how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
Did Honda discontinue PSF
by iluvhonda - 12/08/19 02:44 PM
02 Silverado 5.3L LT Gas fill issue
by Gito - 12/08/19 02:30 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
29 registered members (A_A_G, 4WD, BarryinIN, AZjeff, Char Baby, 3 invisible), 735 guests, and 60 spiders.
Topics298,471
Posts5,136,092
Members70,070
Most Online3,589
Nov 2nd, 2019
Exhaust clamps, regular or guillotine? #5281688 12/01/19 07:23 AM
A
atikovi Offline OP
A
I'm replacing an exhaust system using stock parts. They specify these regular style clamps.
[Linked Image from static.summitracing.com]
Wouldn't these guillotine style clamps seal better?
[Linked Image from gautoparts.com]
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281700 12/01/19 07:49 AM
F
FT92 Offline
F
I've always used the first type pictured, never a problem
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281703 12/01/19 07:51 AM
E
eljefino Offline
E
I've gotten leaky "wrinkles" out the sides where the pipes squish using the first style. A little muffler cement on the joint is a good backup.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281711 12/01/19 07:56 AM
A
atikovi Offline OP
A
From what I read, the second one provides a 360 degree seal but isn't widely available.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281725 12/01/19 08:27 AM
B
benjy Offline
B
it matters NOT because typical materials + even cheap widely use 400 grade stainless will rust + or corrode quickly making removal a cutting operation. when using lifetime 300 series stainless band clamps of 300 series stainless are best allowing removal anytime. depending on where you live + vehicles life costly 300 stainless if available is best as it outlasts the vehicle no matter where you live!
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281736 12/01/19 08:38 AM
T
Trav Offline
T
For me both of those fall in the same category are worm drive hose clamps. I use these..
[Linked Image]
https://www.verociousmotorsports.com/Shop-by-Brand/Torca/AccuSeal-Exhaust-Clamps
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281738 12/01/19 08:41 AM
A
atikovi Offline OP
A
I see these stainless steel band clamps for six times the price. Won't they leak at the bottom?
[Linked Image from i.ebayimg.com]
Re: Exhaust clamps, regular or guillotine? [Re: Trav] #5281740 12/01/19 08:44 AM
A
atikovi Offline OP
A
[Linked Image]
Those only work with pipes that have slots on the ends.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281747 12/01/19 08:50 AM
T
Trav Offline
T
Take a whiz wheel and put a couple of slots in the pipe end, no big deal.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281763 12/01/19 09:06 AM
Silverado12 Offline
A guy at the muffler shop showed me a trick a long time ago. He used high temp silicone RTV on the joints and it lasts the life of the exhaust system for sealing minor leaks. Sometimes you slightly deform a joint when you take apart the system and this will prevent leaks.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281765 12/01/19 09:07 AM
M
mk378 Offline
M
What car comes from the factory with clamps as part of the stock system?
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281768 12/01/19 09:10 AM
A
atikovi Offline OP
A
The first style because it's the cheapest.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281772 12/01/19 09:19 AM
M
mk378 Offline
M
If you use the u-bolt style ones, as suggested put sealant in the joint before starting. Tighten up the clamp then loosen it and rotate about 90 degrees around the pipe and tighten again.
Re: Exhaust clamps, regular or guillotine? [Re: atikovi] #5281776 12/01/19 09:21 AM
Driz Offline
Me too but I’m always willing to look towards something better if it’s not too $$$$$. I like the way those worm type don’t tend to lock pipes together by making that crush ring in both of them.
Re: Exhaust clamps, regular or guillotine? [Re: mk378] #5281784 12/01/19 09:26 AM
Silverado12 Offline
Sometimes you'll have a bolted together flange that won't seal perfectly because it's slightly deformed so the silicone trick works for that. Yeah, you're right all I have seen are welded or have a flange.
00 Mustang GT auto
