2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
94 registered members (Armkb, 94astro, Anduril, 2010Civic, aquariuscsm, aprilia1, 7 invisible), 2,164 guests, and 71 spiders.
Topics298,365
Posts5,133,856
Members70,047
Most Online3,589
Nov 2nd, 2019
HDD and VMs #5282367 12/01/19 08:23 PM
javacontour Online Content OP
OP Online Content
For the second time in about as many years, the drive holding my Virtual Machine images died.
Probably just coincidence, but I was wondering if hosting a VM disk image is harder on a drive than simply hosting ordinary files like spreadsheets, documents, images and media?
I was able to recover the VM that was impacted by the bad sectors. But even f lost, it was no big deal as I use the same machines on my desktop and laptop, so I can export one from the machine that is still up, so no data lost as far as I can tell.
(See on-line back up thread as well.)
Just curious if it's just random chance the the two drives that have failed in the past two years (January 2018 and December 2019) were both the dive hosting the virtual machine disk image files, or if such work beats up the drive far more than other work loads.
network down, IP packets delivered via UPS -BOFH
Re: HDD and VMs [Re: javacontour] #5282390 12/01/19 08:46 PM
OP Online Content
Of course, it could just be an old drive:
CrystalDiskInfo 5.6.2 (C) 2008-2013 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 8 Pro [6.2 Build 9200] (x64)
Date : 2019/12/01 11:27:00
-- Controller Map ----------------------------------------------------------
+ Standard SATA AHCI Controller [ATA]
- hp DVDRAM GTA0N
- TOSHIBA HDWD130
- WDC WD4003FZEX-00Z4SA0
- Samsung SSD 850 PRO 512GB
- Microsoft Storage Spaces Controller [SCSI]
+ Standard NVM Express Controller [SCSI]
- MS1PC5ED3ORA3.2T
-- Disk List ---------------------------------------------------------------
(1) TOSHIBA HDWD130 : 3000.5 GB [0/0/0, pd1]
(2) WDC WD4003FZEX-00Z4SA0 : 4000.7 GB [1/0/0, pd1] - wd
(3) Samsung SSD 850 PRO 512GB : 512.1 GB [2/0/0, pd1] - sg
(1) TOSHIBA HDWD130
Model : TOSHIBA HDWD130
Firmware : MX6OACF0
Serial Number : XXXXXXXXX
Disk Size : 3000.5 GB (8.4/137.4/3000.5/3000.5)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 5860533168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600
Power On Hours : 15441 hours
Power On Count : 41 count
Temparature : 33 C (91 F)
Health Status : Caution
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0000h [OFF]
AAM Level : ----
It's accumulated 643 days of powered on time.
Re: HDD and VMs [Re: javacontour] #5282393 12/01/19 08:56 PM
O
OVERKILL Online Content
Online Content
O
Is it harder on the drive? I'd say yes, because the drive cannot optimize the placement of anything, it's in one huge file that's just constantly thrashing the same areas.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: HDD and VMs [Re: javacontour] #5282400 12/01/19 09:05 PM
dogememe Online Content
Online Content
It's just random. I owned a hosting company with a decent amount of customers and quite a large number of physical server, most with multiple hard drives. HDD failures, while rare, seemed to happen regardless of how the drive is used. In my home I have about two dozen drives in a couple servers running 24/7... I've had one drive failure in the past year and it was not a heavily used drive.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~289K Miles: Unknown Oil, Filter.
Re: HDD and VMs [Re: javacontour] #5282424 12/01/19 09:23 PM
ctechbob Offline
https://static.googleusercontent.com/media/research.google.com/en//archive/disk_failures.pdf
Granted, this study is over 10 years old now, but its a good read for HD failures. Its a study Google did back in 2007 across their farms.
"One of our key findings has been the lack of a consistent pattern of higher failure rates for higher temperature drives or for those drives at higher utilization levels. Such correlations have been repeatedly highlighted by previous studies, but we are unable to confirm them by observing our population."
"The data in this study are collected from a large number of disk drives, deployed in several types of systems across all of Google’s services. More than one hundred thousand disk drives were used for all the results presented here. The disks are a combination of serial and parallel ATA consumer-grade hard disk drives, ranging in speed from 5400 to 7200 rpm, and in size from 80 to 400 GB."
Just found that Backblaze is posting drive failure information as well.
https://www.backblaze.com/b2/hard-drive-test-data.html
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: HDD and VMs [Re: OVERKILL] #5282619 12/02/19 07:33 AM
OP Online Content
Mostly read...
But I should probably make sure I'm not swapping to the disk just in case a VM runs out of memory.
My data is stored on other drives on the host, so the VMs would be getting documents, spreadsheets, etc from the other spinning disk in the machine.
I was thinking the same with respect to the one large file, say 10 to 50gb for a disk image. As I mentioned above, if a machine begins to swap, it may get write heavy. I need to check if they have and/or are using a swap partition.
Other than the SSD, it was the oldest drive in the machine. And I do replace a number of drives with a variety of ages in my job.
It probably is harder on the drive for sure. But hard enough to cause an early death?
We can debate for ages.
Thanks for the feedback.
Re: HDD and VMs [Re: javacontour] #5282995 12/02/19 02:18 PM
O
Online Content
O
You are quite welcome cheers
