NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
40 registered members (Char Baby, bullwinkle, AurionX2, Bailes1992, 2015_PSD, 77GrandPrix, 4 invisible), 1,173 guests, and 16 spiders.
Topics300,377
Posts5,174,523
Members70,491
RTV tube dispenser #5282283 12/01/19 06:37 PM
A
atikovi Offline OP
A
[Linked Image from fototime.com]
If you have ever tried to lay a bead of RTV on a transmission or oil pan, water pump, valve cover, rear axle cover, etc. you know how tiring on your hands it can be squeezing the tube just the right amount while trying to hold the tip steady. With this pistol grip dispenser you have much greater control and power from leverage action. Standard 3 oz tube shown, not included. $15 shipped in the USA. Paypal OK.
Re: RTV tube dispenser [Re: atikovi] #5282346 12/01/19 07:48 PM
W
Warstud Offline
W
A soup can filled with hot water will soften it up enough to make squeezing pretty easy
Re: RTV tube dispenser [Re: atikovi] #5282353 12/01/19 08:00 PM
A
atikovi Offline OP
A
Which messes up the cure time. There is a reason it's called ROOM TEMPERATURE vulcanizing.
Re: RTV tube dispenser [Re: atikovi] #5282379 12/01/19 08:36 PM
rooflessVW Offline
RTV cures upon exposure to air. Warming it before application will not negatively affect the cure time.
"Zed's dead baby, Zed's dead."
Re: RTV tube dispenser [Re: atikovi] #5282382 12/01/19 08:40 PM
A
atikovi Offline OP
A
Heat generally speeds up the cure time of chemicals, but ok.
Re: RTV tube dispenser [Re: atikovi] #5282387 12/01/19 08:43 PM
rooflessVW Offline
And I said that heat would not negatively affect the cure time.
It will improve it.
Re: RTV tube dispenser [Re: atikovi] #5282388 12/01/19 08:46 PM
A
atikovi Offline OP
A
That's the opposite of what you want on something that takes a few minutes to lay out.
Re: RTV tube dispenser [Re: atikovi] #5282407 12/01/19 09:09 PM
rooflessVW Offline
He didn't say boil the stuff.
If I can complete a complex assembly on a 110+ degree day, after removing the tube of RTV from a metal locker sitting in the sun, warming it slightly before applying it will do no harm.
Seriously, man.
Re: RTV tube dispenser [Re: atikovi] #5282411 12/01/19 09:12 PM
clinebarger Offline
I've always used a Roller Key
2001 Chevy Camaro L92/4L80E
Re: RTV tube dispenser [Re: atikovi] #5282440 12/01/19 09:46 PM
bdcardinal Offline
I use the Motorcraft stuff that you use with a caulking gun.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: RTV tube dispenser [Re: atikovi] #5282606 12/02/19 07:15 AM
J
jeepman3071 Offline
J
The issue I have had is keeping it from drying out. Even with the cap secured it seems to only last maybe a week before most of the tube is dried out.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: RTV tube dispenser [Re: atikovi] #5282671 12/02/19 08:31 AM
M
MasterSolenoid Offline
M
OP, thanks for the photos.
I've never seen a dispenser like that.
What I've always done when using a 'sealant' in a metallic tube is;
roll the tube up as it's used / keep tapping the rolled end with a hammer to keep it tight & compact.
If not, as you would squeeze the tube, the contents have a tendency of moving in the wrong direction.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: RTV tube dispenser [Re: atikovi] #5282705 12/02/19 09:05 AM
A
atikovi Offline OP
A
Pistol grip gives more control and a uniform output as you squeeze the trigger.
Re: RTV tube dispenser [Re: atikovi] #5285654 12/05/19 07:43 AM
A
atikovi Offline OP
A
Sold.
