Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
112 registered members (40Deluxe, 53' Stude, 379KITTY, aquariuscsm, Aichiguy, Astro_Guy, 8 invisible), 1,786 guests, and 30 spiders.
Topics298,592
Posts5,138,785
Members70,104
Most Online3,589
Nov 2nd, 2019
Broken pcv tube. #5282276 12/01/19 06:21 PM
D1dad Offline OP
I noticed a crack in the back of my pcv tube that goes from the valve to the manifold. Not the hose that runs to the intake. Who knows how long this has been like this but it didn’t make the car act up or throw a check engine light. What damage could this have caused if any? Oil consumption, rich fuel mix?
Re: Broken pcv tube. [Re: D1dad] #5282567 12/02/19 05:23 AM
L
Lubener Offline
L
Be nice if you stated what vehicle.
Not likely any damage would have resulted. That smaller line likely was tied to your evap. system, the large one would be manifold vacuum.. You would have leaned out the fuel mix by creating a large vacuum leak and possibly some oil contaimination so I would change it if it looks very dirty.
The "thinking" man's friend.
Re: Broken pcv tube. [Re: Lubener] #5282573 12/02/19 05:57 AM
M
Mad_Hatter Offline
M
Only if his car uses MAF only for f/a. But if it uses MAP or a combination of MAP+MAF like mine, the ECU should correct, no?
As for the pcv.. crankcase pressure would have vented to atmo. You might have experienced a higher rate of varnish build up, especially on the non pcv side if it's dohc. You don't mention anything about your car.
Re: Broken pcv tube. [Re: D1dad] #5282641 12/02/19 07:55 AM
W
WyrTwister Offline
W
We live in a sometimes sandy , semi-arid region . Any potential vacuum leak would scare me . Repair it .
Wyr
God bless
Re: Broken pcv tube. [Re: D1dad] #5282649 12/02/19 08:02 AM
Driz Online Content
Online Content
Cars run so hot those plastic fittings tend to dry out and crack when they’re old. Just find a replacement off the net, auto zone ect and you’re good to go. When the hose ends start splitting is a good time to start checking them periodically.
Re: Broken pcv tube. [Re: D1dad] #5283131 12/02/19 04:12 PM
D1dad Offline OP
Sorry I forgot. It’s my 09 altima that’s been using oil forever, oil was dirty within 500 miles after every change and started consuming oil there after. I had the cover off and had the car serviced by Nissan but I never caught it, it was in the back, nor did the Nissan tech obviously. Could a cracked tube have been a major contributor to the vast oil consumption? It’d be nice if it did.
