Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Am I Evil?
by A_Harman - 12/07/19 01:58 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
No passenger tires on LT
by otis24 - 12/07/19 10:23 AM
Subaru Robin 653cc Oil coming out air breather
by Steve_NC - 12/07/19 08:17 AM
Aircraft related, what would you do with $52K?
by Exhaustgases - 12/07/19 05:43 AM
Chevy Suburban on Hollywood walk of fame
by GMguy84 - 12/07/19 05:25 AM
Mills Fleet Farm Havoline & Rotella Sale with Rebate
by Nitronoise - 12/06/19 11:44 PM
85w90 vs 75w90
by Rohan - 12/06/19 11:24 PM
Milwaukee Ratchet & Impact wrench $200
by Deere John - 12/06/19 11:17 PM
Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FRAM ULTRA XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
MxTale, icemanrrc, Cobby, nzeroesc, Steve_NC
70059 Registered Users
118 registered members (53' Stude, Al, 2015_PSD, Astro14, 16 invisible), 2,575 guests, and 52 spiders.
Topics298,408
Posts5,134,903
Members70,059
Most Online3,589
Nov 2nd, 2019
What can I use an air hammer for? #5282093 12/01/19 02:50 PM
J
JLawrence08648 Online Content OP
OP Online Content
J
I bought an air hammer at Harbor Freight for $15 to pick up/remove a wooden laminate floor in a small kitchen and foyer area at my sister's Condo. It worked well and did the job.
Now what do I use it for? Around the house, lawn mowers, snowblowers, cars?
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282098 12/01/19 02:54 PM
2
2strokeNorthstar Offline
2
Just look for attachments. Some will surprise you.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282106 12/01/19 03:00 PM
A
atikovi Offline
A
For tight spaces under the car where there isn't room to swing a hammer. Like suspension work.
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282114 12/01/19 03:05 PM
rollinpete Offline
Rivots on frame rails.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 189k miles
03 Saturn Ion 2.2 L4 5spd 240k miles
Shell Rotella Gas Truck 5w30
PPHM 5w30
Currently under the influence of oil shocked2
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282115 12/01/19 03:05 PM
J
Jimkobb Offline
J
Air does not need hammering.
green_bay_packers_logo_small[1]
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282124 12/01/19 03:14 PM
Chris142 Offline
I recently used mine to remove pressed in control arm bushings.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282126 12/01/19 03:14 PM
T
Traction Offline
T
Air hammers can be used creatively for lots of stuff. Get the hammer bit, that comes in handy. I straightened a nasty crease in a fender once using it like a planishing hammer on a hardwood bench for a backer. Using a regulator to dial it down for the task is a must too. I used it to install an oil pump pickup on a 350 Chevy, and it worked great.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282160 12/01/19 03:58 PM
T
Traction Offline
T
Also the pickle-fork attachments work great on tie rods, and ball joints, etc. The hammer head I mentioned works for driving out wheel studs, and anything else frozen together. Haven't tried it on u-joints since I have a press, but it would work for that too. Hundreds of little hammer blows often works much better than one BFH blow.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: What can I use an air hammer for? [Re: Jimkobb] #5282165 12/01/19 04:02 PM
W
Wolf359 Online Content
Online Content
W
It's just like an Air Guitar.
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282185 12/01/19 04:32 PM
T
Trav Offline
T
Re: What can I use an air hammer for? [Re: Trav] #5282237 12/01/19 05:34 PM
A
atikovi Offline
A
Originally Posted by Trav
What about this one: https://surrauto.com/kits/bb007/ Only had to use it once so far but worked like a charm.
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282256 12/01/19 05:58 PM
dlundblad Offline
The HF pickle fork attachment is pretty nice for suspension component separation.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282272 12/01/19 06:18 PM
V
vwmaniaman Online Content
Online Content
V
Works great to cut off an old tail pipe. Also the pointed bit works good to "drill" a hole in the floor pan to mount an exhaust hanger. Ceramic tile is no match for a wide chisel.
Don't waste your time on a slipshod repair.
Re: What can I use an air hammer for? [Re: atikovi] #5282355 12/01/19 08:03 PM
T
Trav Offline
T
Same thing just another brand.
Re: What can I use an air hammer for? [Re: JLawrence08648] #5282375 12/01/19 08:30 PM
ccs368 Offline
There were several times the air hammer saved my [censored]. I need to remove steel wheel from car and it's frozen to the brake drum from corrosion. Repeated swings with my hammer didn't work so the air hammer rattled enough of the corrosion to break it free.
One other time my slider pins were corroded to the brake carrier bracket as the boot was torn and allowed water in. I had new replacements and hammering with a screwdriver wasn't helping so the air hammer did the trick.
I replaced a wheel bearing and it's retained inside the steering knuckle with a circlip. The circlip was pretty rusted so using the air hammer carefully sort of massaged the circlip to move in the groove.
Lastly the air hammer with a chisel helped take ceramic tiles from the subfloor.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
