Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
93 registered members (AZjeff, 40Deluxe, A_Harman, b1amgm47, 53' Stude, 379KITTY, 9 invisible), 1,813 guests, and 31 spiders.
Topics298,592
Posts5,138,799
Members70,104
Most Online3,589
Nov 2nd, 2019
which torque wrench should i get #5282192 12/01/19 04:43 PM
W
WhyMe Offline OP
W
wanna get a new 1/2" . i am torn between a split beam and a digital. i will use it mainly to torque lug nuts . i already have a couple of clickers and want to try something else . of these 2 which one would best suit my needs
https://www.amazon.com/Precision-In...SFIM/ref=cm_cr_arp_d_product_top?ie=UTF8
https://www.amazon.com/GEARWRENCH-85077-Electronic-Torque-Wrench/dp/B01AY0JG0U/ref=sr_1_11?crid=3BIH2RZ8M52WA&keywords=torque+wrench+digital+1%2F2+inch+drive&qid=1575240207&sprefix=torque+wrench+digital+1%2F2%2Caps%2C213&sr=8-11
Re: which torque wrench should i get [Re: WhyMe] #5282204 12/01/19 04:55 PM
justintendo Offline
go for the split beam! reliable and accurate. no need for electronics in a torque wrench..the precision ones are good for the money
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: which torque wrench should i get [Re: justintendo] #5282286 12/01/19 06:43 PM
A
atikovi Offline
A
So how do you know you have reached the torque without feeling a click from a clicker or a beep from an electronic one?
Re: which torque wrench should i get [Re: WhyMe] #5282292 12/01/19 06:54 PM
T
totegoat Offline
T
My $10 1/2" drive torque wrench from HF works just fine on lug nuts. Enjoy your new tool.
Re: which torque wrench should i get [Re: WhyMe] #5282303 12/01/19 07:08 PM
Chris142 Offline
It's my understanding that the split beam ones never need to be calibrated.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: which torque wrench should i get [Re: atikovi] #5282328 12/01/19 07:32 PM
B
benjamming Offline
B
Split beams provide a click as well that is also felt in the wrench.
Re: which torque wrench should i get [Re: WhyMe] #5282333 12/01/19 07:39 PM
SouthDakotaDad Offline
I have owned the Tekton from Amazon in ft lbs and inch lbs for the past four years. I have used it for everything you can think of automotive related and they work very well and are not expensive.
Of course, I always store them with no tension on them ever and that probably helps keep these in good shape.
2015 Corolla LE, 1.8, QSUD 0w-20, Fram Ultra
2012 Scion XB 2.4, QSUD 0w-20, Fram Ultra
Re: which torque wrench should i get [Re: WhyMe] #5282342 12/01/19 07:45 PM
spasm3 Online Happy
Online Happy
Member Traction posted a calibration on his Precision brand beam wrench. It needed no adjustment after 8 years of use!!
https://www.bobistheoilguy.com/foru...got-torque-wrench-calibrated#Post5126040
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: which torque wrench should i get [Re: WhyMe] #5282354 12/01/19 08:02 PM
T
Trav Offline
T
+1 on the split beam, perfect for what you need.
Re: which torque wrench should i get [Re: WhyMe] #5282423 12/01/19 09:23 PM
E
EdwardC Offline
E
I have that exact split beam and love it. Just used it yesterday when I swapped in the winter tires. It's great to be able to leave the wrench at the torque setting you already need (or at least a close range), and not to have to deal with dead batteries.
Re: which torque wrench should i get [Re: WhyMe] #5282525 12/02/19 12:58 AM
R
redbone3 Offline
R
Digital would be expensive and an overkill. Split beam or regular clicker are both suitable. As a general rule, the better torque wrenches are substantially longer that the cheapo ones and are easier to use.
2014 Passat Wolfsburg, 1995 Miata.
Re: which torque wrench should i get [Re: totegoat] #5282526 12/02/19 01:03 AM
T
TheLawnRanger Online Content
Online Content
T
+1
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: which torque wrench should i get [Re: totegoat] #5282541 12/02/19 02:52 AM
Char Baby Offline
I just bought the 1/2" clicker type($10) from Harbor Freight to keep in the car/trunk with my tire repair kit and tire inflator. I also just bought the 100 psi tire inflator from HF(tested ed by Project Farm) for trunk storage only.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: which torque wrench should i get [Re: redbone3] #5286254 12/05/19 05:41 PM
R
R1jake Online Content
Online Content
R
I have multiple torque wrenches but recently added both of the new HF Quinn digital torque wrenches to my tool set and I’m loving them. 3/8 and 1/2 drive the smaller good for 5/100ftlbs the larger good for 12.5-250ftlbs both have great features too and also do n-m, ftlbs, inchlbs,& kgcm. Both are very accurate as well. I think they are priced right.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: which torque wrench should i get [Re: WhyMe] #5286371 12/05/19 07:37 PM
doitmyself Offline
Unlike all other torque wrenches, the HF Quinn digital models don't mention any accuracy loss below 20% of full scale. Interesting.
