What's going on?
by clinebarger - 12/13/19 12:28 AM
Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
27 registered members (adams355, clinebarger, carlprop, alcyon, cos, c502cid, 4 invisible), 798 guests, and 25 spiders.
Topics298,666
Posts5,140,069
Members70,115
Most Online3,589
Nov 2nd, 2019
Worn hydro gear or linkage? #5281971 12/01/19 12:30 PM
I
i6pwr Offline OP
I
We bought a Husqvarna 1542XP lawn tractor with the Kawi FH430V brand new about 12 years ago. Has the fender mounted lever for the hydro gear and has performed very well.
Hour meter just hit 1200 hrs and we've noticed a little bit of play in the linkage. Couple days ago the linkage had a good 2 inches of play for and aft and I cannot see anywhere that the linkage is severely worn or bent. Naturally the forward and backward travel of the lawn tractor is affected and doesn't want to move very fast at times.
Belt is new as of a month ago with no issues with pulleys, springs etc...just the sloppy linkage in the control lever.
Could this be internal or are there other symptoms?
Not sure what the telltale signs of a worn gear is.
Re: Worn hydro gear or linkage? [Re: i6pwr] #5284070 12/03/19 02:46 PM
J
JTK Offline
J
So if you physically grab the shaft on the transaxle itself, it has a large amount of play in either direction?
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Worn hydro gear or linkage? [Re: JTK] #5284191 12/03/19 05:01 PM
I
i6pwr Offline OP
I
No, that linkage is tight. I did pull the transaxle so I could change the original oil @ 1200 hrs. With doing that, I believe I found the culprit.
This linkage had about 1/16" or slightly more, of play on each side.
[Linked Image]
[Linked Image]
The total so 1/8" - 3/16" total play translated to about 2" at the handle. I trust this is the only issue.
I ordered the bar and the two bolts, but will change out the oil anyway.
Debating M1 15W-50 or M1 V-Twin 20W-50...or other options.
Re: Worn hydro gear or linkage? [Re: i6pwr] #5284327 12/03/19 06:54 PM
J
JTK Offline
J
Wow! That linkage is wallowed out for sure. Good find.
Either of those 50wts would be a wise choice IMO.
