New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
24 registered members (Black_Thunder, bbhero, dlundblad, 6 invisible), 1,556 guests, and 18 spiders.
Topics300,519
Posts5,177,620
Members70,518
Mixing hydraulic fluid and ATF #5280896 11/30/19 07:07 AM
dlundblad Online Happy OP
OP Online Happy
I bought a SpeeCo branded log splitter yesterday. It came with 5 gallons of AW46, but once the entire system filled up, it’s about an inch below the add mark on the dipstick and 1.5 gallons low.
I’m seeing mixed reviews online that don’t seem to match what’s in my owners manual. People say their manual specifically says not to mix whereas mine says it can be “substituted” ( I take this to mean it’s mixable?) as well an an entire switch for cold weather performance.
Are there any long term issues with me topping off the system with ATF? I have plenty of that on hand.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5280934 11/30/19 08:16 AM
K
Kira Offline
K
You'd think mere filling of rams would be forgiving but I guess it's all about how the fluid mix will treat the pump.
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5280983 11/30/19 09:55 AM
M
maxdustington Offline
M
I wouldn't, especially on something brand new. BITOG anxiety!
99 Toyota Tercel CE 5EFE/C151
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5281072 11/30/19 11:58 AM
MolaKule Offline
Global Moderator
Global Moderator
If its a 22 ton log splitter (you didn't state the model or tonnage force) the stated capacity is 5 gallons and usually comes with NAPA ISO 46 fluid.
Filtering is important so stock up on extra filters and replace 1 quart per filter change.
A recommended hydraulic Oil which is a blend of mineral and synthetic base oils can be found in ISO46;
https://www.schaefferoil.com/documents/130-254-td.pdf
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5281082 11/30/19 12:20 PM
Chris142 Offline
Don't mix them. You may use one or the other but not both mixed. I mixed them in our lift at work and it foamed.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mixing hydraulic fluid and ATF [Re: MolaKule] #5281386 11/30/19 06:37 PM
OP Online Happy
Thanks. It’s a 25 ton.
The reservoir holds 5 gallons. Filling the entire system while maintaining a “filled” amount requires 6.5. It’s also good to know ISO46 is a blend.
I’ll stick with the one fluid.
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5281505 11/30/19 09:32 PM
MolaKule Offline
Global Moderator
Global Moderator
ISO 46 Hydraulic fluid can be based on anything from pure mineral oil, to a mineral oil PAO Blend, to a pure PAO synthetic.
Cold weather performance improves as you go from a mineral oil to a Blend to a synthetic.
When I built log splitters using Caterpillar Rams, I used Schaeffer #254.
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5281633 12/01/19 05:33 AM
OP Online Happy
Thanks.
I have no idea what it ended up coming with, but I’m assuming it’s the cheapest mineral stuff possible. The containers were generic with no manufacturer. Same with the pint of oil it came with. No manufacturer.
I’ll see how it does in the cold before topping off.. I guess the less fluid the system has, the faster it’ll warm up and since it’s cold, nothing should get too hot.
Their idea of cold weather and when to change to a better fluid is 32*F so I may have to make a change sooner rather than later. Somewhat surprising it came with such a thick oil since you’d think anyone splitting wood would be in temps much colder.
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5281651 12/01/19 06:23 AM
OP Online Happy
Say I did want to switch.
How clean would the system have to be if changing from hydraulic oil to ATF? I assume no old fluid can be left behind. Seems like it’d be easier to stick with a thinner and/ or synthetic hydraulic oil since I’d assume I’d just need to drain and refill.
Maxlife ATF seems like the cheapest well rounded option IMO. Cheap, easy to find and full syn.
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5282514 12/02/19 12:26 AM
MolaKule Offline
Global Moderator
Global Moderator
Thanks.
... Somewhat surprising it came with such a thick oil since you’d think anyone splitting wood would be in temps much colder.
The fluid that it came with should have the same viscosity as a Dex/Merc ATF since it specs an ISO46 fluid.
I suggested stocking up on filters because those filters can trap a lot of moisture.
Re: Mixing hydraulic fluid and ATF [Re: MolaKule] #5282556 12/02/19 04:56 AM
OP Online Happy
I’ll do that.
Hopefully I can find an aftermarket version.
Re: Mixing hydraulic fluid and ATF [Re: MolaKule] #5287440 12/07/19 06:25 AM
OP Online Happy
Thanks.
How are these systems prone to moisture buildup?
Re: Mixing hydraulic fluid and ATF [Re: dlundblad] #5288797 12/08/19 06:24 PM
MolaKule Offline
Global Moderator
Global Moderator
Thanks.
Speeco 25 Ton Log Splitter Manual
Page 10, Item 16, Part No. 3903750, Dip Stick/Breather Cap
Re: Mixing hydraulic fluid and ATF [Re: MolaKule] #5288866 12/08/19 07:44 PM
OP Online Happy
Thanks.
This is what I was guessing, but I wanted to make sure.
It’s garage kept and will never see rain so that should help.
