
Mad_Hatter Offline
M
Am I the only one who gets a "free" copper crush washer with their filter?πŸ€”
(and I never reuse a crush washer, not worth the few cents a new one would cost.. I'm cheap but not that cheap!πŸ˜‚)
Re: Crushed washer [Re: Mad_Hatter] #5282750 12/02/19 10:05 AM
PimTac Offline
I get a free crush washer from Mazda when I buy the filter.
And for the record it’s a CRUSH washer, not crushed.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Crushed washer [Re: mclasser] #5282751 12/02/19 10:09 AM
Yah-Tah-Hey Offline
Or purchase a box of washers from Clips&Fasteners. Don't go Cong on tightening drain plug, especially if the oil pan is aluminum.
Re: Crushed washer [Re: PimTac] #5282758 12/02/19 10:15 AM
A
Online Content
A
To be accurate, it's a seal or gasket. It's only called a washer because it looks like one.
Page 1 of 3 1 2 3
