how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
Did Honda discontinue PSF
by iluvhonda - 12/08/19 02:44 PM
02 Silverado 5.3L LT Gas fill issue
by Gito - 12/08/19 02:30 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
29 registered members (A_A_G, 4WD, BarryinIN, AZjeff, Char Baby, 3 invisible), 735 guests, and 60 spiders.
Topics298,471
Posts5,136,092
Members70,070
Most Online3,589
Nov 2nd, 2019
Does it fit? #5281733 12/01/19 08:36 AM
N
nickaluch Offline OP
N
I have a 2017 Hyundai Elantra with base 195/65/15 tires on steel rims. I found on Craigslist 2013 OEM alloy rims for Elantra size 205/55/16 complete with tires and tmps sensors. Will they fit? I just want to put them on with no headaches.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Does it fit? [Re: nickaluch] #5281743 12/01/19 08:46 AM
Astro14 Offline
Are you asking a bolt pattern question?
Or a tire size question?
The tires will be about an inch shorter
overall. About a 5% difference in diameter, speedometer reading, etc.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Does it fit? [Re: Astro14] #5281752 12/01/19 08:53 AM
N
N
A bolt pattern question. From what I know there is no difference between the two years but the body style update and interior update also new engine. Is it just put the rims on and drive?
Re: Does it fit? [Re: Astro14] #5281770 12/01/19 09:16 AM
A
atikovi Offline
A
Actually they are nearly the same, less than 1/2% difference.
https://www.tacomaworld.com/tirecalc?tires=195-65r15-205-55r16
Re: Does it fit? [Re: Astro14] #5281781 12/01/19 09:23 AM
A
ARCOgraphite Offline
A
Astro I think you forgot the 55 series would be upped to a 16"
So they will be basically the same O.D and circ.
I also looked at a set of Avid Ascend and the reported Diameter diff for actual tire was only 0.1" shorter than current.
And that within the tire wear range - so not noticeable.
Does the OP know if they have a 5 lug pattern and what the bolt circle is?
And TPMS tech may be a concern.
Sounds like its time to join an Elantra Forum smile
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Does it fit? [Re: ARCOgraphite] #5281797 12/01/19 09:39 AM
N
N
There both 5 bolt pattern. I'm thinking is a slap on and drive. The bigger tire size and rim was OE if you went up one trim level
Re: Does it fit? [Re: nickaluch] #5281846 12/01/19 10:26 AM
slacktide_bitog Offline
Yes, they will fit smile
Re: Does it fit? [Re: slacktide_bitog] #5281870 12/01/19 10:50 AM
N
N
That's what I'm thinking. I just joined a Hyundai forum asked the same question waiting on some responses
Re: Does it fit? [Re: ARCOgraphite] #5281887 12/01/19 11:12 AM
Astro14 Offline
You’re right, absolutely missed the 16”.
So...same diameter, a standard +1 set up.
Only question then, is TPMS and, perhaps, bolt pattern...
32 Packard 15W40
05 MB S600 0W40 M1
