Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
111 registered members (alarmguy, alcyon, 69Torino, 40Deluxe, ammolab, Aero540T, 10 invisible), 1,858 guests, and 29 spiders.
Topics298,593
Posts5,138,816
Members70,104
Most Online3,589
Nov 2nd, 2019
Head gaskets, thermostat? #5281742 12/01/19 08:45 AM
O
otis24 Offline OP
O
1991 Chevrolet K1500, 4.3 engine. Engine temperature shoots up pretty quickly upon starting. Would think that if it was the thermostat, it would take a bit for the temperature to come up. Your thoughts?
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2016 Dodge Grand Caravan
(3.6 V6) 46500 miles
Re: Head gaskets, thermostat? [Re: otis24] #5281746 12/01/19 08:49 AM
Astro14 Offline
Are you certain that the dash gauge is accurate?
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Head gaskets, thermostat? [Re: otis24] #5281760 12/01/19 09:02 AM
Silverado12 Offline
Although I have heard of 4.3 head gasket leaks, it's not a common problem. If there's air in the system the temp will rise quickly. If the block is busted from freezing maybe too.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Head gaskets, thermostat? [Re: otis24] #5281762 12/01/19 09:06 AM
M
mk378 Offline
M
Are you saying that this fast warm-up is followed by overheating?
Any thermostat should be fully closed during warm-up, so it wouldn't matter. Slow or no warm-up would mean thermostat is stuck open.
Very easy to remove thermostat on these to test or just replace.
Re: Head gaskets, thermostat? [Re: otis24] #5281809 12/01/19 09:47 AM
O
otis24 Offline OP
O
When the key is off and the vehicle has sat for a while, the temp is staying up. Makes me think it is a guage or coolant temp sensor issue. Er, I should say that the guage reading is staying up.
Re: Head gaskets, thermostat? [Re: otis24] #5281825 12/01/19 09:59 AM
W
Warstud Offline
W
oh
Re: Head gaskets, thermostat? [Re: otis24] #5281851 12/01/19 10:32 AM
M
mk378 Offline
M
Have you checked that the radiator is full? Any operational problems such as boiling over or heater not working?
Re: Head gaskets, thermostat? [Re: otis24] #5281868 12/01/19 10:49 AM
Z
zzyzzx Offline
Z
If it were a newer vehicle, I would connect a code reader that does live data, compare that to the dash gauge that you are presumably looking at.
Re: Head gaskets, thermostat? [Re: otis24] #5281871 12/01/19 10:51 AM
O
otis24 Offline OP
O
Radiator is full. No apparent sign of overheating. Didn't run it long enough today to get the temperature up to check the heater.
Re: Head gaskets, thermostat? [Re: otis24] #5281920 12/01/19 11:50 AM
W
Warstud Offline
W
Probably a bad Coolant Temp Sensor. There's probably two....so make sure your replacing the one that connects to the dash gauge. There not expensive but you can test it before replacing it. Check YouTube for testing. I'd start spraying it down with penetrating oil now.
Re: Head gaskets, thermostat? [Re: otis24] #5281978 12/01/19 12:35 PM
A
andyd Offline
A
Typically the sender you want as a single , one for FI is 2 wire. grin2
Thick oil is better grin2
Re: Head gaskets, thermostat? [Re: otis24] #5281982 12/01/19 12:39 PM
Chris142 Online Content
Online Content
It would take about 15 minutes from a cold start to get hot. If it's going up faster than that it's likely the gauge or sender. Check the actual temp with an IR gun.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
