Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
94 registered members (40Deluxe, alarmguy, alchargo, Ag76, 77GrandPrix, 9 invisible), 1,763 guests, and 16 spiders.
Topics298,824
Posts5,142,059
Members70,129
Most Online3,589
Nov 2nd, 2019
Am i overdoing it? #5281641 12/01/19 05:49 AM
E
Espada Offline OP
E
I have a 1998 Mitsubishi lancer with engine that started to consume oil with 20w50 oil with added oil treatment, i started doing this mix for my engine oil, 4 liters mixed with 120ml liqui moly oil additive " mos2 " and 1 can of mannol motor doctor 9990 but one of my friends told me i am overdoing it with the mos2 as the engine is a goner anyways and i am just getting any life out of it before changing the short block, so my question is should i use oil with mannol doctor only or keep using the mix i did?
Re: Am i overdoing it? [Re: Espada] #5281646 12/01/19 06:10 AM
SVTCobra Offline
How much oil is it consuming? 1 liter per 2000 km or anything similar? If it's much worse than this then I don't think any additives will slow down consumption.
Think twice, speak once.
Re: Am i overdoing it? [Re: Espada] #5281647 12/01/19 06:17 AM
PimTac Offline
This problem has been ongoing based on your last thread.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5217928/1
Additives are not going to fix what is probably a bad job by the mechanic who worked on your engine.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Am i overdoing it? [Re: Espada] #5281648 12/01/19 06:18 AM
dlundblad Offline
If whatever you’re doing is working, then I don’t think you’re overdoing it.
If you aren’ seeing any improvements, I’d just go back to what you were doing before.
X2 on how much it’s consuming. If it recently started to and it’s an issue, are you certain it’s not a leak?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Am i overdoing it? [Re: Espada] #5281652 12/01/19 06:25 AM
E
Espada Offline OP
E
I know nothing is going to fix i am just trying to prolong the life of the engine as much as i can, the car is burning 1litre every 1000 - 1500km depends on speed and if i am traveling or inside town
Re: Am i overdoing it? [Re: Espada] #5281751 12/01/19 08:53 AM
Astro14 Offline
One liter every 1000-1500 km isn’t bad. If it gets worse, it’s likely rebuild time, based on previous discussion (not valve stem seals, right?).
Honestly, I would just buy a good quality oil, keep it topped off and save your money for the next car/rebuild. The additives aren’t making any difference in your problem, but they are draining your wallet faster...
The 20W50 is a good choice for both your car, and your climate...never gets cold in Cairo...but it sure gets hot in summer!
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Am i overdoing it? [Re: Espada] #5281775 12/01/19 09:20 AM
A
aquariuscsm Online Content
Online Content
A
Maybe just try a 20W50 high mileage formula oil.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Am i overdoing it? [Re: aquariuscsm] #5281788 12/01/19 09:30 AM
K
ka9mnx Offline
K
I haven't seen such an item.(?)
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Am i overdoing it? [Re: Espada] #5281789 12/01/19 09:32 AM
K
ka9mnx Offline
K
Yes. Time to face the reaper and either rebuild, sell or scrap.
Re: Am i overdoing it? [Re: Espada] #5281795 12/01/19 09:36 AM
B
BLND1 Online Content
Online Content
B
This is after a bad repair job? Sounds like you’ll need a rebuild. Weigh the costs of that vs a new vehicle.
Re: Am i overdoing it? [Re: ka9mnx] #5281798 12/01/19 09:39 AM
A
Online Content
A
Here's a couple:
Maxlife 20W50
https://sharena21.springcm.com/Publ...bd3/dcefb479-09bd-e711-9c12-ac162d889bd1
GTX High Mileage 20W50
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/E06073C8EBB011BD80257DFD00582FDA/$File/BPXE-9UF2AZ.pdf
Re: Am i overdoing it? [Re: Espada] #5281852 12/01/19 10:34 AM
M
Mad_Hatter Offline
M
Is this the same engine that didn't have the valve stem seals replaced..or was it the rings, can't recall?? Either way you shouldn't be drinking that amount of oil after a rebuild. Otherwise, what was the point of the rebuild???
I'd take it back and make them fix it.
Re: Am i overdoing it? [Re: Espada] #5281892 12/01/19 11:16 AM
Astro14 Offline
I don’t think it was rebuilt - I think the OP was considering a repair, and opted not to. A Litre every 1000-1500 KM isn’t terrible. Some car companies won’t even fix that under warranty.
Oil recommendations for specific brands won’t help him much, the market for oil in Egypt is different...
Espada - it’s a lot cheaper to buy an extra litre every month than it is to rebuild this engine, or to concoct lots of additives.
Just keep your money in your wallet. Buy a decent 20w50 and keep driving.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Am i overdoing it? [Re: Astro14] #5281911 12/01/19 11:40 AM
M
Mad_Hatter Offline
M
It was rebuilt.
https://www.bobistheoilguy.com/foru...it-safe-to-use-100-synthetic#Post5190894
Re: Am i overdoing it? [Re: Espada] #5281956 12/01/19 12:18 PM
J
JC1 Offline
J
As others have said, just keep it topped up.
Keep it going for as long as you can, until you can afford to replace the car. I would not being spending more money that may not possibly fix the issue second time around.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
